Question about Intel Motherboard
I have a gigabyte GA-946GMX-S2,motherboard and i'm getting continuesly beep
AUTOSOUNDINS
  • 232 Answers
SOURCE: how to connect tv out from the gigabyte motherboard GA-MA69VM-S2
making the plug will probably be impossible with your resources, like u said its an option and the software and video drivers might not be installed for the function to work. u must install a tv tuner to receive the signal before u can av out
Posted on Aug 05, 2008
DRSS
  • 81 Answers
SOURCE: Gigabyte GA-945GM-S2
Hi FRND,
check this link for the drivers which you want....
http://asia.giga-byte.com/FileList/Driver/motherboard_driver_lan_realtek_8111.exe
Enjoy...
Regds,
DRSS...
Posted on Nov 19, 2008
  • 65 Answers
SOURCE: Gigabyte GA-945GCMX-S2 Motherboard having display..
At first I thought your screen went black during the start up process. After seeing the bios screen. In which case I would've said it was a bios setting for the display. Then I realized that I think you mean that their is no display at all. When you push the power button. Only the monitor led light. So, it may be a problem with your RAM stick/s. You should make sure that they are properly seated in the mother board. If they are new, make sure they are compatible with that motherboard. If you can you should swap them out with known good ram sticks. You could also try installing a video card and see if you can get display to work through that one. Make sure your main power supply wire connector is pushed in all the way. Swap the power supply with a known good one if you can. If still can't get it to work you may want to take the motherboard out and inspect it for burns, cracks, and anything that doesn't look right. Maybe contact the manufacturer of the motherboard and ask them what you can check. hope this helps.
Posted on Sep 17, 2009
AldRezaine
  • 995 Answers
SOURCE: 8-9 bios beeps then shuts off restarts and more beeps
There is a problem of your devices attached to your motherboard, it could be the memory. Remove the memory card and then clean the pins with an eraser of pencil and put it back. Remove the graphics card and when the system boots then probably the graphics card is doing the problem but when the problem still persist then your memory card does the problem.
Posted on Oct 25, 2009
  • 42 Answers
SOURCE: i have a motherboard gigabyte 945 gcmx-s2 but
You can find all drivers from this motherboard here: http://www.centraldriver.net/driver.php?codigo=1746
Posted on Nov 01, 2009
Gigabyte GA-965GM-S2 motherboard keyboard, mouse, monitor won't work.
You need all the drivers, each peripheral has it's own driver that needs to be loaded.
Nov 28, 2011 | Gigabyte GA-965GM-S2 Motherboard
I am having one long beep and two short beeps on my gigabyte m61pme-s2 motherboard when i try to boot up...
That is an error code for the video card / device.
Turn off and unplug the computer.
If possible remove and reinsert the video card.
if you have a shared video ( connected permanently attached ) remove and reinsert the memory chips.
Aug 30, 2011 | Gigabyte GA-M61PME-S2 Motherboard, AM2,...
Help with drivers ga m61pm s2 problem on Gigabyte GA-M61PM-S2 ... NIC looks all right in device manager, but I cannot get to the network or my server
here is the link to your drivers for you mainboard
http://www.gigabyte.lv/products/page/mb/ga-m61pm-s2/download/
i don't know what OS ur running so i can't help more if possible please provide as much details as you can so i can help u with your problem
Feb 26, 2011 | Gigabyte GA-M61PM-S2 Motherboard
Motherboard
i believe your motherboard is already bad. have it replaced.
Sep 13, 2008 | Gigabyte GA-945GM-S2 Motherboard
Motherboard
try to remove and place to another slot your bios like the jumper near the battery and put it back again. see what happens next. see also if the wires from the switch of your cpu is correctly connected to the motherboard.
Sep 10, 2008 | Gigabyte GA-945GM-S2 Motherboard
Sound and video drivers required
You can download all driver software for the AOpen MX4LR at this link: http://download.aopen.com.tw/Default.aspx
Click the first dropdown menu & choose, Motherboard
Click the second dropdown menu & choose MX4LR
Bingo.... There's all the drivers for the MX4LR motherboard.
Enjoy!
Mike
Aug 03, 2008 | Gigabyte GA-945GM-S2 Motherboard
Intel Motherboard Logo
221 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
