Question about Sony VAIO VGN-SZ430N/B Notebook
After installing the windows 7 ,screen looks like 10",it does not cover the whole 13" screen
I want to change the password on my Acer aspire with windows 10
try this may be it works work for windows 10
1. put windows 7 bootable dvd on your dvd rom
2. when you see the install windows screen type "SHIFT" + "F10"
3. now you can see the Command prompt (CMD) and type the following command
regedit.exe
Press "enter" key
4. now you get register edit window, after select File and click import
5. now you can see import registry file window
6. click computer and open c: drive on your registry file window
7. now open windows > system32 folder
8. change to " *.reg " to " all files "
9. now find and rename "sethc" file in to "sethc1"
10. now copy and paste the "cmd" file and you get "cmd copy"
11. rename "cmd copy" in to "sethc"
12. and close all open file and restart your computer
13. now after boot the windows you get password screen
14. after press " Shift " key continuously
15. now you can see CMD screen (dos screen) and type following command
net user
press enter key
now you can see user account on your pc (find out which account you need to reset password and type following commands
net user youraccountname 0
16. net user is dos command
youraccountbane is username
0 is (zero) new password
17. now closed CMD screen (DOS screen)
18. type 0 on you password box and enter
Dec 08, 2016 | Acer Computers & Internet
Windows 7 Update
Follow this article
System Update Readiness Tool fixes Windows Update errors in Windows 8, Windows 7, Windows Vista, Windows Server 2008 R2, and Windows Server 2008 http://support.microsoft.com/kb/947821
Jan 13, 2013 | Lenovo Computers & Internet
Ga with indows 7 32 bit
Here is the solution. When you install windows 7 it will automatically configure the VGA driver adapter (totally useless) ATI does not have a driver to support windows 7 on this display adapter; but here is a trick that will get you up and running again.
1. open the control panel
2.click on appearance and personalization
3. click on display
4. Click on screen resolution
5 click on the advanced settings tab
6. click on the adapter tab
7. Click on properties
8. click on drivers tab
9 . click update driver
10. Click search automatically
11. Windows 7 will find and install a driver for your ATI mobility
xpress 200
12. restart computer when prompted
13. You're back in business
14. Good Job.
Jun 12, 2012 | Intel D102GGC2 Motherboard
I have Musicmatch Jukebox 10 but have just changed over to Windows 7.I have a Packard Bell Hard Drive.How do I update from xp please ?
Musicmatch Jukebox 10 is not compatible with windows 7 >>
http://www.microsoft.com/windows/compatibility/windows-7/
MusicMatch Jukebox 10 was designed to be used on older 32-bit operating systems like Windows XP.Note that MusicMatch Jukebox 10 is also no longer being developed, so it is unlikely that these problems will be resolved in future.
Before proceeding with installation of Musicmatch Jukebox 10, you need to look on your Windows 7 PC for any previous versions of Musicmatch Jukebox. If you've already tried installing version 8, for example, then you need to run a complete uninstall, not to mention a good clean up of the registry.Use Revo uninstaller to uninstall and clean any registry trash ,revo uninstaller can be downloaded on the link below:
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Once you have done this, or if you had no earlier versions of Musicmatch Jukebox installed, you will need to download and install the only suitable version.Download and Install Musicmatch Jukebox 10 on Windows 7 >>http://musicmatch-jukebox.com/
Once downloaded, right-click the installer file and select Run as Administrator. Next, you will need to OK the first of many warnings that the file is incompatible with this version of Windows.Proceed through the installer, clicking Next at each option.When you come to the registration page, click the option to not register and also claim to be under 13. Click Next to complete more steps of the installation, changing the location required for your Music folder if necessary. Musicmatch Jukebox 10 will add files and playlists to this location.As the installer finishes, you will be prompted to install the Yahoo! toolbar. You will need to deselect this.A successful installation should result in more incompatibility warnings. Ignore these, but agree to reboot your PC. Next right click Musicmatch Jukebox icon and select properties > compatibility >check run this program in compatibility mode for: (Windows XP) click apply ->ok.
Nov 13, 2011 | Audio Players & Recorders
I have an acer extensa 4420. Recently I reformatted my laptop to Windows 7 Ultimate. Everything went smoothly, it works well, wireless and functionality is perfect. I have one issue, The screen resolution...
Hello Jonnyboy, looks like you are one of the Windows 7 driver problems, you may need to wait for the driver. the display should go to as much as 1280 x 800, try removing the VGA driver and use the standard windows driver.
Feb 14, 2011 | Acer Extensa 4220, 4420, 4620, 4620Z, 4630...
Looking for timing mark's for a 1997 camry with a 2.2 4cyl motor?
You find the timing marks on the picture below.
Removal
Remove auxiliary 1. drive belts.
2. Support engine.
Remove:
Engine mounting and bracket.
Timing belt upper cover [1].
3.
4. Turn crankshaft clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Remove:
Crankshaft pulley bolt [4].
Crankshaft pulley [5]. Use tool No.09213-60017.
5.
6. Ensure timing marks aligned [2] & [3].
7. Slacken tensioner bolt [6]. Move tensioner away from belt and lightly tighten bolt.
Remove:
Timing belt lower cover [7].
