Question about Kenmore Refrigerators
We have new Kenmore ref. We run both ref.and freezer on # 3 have home on 77 It appears my Ref. runs too much it stays on like 17 min and off 23 min My old ref did not run this much .Is there something wrong with unit. It is approx. 3Wks old Ted
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
Ted, there may be a difference between the two systems as you have observed. The designs are different from refrigerator to refrigerator and with the Kenmore, you're also dealing with multiple manufacturers. So, you can have a LG, Whirlpool, Frigidaire, Maytag, Samsung, etc. Kenmore doesn't manufacture any major appliances - they just stick their label on the front. I would keep an eye on it but the main thing is the temperature regulation. If it's regulating at the proper temperature I wouldn't worry about it.
Rich
Western Appliance Repair
Appliance Repair Meridian
Posted on Sep 30, 2010
The blower motor for the refrigerator compartment does not run
Some ge fridges have a control board on back that works fan. Also some go through the bi-metal on the defrost, but that's mainly older side by sides and bottom mounts
Sep 07, 2012 | Kenmore Top Freezer Refrigerator
My kenmore is leaking water once a day .
You didn't say from where. Usually twice a day your de-ice heating coils come on and melt any ice that has accumulated. this water usually runs down the back of the ref. and collects in a small pan under the ref. Someime ice form around the hole that the water drains down through to go into the small pan. so then when the deicer comes on the water just runs down the bottom of the ref and onto the floor. My Kenmore does the same thing. Remove everything from the bottom of the Freezer look in the back at the bottom see if hole is clogged with ice. Remove ice then pour hot water down hole check occasionally.
Aug 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer staying frozen fridge not cooling
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 09, 2009 | Kenmore 73503 Stainless Steel Bottom...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Freezer works fine but fridge side stays at about 45 degrees
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Jan 10, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Freezer gets cold, Refrigerator Hot
check your control setting. You can't see the door but, you should be able to feel air coming through the channel on the Ref side.
This is a failure of the defrost system which consist of the defrost timer, heater, and thermo disc.
Also, If you replaced the evaporator fan then you got a good look at the cooling coils. Look at these coils while it is running. There should be a light coat of frost on all the coils. If this frost line is only 3/4 or 1/2 or any amount less than full coverage of the coils then the system has a coolant leak.
Directly under these coils is the drain pan and drain hole in the middle. This area should be clear of any ice or debris.
Dec 25, 2008 | Kenmore Refrigerators
Refrigerator/freezer not staying cool
If there is no frost on the freezer side it may be low on coolant.
Dec 03, 2008 | Admiral 26 cu. ft. Side-By-Side...
Kenmore bottom Freezer 795.75212402
there are many reasons why a ref stops working, you have not given any symptoms of what happened before it stopped working. The best solution is to call Sears and purchase a "service smart agreement" which will cover repairs up to $500 per repair for a year. there are other details to the agreement. the cost is about $240, but it's the best thing going.
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE SideBySide Ref GSS25VGMD WW
if temps are ok, i honestly don't think you have a problem
Jun 04, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
