Question about Jabra BT350 Bluetooth Headset Headset
Trying to pair my Jabra VBT2050 to my motorola. The passkey 00000 isn't working
I believe the passkey is 4 zeros 0000, not five.
Posted on Mar 09, 2011
  • 37 Answers
You can only use one digit number not four digit..to detect the bluetoot headset
Posted on Sep 30, 2010
I recently got the Motorola Droid X and paired & connected by jabra vbt2050 with it and it worked. Today though, when placing a call with the Jabra, I could hardly hear the call. Now I have not power...
To see if the problem is with your bluetooth connection, try sending and recieving files with your bluetooth. If it is successful, then try borrowing 1 jabra device and test it with your phone. The bluetooth connection and the jabra device are the problems I can see since you said it worked once.
Hope this helps! -jayps
Mar 09, 2011 | Cell Phones
I have a samsung phone and i am trying to pair it with my jabra vbt185z but i don't know the passkey...i tried using 0000 but that didn't work. so what else can i do to make it work?
You do need the passcode. It should "auto pair" but the default passkey or pin is 0000 (4 zeros.)
Here is a link to the user manual
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2010/Documents/UM/VBT185z_UM_6198.pdf
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
dw
Dec 31, 2010 | Jabra BT150 Wireless Headset
HK-760 Bluetooth dongle, pairs with my HP computer but after inserting the passkey, the computer starts searching for the peripheral device drivers without which a connection between my jabra VBT2050...
This device, according to the Jabra website, is intended only for phones, not PC's. The PC is searching for a driver in order to know how to communicate with the device. Since the VBT2050 does not have the necessary software contained within itself, the PC starts searching for device drivers. There are none that I could find on the Jabra website, so I don't think it is intended to be used with a PC.
Feb 20, 2010 | Adapters.com Bluetooth USB Adapater, USB...
Jabra VBT2050
The above solution only lacks one small item. Part of the pairing procedure is to hold the on/off button for the recommended 5 seconds to power up, but the light will NOT become constant until you hold both the power button AND the round center button on together until the light remains constant. Then you can pair the two devices.
Jan 27, 2009 | Jabra BT250 Consumer Headset
Jabra VBT2050 headset won't pair with blackjack II
ARE U FOLLOWING THE CORRECT PAIRING PROCEDURE
pls follow this
ok here u go first turn on the bluetooth func in ur mobile, now while ur bluetooth headset is off press the power centre big button for like 10 sec until the blue light stays on continously not blinking position ok then search for bluetooth devices in the phone bluetooth config ur headset will come up like JABRA VBT2050 select it then it will ask u for pairing code input 0000 and press ok ur device is now connected u will see the blue light which was continous b4 now blinking it means ur haedset is connected , u have to complete this process in almost 1 min bcoz there is a timeout for this process , now try any call u will hear it in ur headset
pls rate me fixya for this if it helped
Jan 13, 2009 | Motorola Mobility H350 Wireless Headset
Jabra VBT2050 Bluetooth won't pair with LG Voyager
Something similar happened to mine. It worked for 2 months, and my phone received a message from jabra to reset pass key. It did not accept, and it stopped working with my phone. I tried everything. I was told to hold the power down for 10 seconds to place in pairing mode, that did not work. This did. Hold the volume up down and the answer button down at the same time for 7 seconds. You have to make sure they are all down or it will not work. You will see that the light will stay lit continuously. This means it is in pairing mode. Then place the bluetooth on your phone on. Tap find device at the top. It will then locate the jabra. Follow any other prompts. If it asks for a passkey, or code, 0000 will suffice. Hope this helps. I looked for almost an hour and a half for the answer.
Jan 08, 2009 | Jabra BT250 Consumer Headset
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Dec 21, 2008 | Radio Communications
Passkey of 4 zeroes does not work
I have the exact problem.. but you try to turn off and on your phone once again.. and then do the pairing instruction.... using the passkey 0000.. then... it works for me again...
Oct 12, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 Bluetooth Headset Headset Logo
158 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
