Question about Whirlpool Duet GHW9150P Front Load Washer
Washer door leaks - Whirlpool Duet GHW9150P Front Load Washer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
The front baffle/boot will likely need replaced. You can do this yourself but it takes some patience. You can order the part, list model #, at 888-321-3107. The procedure is as follows:'
1. Tilt washer, back against wall.
2. Remove wire spring with needle nose plyers. The spring is located at outside perimeter, under lip, of baffle.
3. Peel baffle from front panel.
4. Remove clamp from the outer tub lip. Look closely and you should find a large hose clamp. Use small socket wrench to loosen.
5. Install in reverse order. Be careful and take your time.
Rich
Western Appliance Repair
Washer Repair
Posted on Sep 30, 2010
Need to get new seal for door
How do you fix the doors on a washer and dryer front end loaders
Hey friend, thank you for the post!
I understand your Frigidaire washer is leaking and you are inquiring about how to fix the doors on both your washer and dryer. Some of these parts when being replaced require precision and I suggest contacting a professional for additional assistance. Since the washer is also leaking water the technician would need to detect where the water is coming from and repair that issue as well. Hope this is helpful. -Matt
Jul 24, 2014 | Frigidaire Washing Machines
My whirlpool duet sport washer is leaking in the front underneath, not from the door. Does not do it when it drains. What do I do?
Hello Casey,
Its possible that the washer could be leaking from the door seal yet ya don't see it coming from the door. The way to check if its the door seal remove the lower panel and see if the concrete counterweight that's on the front of the drum...if ya see water dripping from that counterweight,its from the door seal.
If the door seal is not leaking ya would need to look at the pump and hoses on the tub while it was in wash mode to see whats leaking.
GENE
Oct 11, 2011 | Whirlpool GHW9400 Duet Washer
Washer is leaking from door, the other day the rubber gasket between door and tub came off during use..we put it back on, but it still leaks
It sounds like you have a hose leaking.You can check the hose leaking by opening the washer door & inspecting the rubber boot that goes around the perimeter of the tubs. It is secured in place by two clamps.In order to check if the leak is underneath the washer tub you will first need to disconnect electrical power to the washer.Remove the three screws securing the toe panel to the front of the washer and remove the toe panel by lifting slightly and pulling forward.
Hope this helps.
Shane
Mar 08, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool Front load washer - Water leaking
I would check to see if you have a hole or crack in the rubber boot inside the door. Open the door and seperate the fold in the rubber boot and check for a leak. If something sharp was left in someones pocket it will get stuck in this part of the bood.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
195 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
