Question about GE Advantium SCA2001BSS Microwave Oven
After replacing the door latch, the fuse is blowing. With a new fuse installed the clock works; however, when the micro/convection oven is turned on, there is an electrical arc around the compasitor in the back of the unit. Thanks for you help.
  • GE Master
  • 43,501 Answers
The capacitor is bad and will need to be replaced,
Please make sure that you know what to do and how before attempting repairs on a microwave...they can be deadly...
Here isa tip that will help you to figure out what is wrong with your MicrowaveOven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 30, 2010
Micro does not turn on without external pressure
Likely the door latch microswitch. My micro/convection oven has 4 of these, and they do go bad. I've had to replace two of the switches in 4 years.
May 16, 2015 | Microwave Ovens
Replaced the 20amp fuse in my microwave. Clock and all lights work but oven will not heat
one or more of the door micro switches are open or shorted..the micro switches tell the unit the door is closed and safe to use.the micro switched are marked normally open or closed..take note when replaceing them..also their is a actuator lever that tells the switch to close or open..it is plastic and connected to the door latch..it can be broken off or bent from heat,,its plastic..make sure its in place and working the micro switch
Aug 15, 2014 | Microwave Ovens
Blows fuse when you open door
Be-safe, Un-plug your microwave oven ,
Open the microwave cover ,
Close and open door few times to check the door latch(es) and switch(es).
Door switch assembly may has one or more micro switches.( Most switches are black or grey and about 1,25 in long X 3/4 in wide X 5/6 in thick with two or three wire connections).
Making sure door latch close and open these micro-switches.
You can hear the switch "clicks" when small switch pin or lever is pressed.
Sometime these door micro-switches pin or lever get stuck or broken.
You can take couple pictures before remove wires or micro switches
You can buy these switches for about 3-7 dollars online. Some web sites have video showing how to check them. (Using Volt-Ohm meter)
Jan 24, 2014 | Magic Chef MCO160UB Microwave Oven
I have a amv6167bds and convection works but no micro
Check the door safety interlock switches ... tiny micro switches found near the latch mech inside the cabinet.
If they are faulty, the oven thinks the door is open and will not turn on the 'heat' in microwave mode.
Thank you for your question @ FixYa.com
Aug 15, 2011 | Amana AMV6167BDS Microwave Oven
Micro blow circuit
You have a faulty interlock switch. This is one of two or three switches in every microwave that are operated by the door. The interlock switch is wired to blow the fuse if you try to run the oven with the door open. The switch may have gotten knocked out of adjustment (say by slamming the oven door) or its contacts stuck closed. If there are no other problems with the oven, a new switch should clear this up.
Mar 24, 2009 | LG LMV1630 Convection/Microwave Oven
Using Convection Oven and lost power Sharp R-7A85
Replace fuse with slo blow from Ace Hardware. Plugged unit in, clock worked. Turned unit on and immediately blew new fuse. Will fix it with a new unit.
Mar 21, 2009 | Sharp R-7A85 Microwave Oven
Sharp microwave convection oven model R-930AK. the interior light stays on all the time and the only thing that I am really able to operate is the clock and enter some commands but can not get any...
You do not say how old this unit is, but if the microcircuitry in the door latch is damaged the oven may be unsafe. Service on microwave ovens is not cost effective. For problems other than replacing the light bulb, I would buy a new oven. The prices have become very reasonable and the newer ovens have great new features. I had a Sharp unit for years. I started having problems and replaced it recently with a 1100 watt larger oven for about 20% of the cost of the first one.
Ray
Nov 11, 2008 | Microwave Ovens
Fuse
The Interlock Monitor Switch is an added
safety check on the Primary and
Secondary Interlock Switches. If the
Primary and Secondary Interlock Switches
allow the oven to operate with the door
open, the Monitor Switch will blow the
fuse.
You can get more information about adjuting the interlock switch from this link
http://136.166.4.200/contents/Microwave/LMVM1935xx/LMVM1935xx_Service_Manual.pdf
sections 7-11 thru 7-12 discuss the door interlock adjustment that will cause the 20A fuse to blow if it isn't set up right. I hope this helps you...
Aug 03, 2008 | LG LMVM1935 Convection/Microwave Oven
My microwave/convection oven blew a fuse. replaced it and the convection works but when I try to use the microwave it blows the fuse again. what needs to be fixed?
Typically, when the fuse blows in the microwave, the high voltage capacitor fails and becomes shorted.
The door switches are also configured in such a way that if tampered with (in this case, failed switch or latch) the fuse will also blow. Check the capacitor first.
If you need further assistance let me know
Regards,
reg501
The FixYa Team
Jun 19, 2008 | Microwave Ovens
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
Open Questions:
See all GE Advantium SCA2001BSS Microwave Oven Questions
GE Advantium SCA2001BSS Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