Crankshaft sprocket guide washer [9].
Timing belt.
Tensioner pulley.
Installation
Installation
1. Check tensioner pulley for smooth operation.
2. Check free length of tensioner spring is 46,0 mm [8]. Replace spring if necessary.
3. Fit tensioner and spring. Ensure spring is connected correctly.
4. tighten bolt [6].
5. Ensure timing marks aligned [2] & [3].
6. Fit timing belt. Ensure belt is taut between sprockets.
Install:
7.
8. Slacken tensioner bolt 1/2 turn [6].
9. Turn crankshaft two turns clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Turn crankshaft slowly 1 7/8 turns clockwise until crankshaft pulley timing mark [3] aligned with 45° BTDC mark [10] on
timing belt lower cover [7].
10.
11. Tighten tensioner bolt [6]. Tightening torque: 42 Nm.
12. Install components in reverse order of removal.
13. Tighten crankshaft pulley bolt [4]. Tightening torque: 108 Nm.
Manufacturer: Toyota
Jun 25, 2010 | 1997 Toyota Camry
I upgraded my computer and reinstalled Mathcad 13 on my new computer. The installation wizard said the installation was successful but I can't get it to run. The new computer has Windows 7 operating...
My guess is that the engineers at PTC haven't figured out how make their products compatible with Windows 7! I painfully found that MathCad 14, 13, 11 do not work on Windows 7 (I have Windows 7 Pro)! They install, but the application can't even start! However, MathCad 2000 does work on this outstanding platform; I was amazed! You could use that version in the meantime, hoping that PTC will solve this problem soon! Or install Mathcad 14 on the virtual PC that works in XP mode.
Dec 07, 2009 | Mathsoft Mathcad 13 Full Version for PC
REPLACING HEATER CORE
HEATER CORE REPLACEMENT REMOVAL PROCEDURE 1. Remove the fuel injector sight shield. 2. Drain the cooling system. Refer to Draining and Filling Cooling System in Cooling System. 3. Use J 38185 in order to position aside the heater hose inlet and outlet clamps at the heater core. 4. Disconnect the inlet and outlet heater hose from the heater core. 5. Remove the RH Instrument Panel Closeout/Insulator panel. 6. Remove the LH Instrument Panel Closeout/Insulator panel 7. Remove the floor carpet. 8. Remove the rear floor air outlet duct from the holes in the floor reinforcement. 9. Disconnect the rear floor air outlet duct from the heater air outlet cover. 10. Remove the rear floor air outlet duct. 11. Remove the heater air outlet cover screws . 12. Remove the heater air outlet cover heat stakes with a small chisel. 13. Remove the heater air outlet cover from the HVAC module assembly. 14. Remove the heater core cover screws . 15. Remove the heater core cover heat stakes with a small chisel. 16. Remove the heater core cover from the HVAC module assembly. 17. Remove the heater core from the HVAC module assembly. 18. Remove the heater core foam seal (1) from the HVAC module assembly.
INSTALLATION PROCEDURE 1. Install a new heater core foam seal to the HVAC module assembly. 2. Install the heater core to the HVAC module assembly. 3. From the inside of the heater core cover, drill the dimples adjacent to the heat stakes using a 5.5 mm (7/32 in) drill bit. 4. Install the heater core cover to the HVAC module assembly. NOTE: Refer to Fastener Notice in Service Precautions. 5. Install the heater core cover screws . Tighten Tighten all screws to 1.5 N.m (13 lb in) . 6. From the inside of the heater air outlet cover, drill the dimples adjacent to the heat stakes using a 5.5 mm (7/32 in) drill bit. 7. Install the heater air outlet cover. 8. Install the heater air outlet cover screws (2). Tighten Tighten the screws to 1.5 N.m (13 lb in) . 9. Connect the rear floor air outlet duct to the heater air outlet cover. 10. Install the rear floor air outlet duct to the holes in the floor reinforcement. 11. Install the floor carpet. 12. Install the RH Instrument Panel Closeout/Insulator panel. 13. Install the LH Instrument Panel Closeout/Insulator panel. 14. Connect the inlet and outlet heater hose to the heater core. 15. Use J 38185 in order to reposition the heater hose inlet and outlet clamps to the heater core. 16. Install the fuel injector sight shield. 17. Fill the cooling system.
Nov 13, 2009 | 2003 Chevrolet Monte Carlo
I have a compaq presario 2100 laptop with a 15" screen but after putting a new harddrive and installing windows xp which thats the windows it originally had but the screen is only about a 13" screen that...
Please reinstall your display driver. Windows is unable to correctly identify your display dimensions. Once you install your display driver, you screen should be normal.
Nov 11, 2009 | Compaq Presario 2100U Notebook
My search results return a blank white page.
If you are running with Window XP then please see this and follow the instruction given by me:
Use IE 6.0 instead of IE 7.0
or use a new Web Browser such as Firefox or Google chrome, see this Tip posted by Me:
Google Chrome for All XP or Vista user
Let me know in either case if you have any issue remaining, dont vote till you get the solution.
Scott
Nov 21, 2008 | Microsoft Internet Explorer 7
Sony VAIO VGN-SZ430N/B Notebook Logo
121 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
