Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
The spinning cycle gets rid of all the water but the clothing are still extremely damp. What's part do I need to buy to fix it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
I here this complaint often and I find transmission slippage to be often the problem. It needs to get into the "high speed" spin. Tilt the machine against the wall, while holding the inner basket stationary with one hand, rotate the pulley counter clockwise and see if you have slippage. If you do, repeat the same procedure again without holding the basket and look to see if the brake is disengaging. If the brake is not disengaging then replace the thrust bearing assembly. If it is disengaging, then your likely cause is the tranny. Hope this helps,
Rich
Western Appliance Repair of Meridian
Washing Machine Repair
Posted on Sep 30, 2010
Clothes are wet after spin cycle
U need a technician for that... there is a problem with the "flow valve" sorry can't help u out much with that... but maybe u can visit this site and hit the like button... www.facebook.com/muktidayasewa
Jan 13, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
My washing machine isn't getting rid of all the water during the last spin cycle. The clothes are still very wet when it is done. I run the spin cycle more and it only rids a little water from the...
Behind the washer is a plastic hose that enter the drain.Make sure that nothing is pinching it closed.You can also use drain cleaner in the drain but not in the machine.
May 12, 2011 | Washing Machines
In the permanent press cycle only the spin cycle isn't spinning enough. Clothes are extremely wet must run another spin to get out the water.
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
Aug 07, 2010 | Washing Machines
My GE profile WPDH8800J doesn't hit high speed
Your belt may be slipping and not spinning the drum to full speed to rid most of the water in clothes.
Sep 09, 2017 | General Electric WPDH8800J Front Load...
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
GE Washer does not reach full spin speed...stops abruptly
HI thanks for your question. the G E washer has to get rid of all the water before it starts to spin. check to see if you have a good water flow on pump out. if not clean the pump . thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | GE Washing Machines
Damp and piled up clothes at the end of each cycle
Good Day.... I feel for you... Unknowingly,When they purchase it. Many people have the same experience in finding service for products such as your experiencing.
Of course, it's our hope and belief, it's not ever going to have a problem, some people are lucky. Me neither... mine is in computers... but that's another story.. Just believe me, I understand ... but I'm going to try to help... why I picked up this call, is because I find it to be interesting, about the comment about the clothes gathering into a ball... Generally, that happens in relationship to the amount of water, inside or lack of it. If the clothes are in a ball, that's why they're coming out wet. Nobody makes a washer that can do that.
I want you to check the drain line...(that's the hose to water uses to exit) Is the hose at any point, higher than the top of the machine (it's supposed to be) ... if not siphoning may be occurring.
Also check to drain hose at the inlet, where the hose goes into the wall.. it must allow air to get in here as well. I have experienced some indifferent situations before, if the hose in stuffed into the stand-pipe, or taped,glued, sealed.. if there is no vacuum break (meaning-place in which air can enter) that to can create a siphon. Ge was known for having a washer that made the kind of bang you describe. It was their normal method for stopping the clothes basket from spinning forever. I hope this answer works for you, otherwise resolving may continue to be difficult. One piece of information you'll have received, is what you will and won't recommend to buy when you hear others having conversation on buying a major Appliance. Sometimes it's all we can do... I wish you best... dean
Feb 25, 2008 | Haier XQJ50-31 Top Load Washer
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
697 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
