Question about HP LaserJet 3330 All-In-One Printer
Hallo, How can I The scanplaat (glass plate) dismantling, the plate is nauseating inside side. I would like the plate to the within side cleaning
    President:
  • 2,777 Answers
It is not recommend that you dismantle the platen on this scanner, I can almost guarantee it will do more damage than good. You say the underside of the glass is nauseating? Really? What could possibly be under there?
Let me know a bit more and if you really want I can tell you how to take it off, but I definitely do not recommend it.
Tim
Posted on Oct 01, 2010
How do I remove the glass to clean it?
You have to dismantle the door if the the residue is on the inside, but I recommend using a paint scraping razor to clean the glass, avoid slopping large amounts of cleaning fluid on it
Apr 26, 2016 | Ovens
Like many other people I have a vertical line down the copy, using the document feeder, not the plate glass. on my HP officejet J5780 3 in one. Your advice is to clean the small glass plate. I look...
I dont have a picture at the moment but if you lift the document feeder up to expose the large plate glass, the small plate glass is normally situated at the extreme left hand side of the large plate glass.
May 29, 2011 | HP Officejet J5780 All-In-One InkJet...
Spill between glass panes on oven door
The only way to clean this is to dismantle the door. Most brands you can remove the door and set it on a counter to dismantle. This can be very complicated, depending on the brand and model. Leaving the gravy inside the door won't hurt the range, and self cleaning usually will not clean this completely. It usually just bakes it on harder. Good Luck Appliance Specialists
Dec 31, 2009 | Kitchen Ranges
The glass on the inside of the oven door has fell away while i was cleaning it,can not see any way of putting it back on,is it glued on?
that is your heat safety glass if the outer pane is still there,you will need to dismantle the oven door and reseat it in its frame in the oven door,the screws are on top of door and on inside when door is down,im sure you'll find it..and dont run self clean w/o safety glass in place,outer glass wont take the extreme heat of self clean feature
Jul 24, 2009 | Ovens
I have a Y plated A4 TDi the turbo seems to die after a while. starts off fine, within 20 minutes i lose power and the turbo dies
common problem with VNT turbo's fitted to audi's is sooting up of the variable nozzles of the turbo. this causes the the actuating ring inside the turbo to jam, the engine managment senses this and goes to emergency running mode, ie low power. You can clean turbo VNT housing if your a bit handy with the spanners but this involves removing unit from the car and cleaning housing, actuator ring and vanes on the exhaust side of the turbo with scotchbrite. You dont have to dismantle the impellor but you do still have to keep every thing really clean. Another cause of power loss is the air flow meter so you may want to check that out before taking your motor to bits.
Jul 02, 2009 | Audi A4 Cars & Trucks
How do I clean the glass inside the oven door. Have tried to get to glass with no sucess? I have runs on the inside that will not disapear? Thanks
Open the door to the first notch. Lift it straight up off the hinges. Next, you'll have to dismantle the door. Remove all the screws around it and the glass will be held in by another frame. Unscrew the frame, clean the window and reverse for reassembly.
Apr 22, 2009 | Kenmore 30169 Electric Single Oven
Cleaning underside glas plate
Hi, I had to dismantle my HPG55 to clean the glass and found the instructions at the HP website. The link to the site is below. The instructions are very clear, and there are also photos to help you along the way. I hope this helps.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=de&dlc=de&cc=de&docname=c00498704#N216
Sincerely,
Tosty
Feb 23, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Jan 06, 2009 | Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
HP LaserJet 3330 All-In-One Printer Logo
Seeker5211
Seeker5211
