Question about Kitchen Ranges
Circuit Diagram for Carlsbro Gamma 100/205 Active Speaker
Carlsbro instruction manuals
do you own the amp? then as the owner you should have one.Google it.
May 21, 2014 | Radio Communications
Carlsbro gamma 15 400 internal amplifier
I'm not familiar with your exact product, but Parts Express sells all sorts of replacement in-speaker amplifiers. I've replaced several powered subwoofer amplifiers with their products, and the customers usually report-back that it sounds better than when new. You might want to check them out, and see if they have one that will fit.
Apr 23, 2013 | Audio Players & Recorders
Carlsbro Bass Reactor 400 bass amp - power section dead
• Could be drive transistor , output transistor or both on the main amp.
But check for power supply and in the preamps also.
• A signal tracer will come in handy when troubleshooting these kind
of symptoms.
• Measure supply voltages,
• Check offset voltage
• Check idling current
Isolate , and trace afterwards.
• Schematic is really needed when there are burnt and unrecognizable
component. But one can use similar schematics to analyze circuit
problem.
Aug 01, 2012 | Audio Players & Recorders
Connect a mic mixer to a powered mixer
What kind of output does the mini mixer have? If may not have enough to input your Carlsbro PA
Nov 16, 2011 | Radio Communications
Left output ports for both left and right channels do not work
Hi, first thing to do is to check the power supply look for a larger capacitor & using voltmeter measure both sides from ground to positive & ground to negative. Next check the speaker protection circuit if active. If not active measure the voltage from ground to the speaker output before the relay of speaker protection device. The voltage should be zero or close to zero volt. If more then the power transistor or power IC is toasted.
Aug 10, 2009 | Cambridge Audio Azur 540A Amplifier
TV Circuit board diagram
My SONY TV Model : KV-XJ29M50. LED will blink/flash twice right after power turn on and cannot display picture.
May 17, 2008 | Televison & Video
Kitchen Ranges Logo
97 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
