Question about Hoshizaki Commercial Freezer KM-500MAH
KM-500-MAE Hoshizaki Problem huge cubes, alarm code three beeps
    Director Badge:
    Uploaded 100 video answers.
  • Hoshizaki Master
  • 488 Answers
Might need to clean float switch, or water inlet valve bypassing water. Deep clean Hoshizaki.
Posted on Oct 08, 2015
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
Clean or adjust your ice thickness probe
Posted on Oct 01, 2010
  • jason zeringue Oct 01, 2010
    im shure i have the repair manual for this machine if you need it jason
The KM-500MAE has 3 beeps in 3 seconds after 2 consecutive cycles. What should I check?
Hoshizaki has service info on line in pdf format on servicing and trubleshooting. The machine itself has info on what three beeps message is. Sorry, no pinpoint fix
Aug 25, 2015 | Freezers
Km-280mae alarm beeping
the number of beeps indicates the issue. count the beeps and repost.
Aug 08, 2014 | Hoshizaki Freezer Commercial Ice Machines...
My hoshizaki KM-320MAH ice machine has 2 beeps going on - help!
This is a "defrost too long" code. Look for bad thermistor or low refrigerant charge first as these are the easiest and most likely place to start.
Sep 03, 2013 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki km-900mah not going into harvest when float switch opens. New circuit board installed still no harvest. I can set an egg timer and manually operate machine but I can't leave it unattended...
Hoshizaki machines must have a very clean evaporater other wise the ice will bind causing a slow harvest. This may be from lime scale build up. "Lime A Way" is recommended for this proper cleaning. After that is done check to see that the water inlet valve screen is clean and that you have a filter installed.
Last check the thermister attached to the suction line.
http://www.hoshizakiamerica.com/techtips/Pdf/All/tips105.pdf
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a Hoshizaki model Km-250baf it beeps three times.
3 beeps means it has been in the freeze cycle too long. A stuck float switch can cause this as well as a leaking water valve. Look for that first. Let me know if you need more info.
Feb 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
KM-500-MAE Problem huge cubes,alarm code 3-beeps
excessive freeze cycle=60 minutes. In almost every case, it's the water valve (sometimes called the fill valve) is leaking water continually into the sump. Turn machine off and see if you can still hear water running into the unit. If so, it the valve leaking. Just replace it.
http://www.hoshizakiamerica.com/manuals/KM-500M_E_serv.pdf
Go to this site and download you copy of the service manual. It has lots of good stuff.. Let me know if I can be of any further help.
Sep 30, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Km 500 kae hoshizaki 3 beeps every 4 second compressor not coming on
put an amp probe on common wire at compressor and see what amps are when it tries to start. 40 to 60 is mechancially locked up compressor. kill power and test start and run capacitors. there is an thermal temp over load on the compressor that opens when comp gets hot from trying to start. gently remove and look for cracks or burned looking. . i saw one this week doing exact same and i have ordered the oem compressor start cap realy and run cap and drier and will put in all new gas. be sure to allow sufficient time when switched to ice for it to get to ref cycle, it may take 5 minutes starting with water purge, then fill, etc. good luck, call hoshizaki dist they are usually pretty helpful if you need a auth service rep in you area. i think they are three years warrantied!
Oct 25, 2008 | Hoshizaki Freezers
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Commercial Freezer KM-500MAH Logo
655 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
