Question about Acer AL1714 17" LCD Monitor
Hi, My monitor (AL1714) is fine for about 5 minutes and then it goes black. The green light remains on. If I unplug the power cord, and replug it in, it sometimes returns to normal, depending on how long I leave it unplugged (at least a minute or two). The power supply is 18.9VDC off load and appears to be OK. Is this an obvious problem that I could attempt? I have some tools but no spare parts.
  • 4 more comments
  • Robofix Sep 30, 2010
    I will let you know what I find when I open the monitor - not today. I am assuming I can access the board fairly easily. Are there any tricks to getting in?
    Rob
  • Robofix Oct 01, 2010
    The reply I received was vague in that it covered many parts of the monitor. How could it bee the display itself if it gives a normal picture for at least several minutes?
  • Robofix Oct 03, 2010
    I loosened the 4 screws to start looking inside the monitor while I was waiting for it to turn black and lo and behold, it did not turn black. I left it on for several hours and it stayed working!!!
    (not sure if you already got this comment). I guess I will keep my fingers crossed.
    Thanks for the detailed information. However, I loosened the 4 screws to start looking inside the monitor (while I was waiting for it to turn black) and lo and behold, it did not turn black. I left it on for several hours and it stayed working!!! It may be a cold solder joint or something is expanding and touching something else. I will check the Inverter board as you suggested. I know what to look for and I might try a "cold spray" to see if a component heating up is the cause. I will let you know what I find eventually.
    Rob
    President:
  • 4,070 Answers
Hi! Looks like the monitor is in stressed and can't stand long time use. Replacing these parts plus labor is like buying a new one for it will take time and the availability of the parts. I strongly suggest that you buy a new one which can cost you less. HOpe this helps and thank you for using FIxYa!
Posted on Sep 30, 2010
  • Acer Master
  • 4,737 Answers
It must be the Inverter Board defect. If you know how to check the capacitors and the coil, you can try replacing them or refresh (solder) them. Open the monitor case and power on the monitor, now listen whether you hear tick tick sound or not, if you hear tick sound, then it's the "transformer" (small transformer), I would recommend replacing the whole inverter unit. If you can find the similar transformer, you can give a try, but it's better to replace the whole board than replacing the transformer as it'll cost only a little less than the whole board.
Check all the capacitors and replace them with the correct unit (micro farad). You can simply identify the defective capacitors when you look, it might have bulged out or it might have exploded.
The board should look similar to the above (this is for AL1916WA).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 02, 2010
  • Lebanon Raingam
    Lebanon Raingam Oct 03, 2010
    Good luck..
  • Lebanon Raingam
    Oh.. sorry, you've posted several comments. I just got the last one. Anyway, it's good to hear that it's working somehow. Once again I wish you best of luck.
    President:
  • 2,777 Answers
It is the main logic board of the monitor itself, or worse yet the actual display. It is tough to say for sure, but the repair is going to be very costly, you can get a new 17 inch monitor for less than $100.... you are going to want to replace this monitor in my opinion, it is not worth the repair. You can take it apart and look for obvious damage such as blown capacitors... But my bet is you won't find anything.
Let me know
Tim
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
No picture on monitor (monitor turns itself off)
You will need to take it for repairs.
Sorry
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Dell E773C 17" CRT Monitor
My Acer AL1714 monitor was given to me, the person that gave it to me said last time the last time it was connected it work but the monitor had been stored for about 2 years. So I bought a 19V-2.3A power...
mccampbell71 Probably a failure of inverter circuit(dc to ac 600-1100vac) to light-up (sustain) "cold-cathode-fluorescent lamps" causing the "switch-mode-power-supply" to go into full or partial SHUTDOWN mode. Black Screen of Death strikes again!!! The Question I have is why did you BUY a "black-brick" supply? Did the other one fall out of the car or get run over by a train? Only you will be able to make the decision of to REPAIR or Trade-in for new. You are no different than 5000 others worldwide (all brands) who have monitor's with BSOD! Yes, some (75-90%) can be saved to work 1-3 more years! Read some of my other responses in my profiles (12fixlouie aka louie12fix) to learn of the options you have open to you. Bye for now 12fixlouie If this info was of some use please rate on fixya.
Nov 13, 2009 | Acer AL1714 17" LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Power cord
This one should do the trick.
http://insidecomputer.stores.yahoo.net/ac-adapter-for-acer-al1714-al1714b19volt-l1714171419.html
Feb 09, 2009 | Computers & Internet
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Acer al1714
The problem may not be the monitor. Acer AL1714 is known for its weak power supply unit. Unplug power supply from monitor. If the green light on monitor comes on but goes out quickly, the power supply is the culprit!
Dec 28, 2007 | Acer AL1714 17" LCD Monitor
LCD screen goes black repeatedly
Have you checked the light on your power supply? My monitor will go black and I noticed the light on my AC power supply was off. It was very hot so I unplugged it and let it cool down. When I plugged it back in my monitor worked fine until the power supply started to over heat again.
Oct 25, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Acer AL1714 17" LCD Monitor Logo
214 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
