Question about Samsung Televison & Video
No sound, take 2 hrs to come in. model HLN4365WX/XAA
  • Samsung Master
  • 17,130 Answers
The fault of the elctronic circuit to switch on slowly can be related to many issues. i have some tips that might help so take a look at this link:
http://www.fixya.com/support/r6055091-slow_start_up_circuit_cold_starting
Posted on Sep 30, 2010
  • Donald DCruz
    Donald DCruz Sep 30, 2010
    In this case please check the capacitors in the audio output IC section, replace suspected capacitors, try to heat the IC to see if the sound comes on , check the preamp.
HLT5055WX/XAA turns on then turns off. About 2000 hrs on Philips replacement bulb
That is near or past the normal life on the lamp---2,000 hours or 2 years is normal---I would remove and look at the lamp---if shattered you know and also look the pillar of glass inside the lamp is not bent or warped etc.
Dec 06, 2012 | Samsung HLT5055S 50" TV
SAMSUNG TV- model: HLN4365WX/XAA: Component 2 mode not supported
One thing to try is whatever (a box?) connected to that input--remove power from for a short while and then plug back to see if that will reboot the unit connected there.
May 23, 2012 | Televison & Video
Can you replace a fan in the samsung DLPTV model #hln437wx/xaa
it has 2 or 3 fans---they rarely fail but can cause issues---Are you hearing a high pitched whine or fan like sound? I KNOW WHAT THAT IS IN THIS SET...
Apr 09, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
Model RS267LBSH/XAA - freezer working but refridgerator side warm (54 degrees). Heard sound like fan blade hitting, then no longer hear fan at all. What could it be
Have same model rs267lbsh/XAA and fix refrigerator. What I did was take off cover where evaporator is there a wire called defrost temperature sensor that goes bad I changed that sensor and my fridge is now working .if u need to ask me question please email me at jwilliams1957@sbcglobal.net
Apr 12, 2011 | Samsung Refrigerators
Have a DLP DNIe model nbr HLN4365WX/XAA tv that has begun popping white lights when the tv has been on a while. What does that indicated?
Hi my name is Roety,
I can help you with your issue ,
If your TV pops the lamp if may be overheating
Clean all fans and vents with compressed air
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 28, 2009 | Samsung Televison & Video
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
32 people viewed this question
Henry  Thomas
Henry Thomas
