Question about LG Flatron L1919S LCD Monitor
At start my monitor is flashing 4-5 minutes...what can i do?
  • Louis Ebert Sep 30, 2010
    retrevo .com lists unit as "time to retire"... If that not option for you then need to explore the possibility of a less than $20 DIY fix. You need to state exactly what you see or don't see on lcd screen when you push the "ON/OFF" button!!! What exactly is "flashing? The screen or the "on/off" button? Is unit connected to a "known good" pc that is fully booted with all "screen saver" "power save" modes disabled? Will the "flashing" stop after 5 minutes and display the WIN-desktop and icons? or does screen remain black or black n blank? 12fixlouie
  • 11,361 Answers
That may be the indication of failing power supply or th ebcaklight inverter circuits, those are the two areas you need to check.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 30, 2010
How to reset time and date on omronhem790itcan
SETTING THE DATE AND TIME
RESETTING THE DATE AND TIME
To adjust the date or time after it has been setup when you first use
the unit.
Start with the monitor in the of f position.
1. Press and hold the SET button.
The TruRead
will appear on the display for the USER ID selected.
To change the on or oFF setting press the Memory button, then press
the SET button.
The interval time flashes on the display. Press the Memory button to
select the desired interval time, then press the SET button.
The year flashes on the display.
2. Refer to page 19, SETTING THE DATE AND TIME.
NOTE: If you need to change the Date and Time, always adjust the
Date and Time setting before taking the next measurement
Set the monitor to the current date and time before taking a
measurement for the first time. If the date and time are not set correctly ,
the measurement values stored in the memory and the average values
may not be correct.
The Blood Pressure Monitor automatically stores up to 84 individual
measurements values with the dates and times. The monitor also
calculates weekly averages for measurements in the morning and in the
evening. Morning and Evening averages are stored for this week and the
last seven weeks.
The monitor can also calculate an average reading based on the three
most recent measurements taken within 10 minutes of the last reading.
NOTE:
• If only two readings are stored in the memory for the 10-
minute period, the average is based on the two readings.
• If one reading is stored in the memory for the 10-minute
period, this reading is displayed as the average.
1. TO START THE SETTING
Press and hold the SET button to
adjust the date and time.
2. SETTING THE YEAR
The year can be set between 2007 and
2030. When the display reaches 2030,
it will return to 2007.
Press the Memory button (
advance by increments of one year.
Press the SET button to set the current
year.
The month flashes on the display.
NOTE: Press and hold the Memory button (
to advance the date and time values faster .
3. SETTING THE MONTH
month.
Press the SET button to set the current month.
The day flashes on the display.
4. SETTING THE DAY
Press the SET button to set the current day.
The hour flashes on the display.
5. SETTING THE HOUR
The time is set using AM or PM.
Press the SET button to set the current hour.
The minute flashes on the display.
6. SETTING THE MINUTE
one minute.
Press the SET button to set the minute setting.
7. TO TURN THE MONITOR OFF
Press the START/STOP button.
NOTE: The monitor will automatically turn of f after the minute has
been set after battery replacement
sourcehttps://www.manualslib.com/manual/759601/Omron-Hem-790itcan.html?page=20#manual
Feb 08, 2018 | Time Computers & Internet
HOW DO I SET MONTH DAY AND TIME WITH BP3MW1-1W 800229
Below are the Date and Time setting instructions for a similar model: OMRON BP742
http://omronhealthcare.com/products/5-series-upper-arm-blood-pressure-monitor-bp742/
Set the monitor to the current date and time before taking a measurement for the first time. If the date and time are not set correctly, the measurement values stored in the memory and the average values may not be correct.
Press the Date/Time Setting button ( ) to adjust the date and time.
2. SETTING THE YEAR
The year can be set between 2010 and 2040. When the
display reaches 2040, it will return to 2010.
Press the Up button ( ) to advance by one year.
Press the Date/Time Setting button ( ) to set the current
year.
NOTES:
• Press the Down button ( ) to decrease the date and time values.
• Press and hold the button to increase or decrease the date and time values faster.
Press the Up button ( ) to advance by one month.
Press the Date/Time Setting button ( ) to set the current month.
4. SETTING THE DAY
Press the Up button ( ) to advance by one day.
day.
5. SETTING THE HOUR
Press the Up button ( ) to advance by one hour.
Press the Date/Time Setting button ( ) to set the current hour.
Press the Up button ( ) to advance by one minute.
Press the Date/Time Setting button ( ) to set the minute setting.
NOTE:
The monitor will automatically turn off five minutes after the minute has been set
SOURCE (PDF User Instruction Manual):
http://omronhealthcare.com/wp-content/uploads/BP742_IM.pdf
Jan 03, 2015 | Health & Beauty
Lcd monitor is flashing on & off
This monitor is expeicencing a defect on the backlight and the assembly behind it. The backlight may need replacing or you could just buy another monitor.
Hope this helps.
Mar 15, 2010 | Acer AL1916W 19" LCD Monitor
I have 2 monitors connected to 1 computer using a
satservice, What happens AFTER 15 min of FLASHING?? What did unit do or act like 3-4 weeks ago? Is the screen both BLACK and BLANK? or is screen just black and you can SEE win-desktop if you shine a bright flashlight 1 inch from screen at differnt angles? Can you use your Samsung warranty? Will monitor do same when connected to different KNOWN GOOD prebooted to desktop PC? Are you refering to the "power ON" indicator light on front BEZEL as the FLASHING thing? Need more info, but I suspect "shutdown of units "switch-mode-power-supply" due to detection of FAULT CONDITION having been detected with other circuit or with itself. Read some of my other responses in my fixya profile that deal with BLACK SCREEN repair. If this response useful, rate on fixya. 12fixlouie
Dec 19, 2009 | Samsung Computers & Internet
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Monitor flashes on start up
if the video flashes for a few minutes and then stabilizes, this fix will probably be what you need to do:
http://www.alexdemo.site90.com/#samsung2232bw_fix
Nov 08, 2009 | Samsung 226BW Monitor
Monitor power light is blinking .but monitor is not displaying anything after 4 hr monitor blinking light is become slow and when restart the monitor is displaying after 4 hr please help me i have a 20.1...
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact manufacturer to find out a service point.
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Oct 15, 2008 | Westinghouse LTV20V2 20 in. EDTV-Ready LCD...
Flashing on and off
I would suggest trying another monitor to rule out your PC or monitor card. I would also check the video settings on the PC. Then assuming your cable/connector and video card are okay, it sounds like a lamp or lamp driver (a.k.a. ballast or inverter) issue. In other words, an internal issue that probably needs component-level troubleshooting.
Jan 08, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Monitor
Unplug the monitor from the back of the computer and keep it powered on . If the problem is encountered again. Try reseting the monitor . If the same does not help you need to replace the monitor.
Additional help can be found in the following link.
http://support.dell.com/support/edocs/monitors/1706FPSF/EN/solve.htm#General%20Problems
Oct 20, 2006 | Dell E176FP 17" LCD Monitor
LG Flatron L1919S LCD Monitor Logo
74 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
