Question about Toshiba Computers & Internet
My Toshiba Satellite p200-1ee does not charge fully. I connect it to the AC adaptor and when it shows charging is complete I then swith of the power and so my lapton also switchs off. Im not sure if its my battery. Please help.
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 30, 2010
I started charging my toshiba satellite M15-S405 laptop with a universal charger, IGO ac power adapter,with a #702 head/tip, that i bought from wal-mart, and its been having a yellow blinking lite in front...
Disconnect the adaptor and remove the battery from your notebook. Then connect the power adaptor and see if it boots up. If it powers up OK now you may have a bad battery. If the notebook still will not power up, the adaptor may not be compatible or there may be a different hardware problem.
Sep 03, 2013 | Toshiba Satellite A75-S226 Notebook
Basically my samsung n145 netbook wont power up unless its connected to the power supply and also i cant disconnect the power supply when fully charged as it cuts the laptop off straight away :( cheers
Replace your battery to solve this trouble.
Get a battery from a FixYa.com advertiser or anywhere computer batteries are sold.
Thanks for your question @ FixYa.com
Jul 28, 2011 | Samsung N145-JP01US Netbook
Hi. I have a Toshiba laptop a205 s5812. The problem is when I start it with AC adaptor connected it wont start. If I start it without connecting the adaptor it works fine, but once on if I connect the...
Although this may only be a temporary solution, try connecting the adapter but taking the battery out. Now try turning on the laptop. It should work. Unfortunately, this means that you will need to always connect the laptop to the wall when you want to use it.
Mar 21, 2011 | Toshiba Satellite A205-S4777 Notebook
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Toshiba Satellite M45-S331 willnot operate on
You have replaced the battery and then it worked.
Try once with power draining (remove the battery and then press the power button for one minute and then again refix the battery) and check.
Thanks
Dec 10, 2009 | Toshiba Satellite M45X-S331 Notebook
I am trying to figure out what the buttons on the underneath of my laptop are for, they show a battery sign and mine only stays charged for an hour?
That battery LED shows up when you are connected to AC power. When the battery is charging, the light is up. However, when it is fully charged, it will change color or disappear or does not light. But I am begging you to not use your laptop always with the AC power so as not to destroy your battery. When you are at home, plug your laptop to charge but dont open it. When it is fully charged, remove the battery and turn it on while the battery is out. It is the safest way to conserve and lengthen the life of your battery. Use only your battery when you are in places where there is no power outlet or when you are on the go.
Regards!
Sep 25, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
Power adaptor connection to Satallite M30 loose
well..that adaptor is in side on the motherboard, which costs around 150.00 to 200 bucks..and two hours of labor, easy for this..
not that far off..
Mar 17, 2008 | Toshiba Satellite M30 Notebook
Computers & Internet Logo
162 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
