Question about InFocus ScreenPlay 4800 Multimedia Projector
The projector will turn on and after a few minutes it turns off.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Either the lamp is bad or one of the fans is failing or failed. The latter will have to be repaired by a technician.
Posted on Oct 12, 2010
4 Suggested Answers
latinmcgyver
  • 208 Answers
SOURCE: Mitsubishi LCD Projector
power overdraw or overheating. theres a fan inside usualy that stops working.
Posted on Oct 10, 2008
Nic61
  • 1073 Answers
SOURCE: loss of picture
Yes, it is the projector.
Take the filter out and vaccum it, take the lamp out and use compressed air to clean the dust away.
Be carefull witt the air thoug! keep it a bit away from the projector when u cleand the dust away, to close and you can make big mamages inside it.
And, remeber to keep the filter as cleas as possible, i clean min every 2,5-3 monthes.
Good luck
Posted on Dec 09, 2008
projdoc
  • 2237 Answers
SOURCE: in few minutes after turn on the projector (Eiki Lc-xnb4m) ..
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Posted on Nov 18, 2009
Why does it turn on and stay on for a few minutes then turn off with the bulb light flashing?
Bulb has gone bad, and will require a new one. Or check all the fans of the projector and make sure all are running accordingly and nothing is hindering them.
Aug 16, 2015 | HP Digital Projector Vp6110 Multimedia...
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
Display turns dark pink for few minutes and goes
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 23, 2013 | Eiki EIP-5000L 5200 ANSI Lumens DLP XGA...
A vertical white strip appears after few minutes.
Hi fabiano did you ever find a solution the vertical line in your RD-JT91 Multimedia OH projector. I now have the same problem. Gary
Oct 02, 2009 | LG RD-JT91 Multimedia Projector
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
My TLP680U projector shuts off after 1o minutes of operation.
toshiba is not one of the most rliable makes im afraidi have seen this fault before and it turned out to be the bulb which i had recentley replaced and this was apparentley the wrong one and gave the same sort of results.
Feb 25, 2009 | Toshiba TLP 680 Multimedia Projector
Loss of picture
Good luck
Dec 06, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Projector stays on for 3 minutes then turns itself off
Hi Chipped Rice
The loud buzzing noise you heard was the colourwheel that gave in.
Now what happens is , the machine will turn on and go through the whole cycle and as soon as the colourwheel is supposed to start doing it's stuff the Projector will switch off because there is no response from the coulourwheel itself.
You will have to replace the colourwheel unfortunately as it cannot be fixed.
Thanks for using Fixya !
May 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4800 Multimedia Projector Logo
61 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
