Question about Kodak EasyShare C613 Digital Camera
I tried turning on my camera the lens doesn't come all the way out and there is a lens error on the screen 115,0,0,214
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
5 Suggested Answers
  • 3 Answers
SOURCE: lens error 122.1.0.0
My friend had the same issue, and so did I. Maybe this would only do worse to yours, but it actually fixed my issue. When you turn the camera off, the lense should start to tuck in right? Maybe try giving a little push to help it out.
Posted on Jun 22, 2008
leethedeuce
  • 4472 Answers
SOURCE: Dropped camera in sand...
Your best bet is to just open it up and try and blow the sand out but you will want to be very careful.
Hope this helps.
Thanks,
Lee
Posted on Jul 15, 2008
lock123
  • 6831 Answers
SOURCE: When I turn on my Kodak C633 won't turn on.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: I keep getting various lens
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Posted on Aug 24, 2011
The camera was dropped while it was on. The lens is stuck in the open position. When the camera is first started it sounds like tiny gears spinning but not catching. It doesn't really grind or...
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon SD cameras:http://www../Device/Canon_Powershot_SD880 or
http://www..Guide/Disassembling-Canon-PowerShot-SD800-IS-Lens-Assembly/4093/1
Also you may try this Canon "Lens Error" troubleshooting guide >>http://camerarepair.../fixing-lens-error-on-digital-camera
6.To download the complete service manual for a similar camera model can be downloaded at the link below:
http://www../canon_powershot_digital_elph_digital_ixus.pdf/download.html
Wait 10 sec and click Get Manual .At the bottom of the page.
10_8_2011_7_21_11_pm.jpgCanon SD990 IS digital camera lens with ccd parts can be purchased from eBay >>PARTS-REPAIR-/140607486728#ht_483wt_1642
Oct 08, 2011 | Canon PowerShot SD990 IS / Digital IXUS...
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
TURNING ON CAMERA ZOOM LENS DOES NOT COME OUT AND SCREEN SAYS 'TURN OFF THE CAMERA AND TURN ON AGAIN' WHEN THIS HAS BEEN DONE NOTHING CHANGES. COVERS DO NOT COVER LENS COMPLETELY AND ZOOM...
Here are some troubleshooting steps that you can try that may correct the problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 04, 2011 | Cameras
Lens stuck out and won't turn on. When I try to turn it on it flashes a red light but it doesn't turn on.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 01, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Lens Error on L18
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 23, 2009 | Nikon COOLPIX L18 Digital Camera
A210 zoom error
When you first turn the camera on, grab the lens, pull on it slightly. Turn the camera off and try it again. If it doesn"t work the first time , pull on the lens slightly again. It worked on mine
Dec 23, 2007 | Fuji FinePix A205 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
19 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
