Question about Haier HSB03 Compact Refrigerator
Refrigerator too cold, everything freezing in the frige section . thermostate turned down about as low as it will go
  • Haier Master
  • 1,711 Answers
Replace the thermostat they become stuck after long time use.
Posted on Oct 01, 2010
The freezer section of our Danby DFF8200W freezes well. However, periodically the refrigerator section freezes everything in it with the temp control turned as low as it will turn for me. The dial does not...
Make sure you clean the backside of refrigerator at bottom from dust. Make sure you have the recommended clearance from wall. Also make sure the food in freezer and frige have clearance to allow air to circulate around food. Keep playing with your controlls...The dails might be on wrong
Aug 11, 2013 | Danby Refrigerators
Not turning off and on frezzing everything in frige
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 01, 2011 | GE Refrigerators
Will a burned out defrost heater cause the refrigerator section of the side-by-side Frigidaire to stop cooling? I have relpaced both the thermostate and the defrost control. Frige still not...
Good day,
Only if there is a build up of frost on the evaporator coil behind the rear panel in the freezer section.
I don't know what thermostat your describing, but the one controlling the defrost system is mounted on top of the evaporator coil. it looks somewhat like this.
It must work. It can be tested with an ohm meter as long as it is cold. It should read zero ohms. As well the main heater can be tested with a meter. It should read 35 ohms or less. If either one tests bad, replace.
Once again, this approach is only for a situation where the evaporator coil is iced up. If not......
Other causes could be the fan motor not running. It is in the same area.
Lastly, there is a motorized damper located in the top left side of the fresh food compartment. It should be throttled open to allow cold air into the food compartment from the freezer.
May 06, 2010 | Frigidaire FRS3R5EMB Side by Side...
Model TBX18KMB. Liquids on top shelf often freeze. Also,need to cut electric bills,can Power Saver help?
Turn the refrigerator temp control down try factory setting, usually c on frige and 3 on freezer control. The cold air circulating from the freezer enters at the top of the frige therefor it is usually colder.
Nov 04, 2009 | GE Refrigerators
Why does my ge fridge run too cold?
Sir,
You are suggested to try lowing down the Thermostate of you Refrigerator.
Oct 21, 2009 | Refrigerators
Frige not cooling, freezer is fine
its the problem of defrost timer.due to this the cold air from freezer section is not getting in to refrigerator section and its getting warm.check out the defrost timer.located beside the compressor at the back lower side of the unit.the cost of new defrost timer is near to $40.and you can get it from
www.repairclinic.com
thanks.
Jul 14, 2009 | Jenn-Air JFC2089HE French Door...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
I have a Dometic RV frige that freezes everything in the frige section even when i have it set on the lowest temp setting
thanks for the question sounds like a defective cold control replace it thanks the appliance doc
Sep 16, 2008 | Refrigerators
Magic chef gas/electric rv fridge freezer gets cold but fridge dosn't
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Jul 15, 2008 | Magic Chef Refrigerators
Side by side freezer
Check that the freezer circulating fan is running. The frige section may have dampers or vents (lets the freezer air cool the refer section) that are open too much. Usually the bottom area in the frige has a control lever to meter how much cold air gets to that section (lots for meat, little for fruits, etc.). Check the owners manual for operation of those vent dampers.
Oct 22, 2006 | Maytag 60ADiW Side by Side Refrigerator
Haier HSB03 Compact Refrigerator Logo
994 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
