Question about Maytag MDB7100AWB Dishwasher
Roller that holds top rack broke, can i get a replacement part with the wheels?
  • Maytag Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 30, 2010
How do I fix the top rack & rail for my dishwasher? The roller broke away from the rack.
Appliance parts stores will have it or can order it for you.
Nov 18, 2014 | Dishwashers
Top roller screw hole stripped
1)make certain all is clean and very dry
2)apply gorilla glue into stripped plastic hole and insert screw.
3)rig something up to keep it from moving for 6 hours or so
careful gorilla has a nasty habbit of pretty much destroying clothes and staining skin so be carefull. don't get carried away when applying it and maybe set down a disposable rag to catch drips.
but it is very permanent. Its what I would do
good luck
Nov 27, 2013 | Frigidaire Dishwashers
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
I can't put back the top dishwasher rack. The railing does not seem to hold it, even though there is no damage in the railing. The top rack could not be held by the rollers
There should be plastic stops at either end of the rail that prevent the rollers of the rack from coming out of either end.
Sep 22, 2009 | Maytag Dishwashers
2 upper rack rollers cracked in Maytag #MDB7600AWS - cant find simple replacement rollers for inside track - 1 1/4" - of upper rack.
JP Weld works great on repairing these junky Maytag parts. Note that they don't have a replacement for these upper wheels and a guy is selling expensive stainless steel replacements. The round connector broke off of ours that holds the wheel to the rack. My wife found a plastic button that fit within the space and we glued it with JP Weld epoxy (water and temperature resistant). 10 washes later, still working great! I expect it will "heal" any other plastic parts. NEVER will I buy a Maytag again!
Sep 11, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
How do you remove the caps from the upper rack glides? I'm replacing the rollers that attach to the upper rack because one is broke.
Caps on the front ends of the glides can be pulled out. Sometimes they are hinged at the top and have a tab at the bottom to pull out. With the caps out or open you can roll the upper rack out of the glides.
Aug 12, 2009 | Dishwashers
Top rack rail contently comming off the rollers. The rollers are wobbly, tried to tighten but will not go any tighter. are there better rollers available? PLD2850RDC2
Typically the roller wheels and the post tabs that hold them onto the sliding rack/guides will wear over time and depending on how heavily your family loads the racks, the sooner you'll need to replace them.
You can order new ones and do the job yourself which is the best solution for the situation you're describing. The only other thing to check is for the rack section that is attached to the inside dishwasher walls to make sure those screws are snug (don't overtighten and strip them out!) other than that, you still will need to replace the rollers on the extendable portion of the rack supports, etc. Hope that helps.
Jul 13, 2009 | GE 24 in. GSD4030Z Built-in Dishwasher
LG DIshwasher
hi Problems with the dish racks usually occur because the racks have been jammed back into the tub housing after they're fully loaded. Careless handling can exert enough force to crack or break the roller wheels or throw the racks off the tracks. The solution is easy: Stop jamming the racks.
The repair is easy, too. Remove the racks by pulling out the tiny metal pins that hold them in the tracks. Or simply lift up on the racks and pull them out of the tracks. Then reinstall the racks on the tracks so that they roll smoothly. If the rollers are cracked or broken, replace them with new ones of the same type. The rollers may be friction-fit to their hubs. Pull them off for replacement. Or, if they are held by tiny spring clips, pull the clips out with pliers, or pry them out with the tip of a screwdriver. If you can't pull the rollers off for replacement, remove and replace the entire rack.
Sep 12, 2008 | LG Dishwashers
The bottom rack of the dishwasher is always coming off the "track" or what passes for one. The wheels seem too small or the rack isn't wide enough Makes it very diificult to push in or pull out.
A noisy wash cycle or water that won't drain are problems that, for the most part, can be handled yourself. We'll discuss how you can pinpoint these water-related problems in the next section.
tha...........
Maytag MDB7100AWB Dishwasher Logo
154 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
