Question about Watts Onan Portable Generator - 4000 , Model# 5500
I have an ONAN Microquiet 4000, 6 years old, ca 500h on the meter and not run for about 6 month, stored in hot climate (Nicaragua) When started the Onan was initially surging for a few minutes, then engine stopped. Engine will crank normally but will not start again. Batterie ok, Oil ok, Sparks ok, drained gas from the carb and replaced with fresh gas. Any advice? Many thanks!! email: ulibartke@hotmail.com
  • 3 more comments
  • ulibartke Sep 30, 2010
    oil is fresh, changed the spark plug, engine does not start
    spark plug is new, new oil, but engine does not start...
  • ulibartke Oct 02, 2010
    your suggestion worked out just fine. One of the little channels was blocked and I could clean it with cleaner and a little mechanical help. Generator runs well now! Thank you very much!!
    Enjoyed the experience.
    Uli
    your suggestions worked very well! Generator is running now like new. Thank you very much!!
    Uli
  • 3,740 Answers
Remove the float bowl and the fuel solenoid from the bottom of the carburetor. In the area where the solenoid screws into there is a jet. Most likely there is debris in the jet orifice. You cn use a small nail or a scribe to GENLTY scrape in the throat area of the jet to clear any obstructions. Then spray carb cleaner into the jet orifice area as a final cleaning procedure. Before you re-install the float bowl also remove the fuel supply hose from the carb and spray carb cleaner from the float needle area back to the supply connection. You may have to remove the float pivot pin but, I would not remove it unless your absolutely sure that there is debris in the float valve needle area. Getting ready to install the float bowl.... spray the plunger of the fuel solenoid with carb cleaner. Once your sure that the fuel supply passages are clear install the float bowl and solenoid. Then connect the main fuel line and test the generator.
There is one more thing you can check but you have to be real careful. That is checking fuel supply during engine cranking with the fuel hose removed. (FIRE DANGER) There should be good fuel flow via that fuel tank, fuel pump and fuel filter during cranking. If you don't have good fuel flow with the fuel supply hose removed from the carb, the problem can be debris in the bottom of the fuel tank, a clogged fuel filter or a bad fuel pump.
Thanks for choosing FixYa.
Kelly
Posted on Sep 30, 2010
  • Kelly
    Kelly Oct 02, 2010
    I am happy your up and going again. There is nothing that makes my day like someone fixing a problem that otherwise could have ended up in a shop when the owner could have fixed it. Time effort and money saved for the owner = a good day here. Take care. Kelly
  • 37 Answers
Try to chage the engene oil..and replace the spark plug of your generator......
Onan 4000 Microquiet shuts down after running for 20-30 minutes. If I direct 2 high power (400+ CFM) fans to the underside of it -it will keep running indefinitely.
check the current draw from the machine
being a 4000 watt machine if you are drawing 4000 watts it is overloaded as that is the surge power available not constant power which is around 3500 watts
that would account for the requirement of fans to keep it cool
even if It is not 4000 watt what ever capacity it is it is running in an overload situation
Jul 10, 2016 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 won't turn over
check for bad battery, loose terminals ,dirty terminals , faulty starter relay
if it is not starting check for oil level is correct ( low oil level sensor turns off ), diesel -air in system
Jun 11, 2016 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 microquiet generator
Check the ignition circuit, and trigger coil for correct resistance on the trigger coil, and the ignition coil. The trigger coil is a small module on the engine shaft near the flywheel.
Jan 31, 2015 | Onan Microquiet 3600 & 4000 Generator
Onan generator microquiet 4000
Check the pickup tube in the vehicle, the fuel pump is suspect. If you check the fuel pump pressure and it is ok, then try installing a test check valve between the fuel delivery hose to the generator. If it solves the problem the pump is losing it's prime internally, so replace the fuel pump.
May 24, 2013 | Onan Microquiet 3600 & 4000 Generator
Onan bfa 4.0 generator
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Apr 27, 2013 | Onan Microquiet RV Generator 4000 Gasoline...
Onan generator not running
recheck, reclean,and rebuild carb possible had moisture in fuel and carb --white smoke--but sounds like float and carb still gummed up
Feb 15, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan Microquiet 4000 starter will spin but not turn engine
bendix is actual the spring that pushes the gear back out of the ring gears engagement your issue is more likely a rusted /corrodied incline engagemnt gear a little lube will probably bring ti right back (do not us WD_40) this is not a lubricant it is an anti lubricant any light oil will do Good Luck
Oct 12, 2009 | Electrical Supplies
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan generator making grinding noise while cranking
If it walks like a duck and quaxks like a duck?
If it grinds like a starter ?
Your alternator would hsve to be in absolutely unaerviceable condition to match a noise a starter makes.
Jun 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
1,080 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
