System pressure to high - Heating & Cooling
  • 43,501 Answers
Either the condenser coils are dirty or the system is overcharged...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 30, 2010
Holden Cruze Diesel low fuel pressure. High pressure pump replaced. Low pressure pump working fine Very little fuel coming out of high pressure pump outlet
!st of all unless you have the experience and the correct tools do not play with the high pressure side of the fuel system. The pressure that is created on the high side is such that will cause serious damage or fatility "Seriously". The system needs to be sealed for the pressure to occure if air is in system" no" presssure.
If lift pump is working(can you hear it?) Is it exiting fuel filter and arriving at inlet of high presure pump at correct pressure. (if not replace filter Use Genuine part. If still no good lift pump or power and earth suspect check. Any engine check lights on? if so use a code reader.(im assuming no light as you haven't mentioned it). If all is good to high pressure pump then you are looking from pump onward. Is this an issue that has just occured or have you purchased vehicle in this condition. Any unusal noises The high pressure pump is driven by camshaft is it actually turning the pump I have come across fractured cams or drives. if ok advise holden to check from here on there may be an electrical issue or injection issue possibly allowing air in system or shutting the pump down. You can check the whole sytem for visible leaks and vacuume connections. good luck.
Mar 03, 2017 | Holden Cars & Trucks
Ac pressures
134a System Pressure Chart AC Pro according to this chart your compressor is faulty your low pressure line is high and your high pressure line is low
Aug 05, 2014 | 2005 Volvo XC90
I changed the ac compressor and dryer pumped it down and charged the system the compressor comes on for 3 seconds and cuts off. The clutch does not stay in gage. What could be the problem now?
Sounds like it's shutting off due to high pressures in the system. Do you have gauges to read the system pressures? One thing that would cause this is too much freon in the system, or too much oil. Did the compressor come with oil in it or did you add oil to the system? Too much oil and/or freon will give high pressures and the high pressure switch will shut the system off. Or the high pressure switch could be damaged, maybe even unplugged is a possibility. If it is plugged in you could try unplugging it and seeing if the compressor keeps running for longer than 3 seconds, if it does pressures might be too high. It could also be a bad relay getting hot and kicking off. Try switching relays and see what happens. Another possibility is the low pressure switch but not too likely in this case.
When the compressor shuts off, can you turn it by hand? If not, high pressures or even a bad compressor are possible.
Lot's of possibilities. Just have to wade through them. I'd start with the relay and then check the pressures.
Good luck.
Jun 21, 2014 | Cars & Trucks
Condenser fan not engaging
Possibly low on refrigerant. When system is low on freon, it does not build up enough high side pressure to engage the condenser fan . When pressure is high enough. a high side pressure switch kicks on the cond. fan to maintain high side pressure. Have the system evacuated and recharged to proper level.
Feb 01, 2014 | 1996 Mercedes-Benz C-Class
Condenser fan not engaging when A/C turned on. All fuses and relays look fine. Tested fan with eternal power and it runs.
Possibly low on refrigerant. When system is low on freon, it does not build up enough high side pressure to engage the condenser fan . When pressure is high enough. a high side pressure switch kicks on the cond. fan to maintain high side pressure. Have the system evacuated and recharged to proper level. A system dye can be added to check for any possible leaks.
Feb 01, 2014 | 2004 Isuzu Rodeo
High Pressure Switch replacement
typically your high pressure switch should be located on discharge line in order to replace it if you do not have isolation valves. you will need to recover refrigerant pull vacuum on system then replace high pressure switch. recharge system
Mar 07, 2013 | Heating & Cooling
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
Temp off air coming out of register 74 degrees suction line temp is 42 degrees but high side line isnt warm dont look like it is wanting to take freon either compressor is running new system low side is...
Hello, what is your high side pressure? A bad compressor will show abnormally high low side pressure with abnormally low high side pressure. That 45 low side pressure is low And superheat high. If you high side pressure is normal toma little above normal but the low side remains low you have a restriction in the system, that might be why it's not taking in tne freon. Let me know you high side pressure
May 11, 2011 | Goodman Heating & Cooling
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Curious to know about high pressure switches
High pressure switch use to detect the high pressure in the system. It is use to protect the unit from high pressure during operation.
Aug 16, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
