Question about Denon AVR-1905 Receiver
POWER OFF/ SHUTDOWN
System turns on then the display says poweroff , this takes about 4 secs then the system shuts down,,, When turning on the power the system searches for the setting and immediatly shuts off
  • humph1964 Jul 03, 2008
    my denon AVR 1905 also when powering on says AV surround reciever then powers down with the power button flashing red.Ive checked all terminals,none are touching and i,ve even unplugged everything and its still the same.I,ve used this amp practically every day for 3years or so with no probs.The only thing i do differently over the last few months is switch it off from standby on the main plug
  • hopalongis Jul 07, 2008
    I also have a denon AVR-1905 with the same problem. All the lights come on it clicks two times then it shuts down. I have tried everything I even took it to local shop and they said the power board would have to be replaced but said it would cost more for the board then for a new receiver. Before leaving the tech wispered that they really didn't know what was wrong thats just the answer they give when they have no answer.
    Sergeant:
    Champion:
  • 271 Answers
Hi,,,thanks for your good response...Understnding a 7.i surround system through chat is difficult...that ws why i couldnt get it right...if i was there at your place i would have solve that it in seconds...anyway you got it done by yourself thats what we wanted...thanks again
Posted on May 26, 2008
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
Sl400 screen gone black. not able to shut it down. but i guess the system is working because i hear sounds.
Hi. Press the power buttong for 10 secs inorder for the system to shutdown. Take out the battery and unplugged the power adapter. Preass and hold the power button for 30 secs then put everything back in. Turn On the computer.
Oct 13, 2010 | Lenovo ThinkPad SL500 Notebook
Sl400 screen gone black.not able to shut it down. but i guess the system is working as i can hear sounds when i click.
Oct 13, 2010 | Lenovo ThinkPad SL400 Notebook
System shuts down automatically
Remove the battery and adapter. Press power button for 30 sec. Then connect the adapter. Press power button. When pc started, go to
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Apr 12, 2010 | Lenovo 3000 Y410 Laptop
VSX-D457 Display's power off and then shutdown
Most likely it needs one of the output ICs. But check for cold solder rings on the ground connections of the input board. Est. for it to be repaired $100-$120
Dec 17, 2009 | Pioneer VSX-D457 Receiver
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
My computer shuts down after 3 secs
Try to separate the power cord of your monitor from your system or maybe if your using UPS(uninterrupted power supply) directly plug the UPS to the wall outlet. either you can use pretty voltage regulator to the regulate the AC power.
if not solve the problem try to examine the your system power supply.
Dec 11, 2007 | Computers & Internet
POWER OFF/ SHUTDOWN
I found the solution for me! I had the problem where after 1-5 seconds, my receiver would simply shut down. Twice now I've solved it.
The problem is most likely that you have speaker wire that is touching the opposite terminal or coming close to doing so. Check all your speaker wire terminals and make sure that they are not touching at all or coming close.
Also, make sure that your speaker wires are truly in speakers. If you have speakers plugged into the back of your receiver and then sitting out on the other end, that could be the problem as well.
I hope that helps - it solved it for me!
Nov 12, 2007 | Audio Players & Recorders
Auto power off problem
you have either got the power and reset connectors the wrong way round fro the front panel, or you have not enabled ACPI in the advanced cmos settings to allow the board to support shutdown by Windows. Also check in the power options in control panel and ensure that when you click turn off the pc is instructed to power down.
Sep 20, 2007 | EliteGroup P4M800PRO-M Motherboard
Denon AVR-1905 Receiver Logo
291 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
