Question about Husqvarna Huskystar 207 Sewing Machine
Need to change light bulb - Husqvarna Huskystar 207 Sewing Machine
  • Husqvarna Master
  • 7,365 Answers
Some machines it's called the lamp cover door --these machine have a hinge at the back, carefully pull the door toward the back of the machine & it should open to show the bulb
some machines call it the face plate--there is a hidden screw under a plastic plug, gently pry the plug with a screw driver & then take the screw out, & remove the plate & the bulb should be easy to replace,just put the plate back on after changing the bulb & replace the screw & plug
happy sewing
Posted on Sep 30, 2010
Testimonial: "wow what a great respone time thank you so much"
Change bulb on 6085 PFAFF
Looks like you bulb is a bayonet style. Push up and rotate the old bulb to remove. Install the new bulb the same way--push up & rotate to lock in place.
Note: there is also a bulb remover tool
Pfaff Varimatic 6085 Parts
PFAFF fashion Owner Manual Changing The Light Bulb
Apr 07, 2017 | PfaFF Sewing Machines
How do I change the light bulb on my Bernina 1530?
You might check out some of the older Bernina manuals to get an idea of how it may work in your machine. The 1260 is the closest manual available. Looks like your machine takes the same push-in bulb. So, you would push up on the bulb and twist. Then you would install the replacement the same way. Sometimes, using tight fitting medical gloves helps grip the bulb in order to twist.
BERNINA Sewing Systems
BTW--I have older Berninas and upgraded their bulbs to LED.
Oct 03, 2016 | Bernina Sewing Machines
Where is the light bulb located on a Memory Craft 4000 sewing machine. Need to change light
Hi Rhonda I have a 9000 and a 500e and the light should be directly above the needle shaft.
Good luck
Jan 20, 2015 | Janome Sewing Machines
Change a light bulb in Bernina 1008 sewing machinge
If you still have original Acessories there should have been a grey or brown cone shaped rubber gripper that could be slid up on bulb to assist in turning it If not remove the side cover, then back cover to access the bulb. Some 1008's have push in bulb others screw in so be careful not to break bulb as you remove it
push in bulbs must be pushe in and rotated 45 degrees counter clockwise to remove. Of course screw in bulbs just rotated counter clockwise to remove
Aug 23, 2014 | Bernina Sewing Machines
As changing the light of my jaguar sewing machine
try these sites for a manual
sewingstyle.com
sew4less.com
homeappliance.manualsonline.com
also try youtube--changing a light bulb on a jaguar sewing machine
and bing video search--changing a light bulb on a jaguar sewing machine
Apr 01, 2012 | Sewing Machines
I have a Singer Advance 7422 Sewing machine. The light bulb went out. How do I change it and where can I find a replacement bulb?
My light went out of my Singer advance 7422. Does anyone know how to change it or where to buy the bulb? Thank you for your help.
Jun 05, 2011 | Singer 7422
Light bulb not working
You need to change the bulb.
Most light bulbs in almost all sewing machines are located inside the face plate on the left hand side of the machine.
The faceplate is usually hinged at the back and it opens a bit like a door. It should open fairly easily and close with a click.
Open the faceplate and unscrew the bulb, it should be in plain view.
Look to see if it a screw or bayonet type.
Replace it the same way you would an ordinary bulb.
You can get sewing machine bulbs on ebay but you'll need to know which type of fitting it has before you buy.
Hope this helps!
Nov 10, 2010 | Singer 7462 Mechanical Sewing Machine
I need to change the overhead light bulb? how do I do this it is not in my manual
It is on page 110 under the Care of your Designer 1 section. You need to use the special tool provided to remove (one end) and insert (other end) the new light bulb. Light bulbs can be easily sourced from the auto spare parts department for very cheap prices. You might need to slightly wet the removing end of the device to help provide suction. It is a tricky operation, but you will be able to do it yourself. You might try laying the machine down on its side on a towel to help you see better. Sometimes the bulbs pop out without bother but other times they just don't seem to want to come out - persevere, they will come out in the end. You should change both bulbs at the same time - if one is out, the other won't work. There is one above/beside the needle and the other is in the harp of the machine.
Oct 23, 2010 | Husqvarna Designer I
Cannot get to the lightbulb on an Elna SU sewing machine to chang
On the left hand side of the machine on the end cap.
Changing the Light Bulb
The sewing light is located behind the face plate.
UNPLUG THE MACHINE. Wait until the bulb is COOL before you touch it!
1 2 3 Remove screw cap , screw and face plate .
To remove: pull out bulb from socket.
To replace: insert bulb into socket.
Attach face plate and insert screw and screw cap.
NOTE: Replace bulb with same type rated 12V, 5W.
I hope this helps. Don't forget to rate my answer.
Jan 31, 2009 | Elna 2007 Mechanical Sewing Machine
Husqvarna Huskystar 207 Sewing Machine Logo
330 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
