I select program all the lights go on but the door locked button keeps flashing and it wont start,the door is closed firm?
    President:
  • 1,554 Answers
It doesn't necessarily mean that the door switch contact is close when the door is firmly shut. The door locked indicator flashing indicates an error in the door locking system particularly the door switch. The door locking routine is initiated only when the door switch is close for the wash cycle can start.
Indicate the exact model number of the machine for further troubleshooting advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting a solution will not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 30, 2010
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
CathI have a dishlex global 510 and I cant open the door does it have a child lock and if so how do I turn it off so as I can open the door
heres what it says in your manual
Follow these steps to set the Button Lock function:
1. Switch on the appliance.
2. Set a washing program.
3. Start the washing program.
4. Press Button Lock for approximately 5 seconds, or
until the Button Lock indicator light flashes.
5. Button Lock indicator light flashes for approximately
15 seconds.
6. When Button Lock function is active the indicator
light is on with a static light.
At the end of a washing program the Button Lock function
is deactivated by opening and closing the door or
switching off the appliance.
Important! It is not possible to deactivate the Button
Lock function while a washing program is in progress
if you have any further questions message me back Thanks Rick
Jun 11, 2011 | Dishwashers
We have a Whirlpool WFS1071BW, and it has just stopped working for no reason. When you start the cycle (any cycle), it starts and then after 5 seconds or so, stops, the "Start" button light...
The problem is the door switch likely broken or not being activated. Make sure the door is closed firmly and nothing is caught in the door that might prevent the door from closing tightly. Replace the door lock/switch assembly if the door is closed firmly. You should hear the door lock/switch clicks when Start is pressed.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Mar 06, 2011 | Washing Machines
How do you program new spare key for 2007 rodeo RA?
if its the ignition key it must be done by a dealer and have a lage black plastic head which has got a transponder in it. If you got a blank key cut at the locksmith it will turn the locks but wont start the car. Usually you get the dealer to do both supply ignition key and then get it cut, then they can program it.
but if your asking how to program the keyless entry remote follow this procedure.
take note step 5 is different for different year models.
Make sure that all the doors are closed and unlocked and wait for dome light to go out before starting.
Insert the ignition key into the ignition switch
Open drivers door
3 on/lock
Close/open drivers door
Wait 8 secs
On/lock/on (MY06-07) OR 2 on/lock OR on/lock (MY08)
Close drivers door
Hazards flash
Press remote & keep pressing one button & then the other slowly(2 secs) until locks start working(they wont operate if key is in ignition).
Hazards flash
Feb 23, 2011 | Isuzu Rodeo Cars & Trucks
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
Machine won't start and clicks if turned on with door open
Ok, this is the fix:
No payload. Close the door. Press off, then press on. Then enter a program starting by selecting the fabric and the others as usual. Do not press start, instead press the slip button to advance the programme to the very last phase, ie drain and empty. Then press start. It will perform this operation with no load and pump out the “no water”. This part takes 5 minutes. After the 5 mins the programme will end and the machine will beep annoyingly, but the computer will be reset and you can clear the program and use the machine as normal.
Why?
I had the same problem. The stupid computer inside remembers the program whilst it’s off and unplugged. What has happened is you accidently pressed start and start again to pause it in very quick succession. This confuses the computer and it thinks that a program is in progress. This is why it wants to close the door. There is no problem with the latch (unless it is a separate problem). You have to let it play out a program to reset it, which is why you can play the very last “drain” segment.
Question.
Presumably there’s a way to reset the computer either by a secret button combo or shorting out two pins from the computer box. I don’t know. If someone knows this please tell me.
Good Luck!
Jun 07, 2008 | Zanussi FJS1225W Front Load Washer
Oven door will not close because the door lock is on and flashing, also the oven light won't go off. how do I fix the door lock flashing so I can close the oven door completly?
is not actuallly physically closing??? perhaps the lock/ latch has partially engaged prevetning door from closing, and with the door oopen it cannot do anything for safety reasons. can you see a door /light switch thtyou can depress by hand??? if so push and hold it in the light should go out, and at this point continue to hold in switch and try starting a self clean cycle ( dont worry it wont actually start cleaning right away)it then should activet the latch assy to fully engage and suppoedly lock door, still depressing the button then press thecancel button and the latch should return to the normal resting position and you can close the door
Apr 03, 2008 | Ovens
Door locked indicator light flashing
reposition the switch.. in the door
first try holding button at door with finger and press start..if same symptom appears...check tab that depresses that switch and if its good try to reposition or replace switch.
Feb 26, 2008 | Hotpoint WMA50 Front Load Washer
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
FLASHING LIGHT(WHIRLPOOL AWM6120 FRONT LOAD WASHER)
This happens to me every time i put a load in, try giving the door an extra nudge to close it, just give it a firm push where the handle to open it is. hope that helps!
Sep 19, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
