Question about Haier Energy Star ESA3183 Air Conditioner
A/C Fluctuating Pressures
When i hook up my gauges to the high and low side i have fluctuations in the pressure readings.In the past i have just replaced the unit it self but this time dont have the means to do it.So my question is....Is there anything that i can try to do before replacement??
  • Justme78212 May 25, 2008
    Its not a window unit....Its central
    Novelist:
    Champion:
  • 230 Answers
I dont know what you mean by fluctuating. Do you mean small bounces? If so that can indicate non condensables like water in the line. It could be an indication of a weak compressor.
If they are slowly increasing and decreasing then the refrigerant levels could be the cause as well as a weak compressor. As 22 Yooper said. Make sure you are checking based on the superheat target pressures.
Posted on Jun 15, 2008
  • 828 Answers
Most Central air conditioning systems are what is termed "A Critical Charged system". Ambient temperatures also affect the pressure reading in the system. Every time you attach a set of gages to a system you will loose some of the charge even if minimal. A set of gages in the hands of someone who does not fully understand the inner working principles of the system could be dangerous to both the system and to the individual in person. To balance a system charge the superheat method is the best. This must also take into consideration the ambient temperature at the time of the procedure. A low superheat at a lower ambient temperature will cause a liquid flood back to the compressor under higher ambient conditions.
Posted on May 25, 2008
Does Kubota tractor have a low pressure switch & high pressure switch for air conditioner
You might have a TX valve and switch on the evaporator side. There should ought to be a low pressure switch in the hvac circuit to prevent compressor from running when freon is below operating pressures. Have you had the chance to hook up a/c gauges to get hi and Lo side readings?
Jun 20, 2016 | Kubota Garden
Cruze ac problem both side pressure riding good lp hose too much cool hp normal hit compressor engage good condensor fan good but cooling low not good cooling drive time
Your question was somewhat confusing. It sounds like you may have a set of gauges that you hooked up to your high or low side? Without a proper set of gauges to read the pressures it would be hard to properly assess the problem. A/C is all about pressure/tempeture Depending on the age of your car, you have r-12 or post 90' or so 134-a. Whatever the temperature is that day your pressures should be within a range . If it's too hi or low would indicate a problem. In the mean time it never hurts to clean your coils in a car you're probably only going to be able to clean the condenser. So I guess I would have to need to know what refrigerant you have and what were the pressure readings. You did say that when you turned on your AC the compressor was working?
Jun 06, 2016 | AC Cars & Trucks
What causes high pressure on the low pressure side of the a.c. unit
Low side and high side pressures are high. Usually indicates an over charged system. do you have a charging guage! if not, go to any auto parts store to get one. advanced auto, auto zone ETC, this guage will tell you the correct amount of freon to put in it, on the low side only.
Jul 15, 2014 | 1995 Chevrolet K1500
Erratic temp gauge - strong smell of antifreeze - temp light comes on flickers goes out. really hot air coming through heater vents.
have the alternator checked for out put. have a pressure test done on the cooling system to check for leaks The fluctuating temp gauge may be the boiling water gushing past the sender bulb .
Mar 02, 2014 | Buick Century Cars & Trucks
Fluctuating oil pressure
replace the oil pressure senor they alway's fail on gm cars and trucks
Apr 05, 2012 | 2003 Chevrolet Impala
COMPRESSOR ON & OFF FREON LEVEL OK
You need to hook up a gauge and read the pressures on the low and high side. It will cut out if the pressure drops too low or goes too high. If it was properly evacuated and charged I would assume it is probably high pressure cut out which would be indicative of a plugged orifice tube or restriction in the system (line, condenser, evaporator.
Jul 06, 2011 | Chevrolet Colorado Cars & Trucks
How do i hook my manifold gauges to my residental condensing unit to check pressures
The AC manifold gauges set have the three chambers: the low pressure chamber (left side), utility chamber (middle), and the high pressure chamber (right side).
When technicians connect the HVAC manifold gauge to the air conditioner units, he connects the low pressure side of air conditioner unit to low pressure gauge side.
If he wants to read the pressure in discharge line he connects the high pressure gauge hose to the air conditioner high pressure side.
The utility port (the middle chamber) is a place you connect the hose to vacuum pump, recovery units or add or remove refrigerant from AC units.
Air conditioning gauges is used to measure air conditioner units pressure within closed-system to evaluate or troubleshoot the AC units. Gauges manifold set is the most frequently used item when it comes to refrigerant or pressure.
Air conditioning gauge set allows the HVAC technician to check AC units operating pressures, transfer AC refrigerant, pressure test system, purge the system with nitrogen, and perform other necessary tasks.
The gauges manifold set includes the hoses, the manifold, the valves, the compound gauge (low pressure gauges) and high pressure gauge.
Jul 24, 2010 | Heating & Cooling
My oil pressure gauge is fluctuating and on ocassion will peg out to the high side. What could be the cause? Oil always checks good on dipstick.
Sounds like it could be the oil pressure sending unit. I believe it's at the back of the intake manifold, on the driver side.
May 15, 2010 | 2001 GMC Sonoma Extended Cab
How much freon goes in a 2006 suzuki forenza
You can use those quick fill freon systems from auto zone that has the easy to read Gauge on the bottle. There are some that come with an easy connect hose to.
If you have your own gages and bottle you need to get you pressures right in your high and low side. At most ambient temp. that warrant using your A/C pressures should read about 35 on low side and 65 to 70 on high side.
May 09, 2009 | 2006 Suzuki Forenza
Haier Energy Star ESA3183 Air Conditioner Logo
351 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
