Question about Maytag Neptune MDE5500AY Electric Dryer
I HAVE A MAYTAG DRYER MODEL MDG4000BWQ AND IT WORKS FINE BUT QUIT HEATING THEREFORE IT WILL NOT DRY THE CLOTHES. i CAN HEAR WHAT SOUNDS LIKE THE IGNITOR CLICKING OR TRYING TO FIRE FOR A FEW SECONDS WHILE THE MACHINE IS RUNNING IT CYCLES THAT IS GOES OFF FOR A WHILE THEN COMES BACK ON WITH THIS CLICKING SCRATCHING KIND OF NOICE FOR ABOUT 4 OR 5 SECONDS BUT NO HEAT. i AM ASSUMING I NEED TO CHANGE THE IGNITOR??? IF THERE IS SUCH A PART. HOW DO I TAKE THE MACHINE APART TO GET TO IT??? TOP OFF,,, BACK OFF, BOTTOM OFF . ANY HELP WOULD BE APPREICATED. THANKS WAYNE
  • HANDY ANDY Dec 17, 2011
    This person seems to be referring to an electric dryer--IT'S GAS
    This person seems to be referring to an electric dryer--IT'S GAS:
    metbe the protective fuse of yuor dryer is broken so that the heating filament of your dryer did not work.....try to change the fuse if thers an existing fuse.....
    By sagara162029 Over a year ago = This person seems to be referring to an electric dryer--IT'S GAS
Http://www.fixya.com/support/t6223020-maytag_dryer_model_mdg4000bwq
to Wayne (vmsem) : model MDG 4000BWQ Maytag Gas DryerI have the same dryer and experienced a similar problem. If you hear a click followed shortly by a gas ignition (whoo-oosh sound) but then there's no significant heat at the beginning of a drying cycle, the flame went out..... probably because you have a bad coil (aka solenoid valve). If the dryer is left on, the click-whoosh event will repeat periodically--I don't recall how often, perhaps 5 minutes. To access the coils you will need to remove the front panel of the dryer....(it's simple). Begin by locating the door hinge screws when you open the door.Remove the screws that mount the hinges to the cabinet--leaving the hinges attached to the door itself. The door should still hang there loosely. With the door open, gently lift the door so the hinges will slide upward in the slot where they mount, then pull gently to slide the hinges out of the slots. When you remove the hinges you can see why they require the up-n-out motion. Now remove the screws (2) on the other side of the door opening--they are holding plastic "bumpers" attached to the cabinet just inside the door. The top front panel should now pull away from the cabinet--tug at the top R and L portion of the front panel but not at the base--it is hinged. Then allow the top of panel to drop forward and down (within 1 ft. of the floor?) until it can be easily pulled away from the cabinet (off of the brackets that hinge the base of the panel). Now you can see what's happening and troubleshoot.
WARNING --If you haven't unplugged your dryer BE VERY CAREFUL not to touch exposed wires, igniter, etc. and if you activate the motor, keep your hands or anything else away from moving parts, including the dryer drum.
CLICK--WHOOSH--FLAME GOES OUT:Chances are that your problem is with one or both "coils" that are mounted about 6" in front of the burner tube (metal duct where the gas ignites).
There's a bunch of red, white, and black wires attached to little plugs that are connected to the coils. They can be tested for continuity using an ohm meter and more on that can be found online. If the igniter is bad it will not get red hot and the flame will not appear. You can observe what happens by starting the dryer and watching. BE CAREFUL !! (Hold the button in--where the door used to hit it. Or, temporarily replace the door without the front panel). The igniter should glow red-hot within 10 seconds and within 30 seconds the flame should start. If the flame starts but goes out after a few seconds it's more than likely a bad coil. If the igniter never gets hot, look closely at it (before removing it) with a flashlight to see if a crack or break is evident. BE SURE TO UNPLUG the dryer before attempting to remove the igniter (or other parts) OR wires connected to it--SHOCK HAZARD! Avoid touching the metal igniter element unless you're sure it's bad--Touching or bumping a good igniter may cause it to fail. Directions on the procedure can be found online. .
Recently I encountered a less common problem with my 11 year old dryer that also prevents it from getting hot--(no flame at all). The igniter gets re-hot and stays red, but no fire. There's a (1x2-inch black box) heat sensor mounted over an opening on the burner duct, very near the igniter. As the sensor is heated by the ignitor, it's supposed to trigger the coils and allow the gas to flow for ignition. I understand that the sensor rarely fails but it can happen. More details about troubleshooting and replacing bad parts can be found elsewhere. I hope my comments were helpful. ("HandyAndy")
Posted on Dec 17, 2011
  • 37 Answers
Metbe the protective fuse of yuor dryer is broken so that the heating filament of your dryer did not work.....try to change the fuse if thers an existing fuse.....
Posted on Sep 30, 2010
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
MAYTAG GAS DRYER NOT HEATING
That sounds to me like you need to replace the coils. They get intermittent with age. Work some then quit take a long time to cool down and work a little more when going bad.
MY MAYTAG DRYER HOME REPAIR VIDS
Jul 20, 2012 | Maytag Dryers
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
Not sure what model is other than maytag atlantis but my gas dryer has quit heating therefore does not dry...any suggestions?
check voltage to dryer, should be 220-240. check element, thermal fuse. could be in the timer but rare.
Jun 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Quite Plus clothes dryer gets warm but not as hot as it use to. It seems to take a very long time to dry clothes. Vent is clear. The moisture gage seems to flicker lately.
most dryers have two heating elemts and when one goes out this increases the drying time and could cause a elec. short and trip a braker can be replaced.. There is also a saftey switch that goes bad and will not let the heating elemt work properly ?
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Roper dryer model REX 3514RQ1. dryer works for/then quits. help!!
I have seen this before. You have got to remove the housing for the filter. Blow out the area around the blower and get the junk out of there. Wash out the filter housing.
Jul 06, 2009 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
307 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
