Question about Sunbeam 2350 Heritage Series Mixer
Hi! i got my sunbeam thru e bay i have noticed that the beaters are not as sturdy compared to the one i have which i have been using every for the last 10 years. i have been using it only for a few weeks and now every time i turn it on the speed changes by itself. i am so frustrated because they dont sell it here in my country(philippines) i had to order it on line and its already deffective.
  • Sunbeam Master
  • 17,129 Answers
Yes the one that are marketed on line do not measure up the standards as they are bought mainly on the price comparison. so the quality suffers a bit due to which the such issues do come up.
This is due to poor fitting of the unit , the poor switches and the motor assembly.
The speed is changing due to the poor quality of the switch and all what can be done is to keep it in position.
You can also make a complaint to Ebay asking for a replacement or action.
Posted on Oct 01, 2010
How do the beaters get inserted into a sunbeam mixmaster mma? Was recently given one to use...no manual...
The beaters are inserted into the appropriate openings and pressed in until they lock in place.
Dec 25, 2016 | Sunbeam Food Mixers
Sunbeam beaters hitting each other
Check with Sunbeam. The beaters may have to be replaced.
Dec 11, 2013 | Cuisinart Food Mixers
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Beater keeps falling out. The plastic thing at the top of the beater inside the mixer needs to be replaced. Where can I get the part?
Sunbeam 2366 stand mixer -- Front view: mixer-0-small.JPG -- 0d345a3.jpg-- image of the "beater clip": mixer-1-small.JPG -- notice the wear on the plastic clip --8982711.jpg -- image of the "modified" beater: mixer-2-small.JPG - I took a paper clip an wound very tightly to the smallest diameter (notice it covers the entire section to prevent slippage) and then put one wrap around the "top knot" to increase diameter --d67ddea.jpg -- image of the back of the front cover: mixer-3-small.JPG - notice the broken clip at the top. I used a wide scrapper blade to separate the cover from the main body. 3297c2c.jpg----
Oct 16, 2008 | Sunbeam 2366 MixMaster Series Hand/Stand...
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Jul 18, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Stand Mixer
For whatever reason, Sunbeam must have decided to cut on costs and used a plastic gear to transfer power to the beater. I had my Sunbeam for two years and the plastic gear decided to break. End of mixer. You cannot find a replacement part anywhere. It is the last sunbeam I will buy.
Dec 02, 2007 | Sunbeam 2350 Heritage Series Mixer
Sunbeam 2484 Beaters won't stay engaged.
In taking apart my same beater, I'm trying to figure out the alignment of the spring which provides the tension so that the beaters won't fall out. I'd assume that your spring has mis-aligned. You need to take it apart (3 Philips screws), and carefully pull the assembly apart. I'll bet your spring falls out like mine did. I'm trying to find a schematic from Sunbeam to see how the spring should align.
Nov 19, 2007 | Sunbeam 200 Watts 2484 Hand Mixer
Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Nov 12, 2006 | Sunbeam 2485 MixMaster Series Hand Mixer
Sunbeam 2350 Heritage Series Mixer Logo
149 people viewed this question
Top Sunbeam Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Tony Vallette
Tony Vallette
Level 1 Expert
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
