Question about Kodak EasyShare Z740 Digital Camera
B03 error code on kodak easyshare one 4mp digital camera
Camera turns on briefly showing B03 error code, zoom lens extended (won't retract). changed batteries and removed memory code. I still receive the error code. the manual says to clean contact points on batteries. I even tried that and still have the same error code.
Kirstin N. Fuller kfuller33@YAHOO.COM
Thanks for your help! I had moisture get in to my camera and ended up with the same problem. I have the Kodak Z740 camera.
  • Anonymous Feb 02, 2009
    I have got the same problem
    fevzierhan@yahoo.com
  • Anonymous Mar 08, 2009
    same issue after changing battery.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 22, 2010
My daughter just dropped her camera, now the silver part/zoom lens wont go back in and its says, lens error 211. i tried removing the batteries and putting them back in but nothing has changed. what do i...
The lens has been damaged, or knocked out of alignment. There is a tiny motor that extends and retracts the lens, you will need to take it to a camera technician to assess whether it can be repaired or replaced.
Jan 17, 2011 | Kodak Easyshare C182 12MP Digital Camera
Lens won't retract
Lens probably does not extend or retract because of debris or a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 07, 2010 | Kodak Easyshare M753 Digital Camera
Easyshare Z612 with an error code of #e45
Itøs a lends error. There is not much else to do than to send it in for repair or go for a trade up.
OoW repair for this model w. this fault: 88,07 Pounds.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 14, 2009 | Kodak EasyShare One Digital Camera
Turn on camera get error B03
THe issue of the camera shutting down and the lens Extending is an internal malfunction. UNited Camera Repair has been able to fix this, at least for me, they did. They replaced the main board and the camera worked when I got it back. Otherwise, if you dont want to spend the money, try installing a new firm ware.....
thank yoy hav a nice day
May 11, 2009 | Kodak EasyShare V550 Digital Camera
Camera error #B03
j'ai un kodak EasyShare c360 il donne un message comme erreur camera#B03 et consulter le guide
Apr 15, 2009 | Kodak EasyShare C875 Digital Camera
Kodak Error B03
Either your PCB board is damaged, your batteries are old, or your AC adapter is providing higher voltage than the required 3 volts.
Feb 09, 2009 | Kodak EasyShare CX7430 Digital Camera
My easyshare Z650 has an error code B03, How do I fix it?
kodak digital camera v530 showing #b03 error.how to sole this problem.mail me at juneboyrishi@gmail.com
Jun 25, 2008 | Kodak EasyShare V550 Digital Camera
Kodak EasyShare C533
When I turn on the camera. the lens will not extend. The screen
will not show anything but a message, " date & time are already
programmed". No menu item works. Pictures cannot be taken.
Apr 21, 2008 | Kodak EasyShare C663 Digital Camera
THe issue of the camera shutting down and the lens Extending is an internal malfunction. UNited Camera Repair has been able to fix this, at least for me, they did. They replaced the main board and the camera worked when I got it back. Otherwise, if you dont want to spend the money, its a gonner..
Mar 02, 2008 | Kodak EasyShare One Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
395 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
