Question about LG 22" FLATRON LCD Monitor
We bought LG w2242s monitor almost 2 years ago and never used it until now. I cant switch it on! Plugged in, fuse in the plug is okay, all the buttons (including switch,menu etc) do not operate. Screen is still black. But sometimes after powercut in the house screen is white.
SOURCE: Computer monitor screen stays black
i have a proplem in my monitor, always it appears as lots of screeching thin line whenever i on my PC, is there any solution to solve this problem? please help me.
Posted on Sep 15, 2008
acdr
  • 1913 Answers
SOURCE: my new 22" monitor won't come on
restrat your computer then press continue F8 key untill u get menu
then go to enable vga mode or safe mode or last known god configuration. set your display resolution in display properties to 1024*768 pixel then try.
Posted on Oct 05, 2008
SOURCE: Black & White lines across my monitor
1.Make sure all the connections are secure.
2.Try attaching the monitor to a different PC if possible, to determine if its the monitor or video card.
3.Your monitor might just be going bad
Posted on Jan 04, 2009
Witchunter
  • 98 Answers
SOURCE: LG W2234S screen just went black
If you plugged power cable, and Power button on monitor is not working, something's wrong with the eletronics. Go for a refund.
Posted on Jan 15, 2009
  • 5 Answers
SOURCE: Resolution 1680 x 1050 is not adjustable
Make sure your video card is capable of supporting that resolution and also make sure your video card drivers are up to date.
Posted on Apr 08, 2009
Hello i have a 19 inch LG M197 WDP monitor/tv, when i switch it on the screen is white with a little gray bock that flashes and slowly moves across the top of the screen reading v3.02.0 which i presume is...
I also had an LG M197WDP tv/Monitor with the same problem. It comes straight on when plugged in, but with the blank screen and scrolling version number across the top.
The solution:
1. Use the remote control (check batteries first)
2. Point at the working TV and press either MENU or EXIT
3. Static should be seen on the screen.
4. Switch to standby using the remote, by preesing POWER button.
5. Switch back on using the POWER button.
All should then be working normally
Jun 20, 2011 | LG M197WD-PZ 18 inch LCD Monitor
I bought a new LG Monitor, W1946S, a couple of days ago. First time I used it after connection it worked fine, since then it is in Power Save Mode when switched on and stays that way. If I press the...
Firstly take it straight back and change it, if its a hardware issue then you want it changed sooner rather than later when it might run out of short term warranty.
Secondly, be sure that the vga/dvi cable is plugged in securely at both ends, it has to recognise the signal from the pc to turn its monitor on and start displaying. But change the monitor and fast!
Jan 07, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
Unable to drive LG W22432S monitors in WindowsXP
Hi there.
Go to the control panel, select display, click on the settings tab and set the display to 1024 x 768 pixels, that should sort the problem out.
Post back if you need more help.
Good luck and thanks for using FixYa!!
May 14, 2009 | Computers & Internet
Apr 07, 2009 | LG 22" Widescreen Flat Panel LCD Monitor
LG Moniter W2242S Not able to set up instelation disk buckled need driver
He's looking for the colour profile. I have one of these monitors. The controls on the device and the menu system are counter-intuitive. The Windows Vista default colour profile is sufficient, and what's on the disk is pretty much useless anyway. Just perservere with the menu on the monitor itself.
Nov 15, 2008 | Computers & Internet
LG 700E monitor gives a blurr vision
open unit, adjust focus pot on flyback, may have 2 focus pots.
do both until satisfied.
If the problem varies with temperature (on time), then you may have a failing flyback.
Oct 02, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor Suddenly Shuts Down
you should download and install the software for your computer model that controls the functions like increasing & decreasing screen brightness, switch between screens etc. Try reinstallimg the OS using the recovery CD ROM that came with your computer
May 17, 2008 | Dell Inspiron 1150 Notebook
Monitor not getting info from computer
Does the computer beep when it starts? Does the monitor work on another pc? Possible culprits with these symptoms are the power supply and video card.
Feb 16, 2008 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
LG 700E COLOUR CHANGES
you have touch up the solder point at the pict board. Because the solder joints dried up - lead poor contact.
Nov 29, 2007 | LG Studioworks 700S 17" CRT Monitor
LG 22" FLATRON LCD Monitor Logo
95 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
