Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Trying to install from disc. It asked for domain. I don't even know what that is .
I put printer 5300 together and installed ink It says the important part off the disc did not load
Anna Mae
    President:
  • 173 Answers
Try reinstalling the software and make sure all the cables are connected correctly. More detailed information about what it is doing and what it is not would be helpful. The drivers may not have loaded from the install disc so try uninstalling and reinstalling the software.
Posted on May 26, 2008
Doesn't show new installed cartridges, also wont shut down.
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I've been using my scanner this am, now the attention button keeps blinking that i am out of ink, I haven't been using the ink, just the scanner. I can't even shut down the printer. kodak all in one...
Kodak printer are designed in such a way that if you even don't print from them, everytime you on-off the printer the cleaning process goen on, which results in emtying the ink cartridges. Try installing new ink cartridges. if u still get the same ink error. Then the printer will be replaced.
Jan 14, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
We cannot get out printer to print. easyshare
we replaced printhead and it wants us to calibrate and replace ink color ink cartridge, and before we put the printhead in , it had 1/2 full color in cartridge
Jan 10, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 printer problem
I would suggest the following :
1) Remove the Kodak printer and all its software.
2) Disconnect the USB cable from the computer.
3) Reinstall the entire software applications for the printer just as if you were installing it for the first time.
4) When asked to connect the printer .. Use a different USB port .. even if you have to switch something out .. but do this step irregardless.
Now what I want to know is ..
1) Can you print from the computer?
2) Black still "gone" ?
Let me know
Feb 01, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black inkwon't print
pictures are not clear even after installing new ink cartridge and cleaning print head
Oct 04, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 printer
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 ink
First try to install a new cartridge as much as it is a waste of money. Sometimes it helps. If the error on the printer clears, download the newest firmware from www.kodak.com/go/5300downloads.
If that doesn't work, you will need to call Kodak AiO Tech Support at 1800 421 6699 to get a new printhead.
Jul 20, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Ink Installation Problem
Ok trust this solution. Go to www.kodak.com/go/5300downloads and try to install the latest firmware. If the firmware does not work, call kodak AiO Tech Support and go through the troubleshooting steps with them. The solution is usually another cartridge or a new printhead. Either way though, the firmware will update the printer so this won't happen after this first fix.
Jul 14, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
My kodak 5300 will not accept the new ink cartridges
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300....Problem:
I cannot get the printer to work on the USB cable. I have tried about everything. Seems that the drivers are there but there is something else wrong. Now what?
Nov 26, 2007 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
