Question about Toro Lawn Mower With Toro Power Tools
Cable broke on my self propelled 22" toro lawn mower. Picked up a new cable with a spring at the end that attaches to the transmission. How do I replace this end of the cable.20017 mower cable 105-1844
SOURCE: the cable traction cable is broken on my toro
I changed the cable on my toro mower but i cant make it go unless i pull back on the handle .i cant find a picture to see what i am doing wrongcan you help. Thanks
Posted on May 06, 2009
wadembly
  • 448 Answers
SOURCE: Mower won't keep running after 10-15 seconds.
check the air filter & also spray some carb.clean in the carb see if that helps
Posted on Jun 06, 2009
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
Posted on Jun 08, 2009
  • 130 Answers
SOURCE: I have a TORO 6.5HP Mower Model #20017 Self Propel Drive-
check cable.check belt and check gearbox.one of these will be bad.if not all
Posted on Jul 22, 2009
  • 5 Answers
SOURCE: Toro mower model 20017, self propelled will not
either a gear wheel has busted inside the plastic wheel hub. Or the drive belt is off it's track and wedged between the disc wheel and the frame. easy to pry off.
Posted on Aug 05, 2009
Toro 20333 self propel. Doesn't engage. l
Is the tension spring gone? How is the cable? Usually there is a spring at the end of the cable in which when you pull back on the bar with your hands, this tightens the belt so that it engages with the engine allowing the wheels to turn.
Oct 06, 2015 | Toro 20332 22" Personal Pace Walk Lawn...
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
Jul 21, 2014 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
Have a walk behind 22"
Sounds like the rewind spring is broken in the recoil starter.
Aug 04, 2011 | Toro Power Lawn Mower
Limited self propell
The self propel cable needs to be adjusted. This can be done with a 7/16 wrench. loosen the nut that holds the self propel cable in place. You may need to pry this open with a screwdriver. Don't overdo it or you could break the plastic. Once the cable is loose pull it toward the mower deck, once the slack is out of the cable press the self propel handle in about a half of an inch. This should be close to what it was from the factory. Then re tighten the nut. And check the self propel to make sure it is engaging properly. If you hear a grinding noise when trying to engage the transmission then you will need a new transmission. Depending on if it is a front or rear self propel the part alone is either $60-$75 retail. Most repair shops will charge an hour to do this repair. I hope this answers your question.
Mar 24, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
My toro self propelled lawn mower won't roll backwards... the wheels are locked up
My Toro Pace Master self propelled 22" 6.75 mower will not move by itself. I can push the mower and cut. It does start with no problem. I have a cable on left side of the mower that extends to the top of the handle broken off at the top of the mower and is loose. Is there a way to check to see if this is why it will not self propel. It attaches to the push handle that does I push down to propel the mower. Any suggestions?
May 07, 2010 | Toro Lawn Mower With Toro Power Tools
Replace the cable traction (part #105-1844)
I just replaced mine and it was a little difficult and took me roughly an hour to do. First, download the walk behind power mover drive systems at https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=30166&control=SetCommunity&CommunityID=225&PageID=30031#manualsResultPage
While they do not specifically address replacing the cable, you can find out how they do it when replacing the drive belt. As I said, it took me about an hour and I just about had to remove the transmission and rear drive assembly in order to unhook the original cable. Good luck!
Aug 14, 2009 | Toro Lawn Mower With Toro Power Tools
Self propel is out
Either the cable that engages it is broke or the belt that drives it is broke.
Jim
Jun 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
751 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
