Question about Bosch 24 in. SHU43 Built-in Dishwasher
Light appears stating to refill rinse agent - Bosch 24 in. SHU43 Built-in Dishwasher
    President:
  • 2,501 Answers
There is a rinse aid dispenser on the door.
Buy some from your local supermarket, open the dispenser and fill it. Close the lid and the light should disappear.
Posted on Sep 30, 2010
Refill the rinse agent with what?
I use Jet Dry, a rinse agent. It helps prevent water spots on your dishes.
Jul 04, 2015 | Bosch Dishwashers
Rinse agent (blue liquid) is leaking into the bottom of the dishwasher compartment. Every time I refill, it leaks out within a few days. Any idea what is causing this?
There is a lot of info missing like brand and model, but it a general way they all work the same. A preset amount is dispensed in the last rinse cycle by an electric circuit. Sense this appears to leak the entire amount the valve/ opening is not shutting. A repairman would just replace the rinse aid dispenser assembly. They are hard to clean because the are a molded/sealed assembly.
Dec 29, 2014 | Dishwashers
"add rinse agent" indicator light will not reset?
Switch the unit from mains to reset and try again
Jul 25, 2014 | Bosch Dishwashers
I accidently put Jet Dry DISHWASHER CLEANER in my rinse agent dispenser and I need to know how to drain it out..help!
if you leave loading draw or lid open and do a hot wash with no detergent water will enter replacing the detergent you will have to do this several times till wash tub runs with clear water then refill with rinse agent.
Feb 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
What is the rinse indicator clear knob inside door
That is the compartment for a liquid rinsing agent (Jet Dry). If you use it you can see if the compartment needs to be refilled by looking through the knob. Rinsing agent is supposed to keep glassware from having water spots but is not always necessary.
Jan 17, 2010 | Dishwashers
The rinse agent light is on and the water will not spray out
NO WILL STILL WORK IS ONLY A FLOAT SWITCH TO WARN YOU,HOWEVER RINSE AGENT DOES AID THE DRYING PROCESS SO WITHOUT YOURE DISHES WILL BE WET AND SMEARY
Sep 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Where do I add my rinse agent???
I have the same dishwasher, KUDS01FLSS. All you need to do is pour the rinse agent (We use Jet Dry) directly into that circle like plug with the line through it that you mentioned above. It acts like a funnel.
Pour the rinse agent in slowly as it takes time to drain into the dispenser. Just watch the little sight glass to the right of the rinse agent fill funnel. It will begin to darken (or turn blue if you use Jet Dry) as the dispenser starts to get full. I just pour it in slowly and when the rinse agent does not flow down the funnel any longer, it is full. Be sure to wipe up any spills or excess rinse agent. Hope this helps you.
Good Luck,
Tom
Jan 08, 2009 | KitchenAid 24 in. KUDS01FLSS Built-In...
Kenmore Ultra Wash rinse agent not draining
I used to think the same in my dishwasher, but come to find out it actually lasts for a few months so it only uses drops at a time..
Mar 03, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Refill rinse agent
Rinse aid is important for wash performance. open door where the dial is should be hole there it be. fill slowly most take up-to 85-125ml from empty..insure to wipe up any spillage also jiggle door as they can air lock while filling
Dec 22, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
570 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
