Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
How do I know if my jet pump is going bad? It's at least 16 years old, and it can't handle the flow demand of a shower and a washing machine at the same time. It will drop pressure to the point where it can't recover on it's own and I must prime it to get the pressure up before I open up the valve to pressurize the whole system. The bladder tank is just as old as the pump, it is pressurized at 2 lbs. below the pump start-up pressure which is on at 30 off at 50.
  • 518 Answers
I had similar problems it ended up being the shallow well it self. It did not have enough gallons per minute of flow to keep enough water flowing to allow pump to function properly. Some well drilling companies can clean out well or vanes to allow well to flow properly. Otherwise you will most likely need to drill a newer deeper well.
Posted on Sep 30, 2010
Testimonial: "Thanks, I'll look into having the well drilled deeper."
  • Andrew Bugbee Jul 17, 2011
    Your tank pressure should be set at 2 lbs below your cut in pressure setting on the pressure switch. That means you should have 28 lbs press. in your tank. The diaphragm in the tank is probably bad. Seeing as your pump is 16 years old then it might be a good idea to change that as well. A 1hp pump is not much more than a 1/2hp pump and can deliver more water at higher pressures so you may want to upgrade. Also consider increasing the size of your tank. The benefit of a larger tank is two fold. If there is a power outage a bigger tank will deliver more water even with no power because of extra storage capacity. Also, you want your pump run time to be at least one minute. Pumps like to run. They don't like to turn on and off so if you have a bigger tank the pump will run longer to fill it. I also suggest you change your press. switch setting to 40/60, or 50/70. The pipes in your house can easily handle this higher press, but don't go over 70 as it may cause your water heater press relief valve to blow off. Remember to increase the press. in your tank to 2 lbs below your cut in press.(the low number on the press switch setting.) Good luck!
How to fit shower body jets
If you have good water pressure in your home and a tank water heater and not a tank-less, as long as all jets are space equally apart you should not have pressure issues. but running straight to a jet and splitting off from that point will cause a rapid loss in pressure to the other jets because the lack of resistance.
Fluid pressure is created by resistance to flow, not gpm (gallons per minute). If you flush a toilet and a faucet in another part of your home is reduced greatly you have a volume problem were the city water or well water is not supplying enough volume to your home and the multiple jets will not function correctly.
Tank-less water heaters have difficult times keeping up with the demand multiple faucets create.
Both problems have work arounds and fixes but it is best to get a certified plumper to install the components you would need
Jul 20, 2010 | Rohl Shower I00124 Ocean 4 Matching Twin...
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
We have two 16 year old shower faucets (house was built in 1993 by Del Webb). Can't tell what model they are. We are guessing they are Moen Legend 3175 (one handle). Problem seems to be pressure balancing...
This is a common problem with this type of shower mixer valve. They are not very good at regulating with pressure change. Your options are somewhat limited to not flushing the toilet or using any other taps when in use, repalce the mixer valve for a modern ceramic unit or installing a 2 vane hot & cold shower pump.
Nov 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Jul 20, 2009 | Delta & Single Handle Shower Faucet
Shower leaks very bad when turned on. Water sprays out from behind each knob and from behind the valve plate. Then after about a minute water starts to come out from underneath the one peice shower stall....
there is a problem with the rubber washer or bushing. it may be brittle since it has not been used for a long time. remove the handle then assymbly to locate the rubber washers, the washer seals the flow of water.
Jul 17, 2009 | Washing Machines
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Hot water problem
Someone has not sized the system correctly. The water heater will heat a certain GPM a certain temperature rise. Most of those "generalizations" from the manufacturers are referencing the lowest of all the flow requirements like 2 lavatories. The truth is, don't use other fixtures while showering or get a bigger system. Lots of information related to sizing the tankless system at http://www.mechanicalengineeronline.com/Mini_Sites/Tankless_Water_Heaters_Ebook/Tankless_Water_Heaters.htm Have a good one. PS:Properly sized On-Demand water heaters are actually really good. Be prepared for the day your water heater quits.
Mar 11, 2009 | Bosch & Tankless LP Hot Water Heater
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Aug 30, 2008 | Home
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
1,033 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
