Question about Fein Multimaster Rs - Msxe 636 - 2 Rs
A friend who bought a multimaster less than a year ago has had his start a loud 'clattering', dry, noise, and the gearbox started to get hot. The output shaft now has about the same amount of slop as the total movement should be. It is one of the quick attach type. I bought one of the allen key attach type, and have found in the past with various 'name brand' tools, drills, angle grinders etc that they usually use a 'dry' type grease which soon throws off the necessary parts and they run dry until colapse. I wish to open the gearbox and use a quality 'teflon' based grease or similar to prolong its life. How does the gearbox come apart please?
  • 490 Answers
Fein is an excellent tool and has an excellent warranty that will be void the moment you open the gearbox. I do not recommend this action. Fein is quick and responsive, especially for a less than one year issue. Farmerbear at FixYa.com
Posted on Sep 30, 2010
  • grubz253 Oct 02, 2010
    Thanks for the advice, point taken.
    It is just frustrating though when something as simple as the lubricant can make so much difference to the life of the machine.
    Thanks again.
Why is my central vac. making such a loud noise. It sounds like jet getting ready for take off. It seems to be getting louder. I'm not using it because i'm afraid it's going to explode or...
The bearing or the motor is warn out they last 15 years in the case. In some rare case the brush ware out or the rely can catch fire, most central vacuum are not made to be oiled! Hot oil will catch on fire. Best to unplug the vacuum unit call a few shops and ask replacement motor cost, if you remove the Vac and take to them it will cost less.
Jun 25, 2011 | Vacuums
My dyson C07 ANIMAL is making a loud clatter noise when I push the head down. I have removed the sole plate and the brush bar is cracked so I removed it, but I understand the clutch maybe a problem also...
The noise is likely the clutch if you have a cracked brush bar. If so replace the brush bar, also replace the belts in the clutch or the clutch if the belts are stretched out.
Sep 12, 2017 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have the same problem as discussed above. My Hoover Pet Cyclonic upright stops working while using it. The bottom feels hot when this happens. When it first occurred, I emptied the canister and even...
The vacuum is probably getting hot and the thermal sensor in the motor is shutting it off and then allowing it to come back on after it cools down. You mentioned replacing the secondary filters, replace the exhaust filter too.
If replacing all the filters did not solve it you may have a clog or restriction somewhere causing the loss of suction and the overheating.
Mar 09, 2017 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
While using my mutimaster it started going slow and got very hot
Hello. Regularly blow out the interior of the power tool from outside via the ventilation
openings with dry, oil-free compressed air;
always wear eye protection when doing this.
Most likely, your tool has debris inside which is preventing the normal cooling from occurring. J.
Jul 22, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Wind tunnel supreme sounds very loud
Sounds like a bad motor, you have a years warranty on this, take it in for warranty repair. You will void the warranty if you mess with it.
May 08, 2008 | Vacuums
Load noise at start-up goes away after a minute, but there is no suction.
If the brush roll and motor runs and sounds ok, then that is an indication of a clog, either in the hose or the dirt inlet down by the brush roll. You should have a years warranty on this, if you can't figure it out, then take it into Sears and get it repaired.
Apr 15, 2008 | Kenmore 31913 Progressive Direct Drive...
Dyson Animal DC07 making a horrible noise!
Ensure plug is not in the socket.
remove the guard from around the roller on base of Dyson by turning 3 screws 90 Deg anti clock wise.
unclip belt from the metal spindle from the motor.
Pull out the roller.
Pull the end of the roller out.
They do not screw, they just pull out.
Clean the muck out from inside the roller ends.
Put end caps back on.
put belt on and thread through the slot.
put belt back on to motor spindle.
Ta da it stops squeeling.
Oct 16, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Not oscillating
Hope this helps!
Inside the gearbox there is what should be a 2 pronged fork you may only be able to see 1 of these the other may be broken, the fork goes each side of the armature bearing. If the fork isnt broke it may be the armature bearing that fits inside the fork.
Hope that helps. Sean
Jul 26, 2007 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Fein Multimaster Rs - Msxe 636 - 2 Rs Logo
216 people viewed this question
Top Fein Vacuums Experts
Bill Boyd
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
