The computer says the disk is not formatted. Im afraid if I format it it will just become a flash drive and no longer an mp3 player. is there anywhere i can get a software for it?
(WARNING: After running this low level format tool, the whole USB flash disk surface will be fully erased. Therefore, data restoration will be impossible after using this utility!)
you should reinstall the firmware in the mp3 player
to do that you can go on the mp3 manufacture's website click on support and look for the appropriate firmware that fit your model number
once it's download
plug your mp3 to your pc and then run the firmware updater
you should be able to use your mp3
good luck
#1 Insert your ( memory card , flash disk , cellphone , .... ) into your computer. #2 Open up 'My Computer'. You should see it under the list of available drives. #3 Check its contents first to make sure that you have the right drive. #4 In 'My Computer', right-click on the drive and choose 'Format'. #5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place. #6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
what is your mp3? if it come with manual im sure there is instruction how to format, but if doesn't just format in windows connect to usb and when computer detect ur drive just right click and click the word format.
Try using Windows Disk Manager.
Control Panel - Administrative Tools - Computer Management
In the Tree-List on the right, you want
Storage -> Disk Management
if you can't see the tree-list select the appropriate button on the toolbar, you should be looking at something like this: http://attachments.techguy.org/attachments/129148d1206573004/disk-manager.jpg
Select your 'volume' from the list in the main part of the window and right-click. Somewhere in the menu it should say 'Format'. Select this and move through the stages.
(When asked use FAT or FAT32, not repeat not NTFS. NTFS is for Windows hard-drives only)
When using your MP3 player for the first time you should format it.
Formatting prepares the disk (storage medium) for any reading or
writing. It erases all information on the disk, and tests for any bad
sectors or errors. Below are the steps for formatting your player:
-Connect the disk storage (MP3 player) to your computers USB port. If
the computer pops up a window asking what do you want windows to do?
Click cancel. -Right click on My Computer and click on Explore. Look
for the drive Removable Disk (E:) [The letter drive may vary depending
on your computer] This is your MP3 player. -Right click on the drive
Removable Disk (E:) and click Format… A small window will pop up
displaying Format Removable Disk (E:) Click Start. Read the warning and
click OK. Format is complete.This procedure can be done occasionally to
erase all data on the disk storage. http://www.nextar.com/frontend/support.asp?CATEGORY=10000309&MODEL=MA715&subpr=624950167&categ=519278318
T.sonic cannot operate after it was formatted in Windows Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the default format of the T.sonic. To retrieve the default format, you must link to http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
