Question about Maytag Dryers
Gas dryer will not heat. glow plg will light but gas will nor release to cause the flame
  • 121 Answers
This will typically be the coils on the gas valve. Both come in a kit replace both. http://www.appliance-repair-it.com/gas-dryer-repair.html
Posted on Sep 30, 2010
Lighting pilot light on kitchenaid dryer
It is all automatic, when you press start the power is sent to the gas assembly (if the timer is set for heat). The power originates from the cord to the timer to the temp control (on the blower housing) to the fuse next to the control, and to the gas assembly. The solenoids ignitor and flame sensor are all energized at once. The solenoids cannot release the gas unless the ignitor drops out of the circuit. That is the job of the flame sensor. Once the sensors bi-metal bends and opens the circuit, no more power goes to the ignitor< hoever, once the ignitor is glowing it generats a signal and becomes a thermogenerator with holds open the solenoid (holding coil) If for some reason the gas did not ignite the glow coil will cool off and shut down the solenoid. So what can go wrong? Lint buildup in the blower housing cause the fuse to melt. No power can be sent to the gas assembly. The flame sensor is open and not allowing power to the ignitor, the ignitor is open and not glowing. Old timey dryers had a pilot light. You hold down on the red lever and light the flame. Then release the lever and the pilot stays lit. I doubt if yours has a standing pilot. How modern gas dryer work:
Feb 24, 2013 | KitchenAid Dryers
The Kenmore dry glow plug lights but the gas only comes on initially. After a few min the gas goes out and the plug glows periodically but no flame
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 27, 2011 | Kenmore Dryers
Dryer runs ok. igniter glows and lights flame. Flame burns for about 30 seconds and goes out. After a while it does it again. Minimal drying being done.
heatman101
Jun 19, 2011 | Maytag ADG7005AWW Gas Dryer
Whirlpool lgn2000LG0.... flame wont ignite.. glow stem glows..
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 04, 2011 | Whirlpool LGN2000LWH Gas Dryer
No Heat - Maytag Dryer - Model# SDG3606AWW - Gas Line OK - Clear Vent - Do not see any flame after removing front panel. Igniter glows but then cools down no flame
heatman101
Dec 10, 2010 | Dryers
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a roper gas dryer model rdg4440sq0, the igniter glows then the flame lights. Then the flame goes out and doesn't light up again. When it cools down and i restart the dryer the igniter glows and...
If when the flame goes out ...Check to see that the igniter glows...If it glows and the gas does not light then replace the valve coils...Very common problem.....The coils are to weak to hold the valve open..
Apr 20, 2010 | Dryers
FLAME ON SART UP NONE AFTER
Replace the gas valve coils if the ignitor glows but does not light. Replace the flame sensor if the ignitor does not glow.
Aug 29, 2009 | Kenmore 73952 Gas Dryer
Dryer Model DE306 has stopped heating
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Aug 13, 2009 | Dryers
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
