Question about GE Energy Star WCVH6260F Front Load Washer
Have ge frontload wcvh6260 had excessive vibration replaced dampers which was need old ones not working still have excessive vibration not as bad but still excessive
  • frankw142 Sep 30, 2010
    springs are attached and brackets are secure
    new dampers , brackets are tight, springs are attached concrete floor machine was leveled with bubble level left to right and front to back
    President:
  • 1,554 Answers
Check the chassis at the of base of the machine where the dampers attach to. Make sure they are tightly fastened to the base. Next to check are the suspension springs at the sides of the cabinet. Make sure they are attached to the outer tub and the sides of the cabinet.
Posted on Sep 30, 2010
  • Jahn27
    Jahn27 Sep 30, 2010
    Check the leveling of the machine including the leveling feet. Reinforce the floor it is not sturdy.
    Please provide clearer and more information describing the problem.
  • Jahn27
    Jahn27 Sep 30, 2010
    Is there any unusual noise coming from the machine when it's spinning? I'm suspecting a rear tub bearing or a spinner support issue. No more reason for the machine to vibrate except the bearing or the spinner support.
Excessive vibration on my Dyna
17 years is a long time for engine rubbers on a v twin. But if the vibration is only in the handlebars, you might want to fit some heavier handlebar end weights. They are there to absorb vibration(they act as dampers.) But, if the vibration is in the engine, it may be worth checking the ignition timing. On a Big V the ignition only needs to be out by a small amount to set up a noticeable vibration.
May 05, 2013 | Harley Davidson FXD Dyna Super Glide...
What happens if you drive with bad damper pully
This will cause excessive vibration, ruin the belt/s, and could walk off and destroy the openning at the crankshaft requiring the crank shaft to be replaced or repaired. Expensive to do so.
Feb 01, 2012 | 1995 Buick LeSabre
I have a Maytag LA 211 washer and during the spin cycle it vibrates excessively. I tested the spin cycle without clothes and water and it still vibrates excessively. how can this problem be fixed? Ron
To fix this problem you will need to replace the damper pads, this will require several hours of your time, you can read several articles on how to complete this repair yourself at the link below, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Washing Machines
Crankshafts pulley is shaking
Hi, your vibration damper is coming unglued. You will have to replace it. You will need to borrow a puller to get the old one off. You will also need a way to hold the engine from turning in order to loosen the bolt. If you have a manual transmission, put it in a high gear and set the brake. If you have an automatic, you may need to remove the starter and jam the flexplate teeth with a screwdriver. Please let me know if you have questions, and thanks for using FixYa.
Feb 13, 2011 | 2002 Mitsubishi Lancer
GE model 25 - 6 years old - Top part of fridge and freezer not cooling. compressor seems to be working fine. Bottom part of freezer is very cold and bottom part of fridge is freezing everything. Appears to...
It sounds like the damper assembly might have failed or be stuck open. The damper is mounted in the left side upper rear corner of the refrigerator section. The damper controls the amount of cold air that comes into the refrigerator section from the freezer.
If you want to repair the refrigerator yourself you should disconnect the power to the refrigerator and remove the 2 screws holding the damper cover to the center wall. Sometimes you can spray the damper with WD40 and free it up.
Jan 30, 2011 | GE Profile PSW26P Stainless Steel Side by...
I have a wpxh214a ge washing machine.approximately 5 yrs old.suddenly vibrating like crazy.took off front lower panel noticed broken left damper(at the foot where plastic bolt goes through damper.Oddly at...
The machine shut down bwcause of the vibration and if you unplug it it will reset...
but you need to get those shcks changed... they are not that hard to cchange and change both sides right of way...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 28, 2010 | GE WPXH214A Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Excessive noise/vibration
Vibration problem occurs on dryer/washers because of bad dampers generally. When drum is loaded, the load is distributed randomly, so its create vibration when drum spin in certain revolution. The dampers are supposed to take this vibration and minimize them.
There are more possibilities like drum dislocation or bended drum etc.
Jun 28, 2009 | Kenmore 73932 Gas Dryer
Miele W828 Frontloader vibrating more.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Washing Machines
GE Energy Star WCVH6260F Front Load Washer Logo
184 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
