Question about Native Instruments Guitar Combos: Twang Combo (4042477003623)
Serial number for twang combo - Native Instruments Guitar Combos: Twang Combo (4042477003623)
Serial numbers on makita combo kit DLX2002
Serial numbers on any product are for that one and only item. That's why it's a "serial" number, each and every one has it's own individual number. The one before it and the one after it on the production line have a different number.
The serial number is usually pointless unless you have a recall or something.
Nov 02, 2016 | Makita Drills
My fender frontman 15r guitar amp has too much of a bass sound on e-a-d but too high on g-b-e I'm using a silvertone guitar with a 5 way switch how can I get goo clean sounds for country and blues?
As a guitar tech I suggest that you simply lower the pickup height on the low strings [by turning the height screws clockwise] then the low strings will blend better with the high strings.With a 5-way switch try the 2nd and 4th positions for a more out-of-phase twang too! Good Luck.
Sep 17, 2013 | Fender Frontman Amp 15R Guitar Combo Amp
Were is serial number on lxt202
serial is on same label where the model number is
S/N:
Nov 16, 2012 | Makita LXT202 BHP451 18 Volt Hammer Drill...
I have twanging noise from rear end peugeot partner van 52
A Twang sound is normally a universal joint on the tail shaft, Check for movement & replace if necersary.
Jun 18, 2012 | Cars & Trucks
Sound comes and goes on the drive channel, and there is a strange crackling on the clean channel. i dont know if its the tubes, the speaker, or electronics.
Using a common lead pencil, gently tap on the smaller tubes in the unit, listening for noises and crackling to change and the drive channel changes.
It is normal to get a slight twang when doing this from the microphonics of the tubes, however, the crackling and up and down volume points to a bad tube.
Sep 03, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Where is the serial number on my marshall amp mg15fx
Behind the amp, right around where the power-supply is. Usually the right hand side at back of amp. Serial numbers are labeled as: S/N########
Mar 14, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
The Nero Essential 7 CD included in the pack doesnt work
Original nero cd's will take key automatically or else the serial number will inside the cd.
search for a file by name serial.
it will be a text file.
Jan 05, 2009 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
Twang
How do you connect your system?
Joe
Feb 04, 2008 | Philips DVD Micro Theater Shelf System...
Computers & Internet Logo
659 people viewed this question
Top Native Instruments Computers & Internet Experts
ray gallant
Dan Shibata
Dan Shibata
JonSnell Electronic
JonSnell Electronic
Are you a Native Instruments Computer and Internet Expert? Answer questions, earn points and help others
