Question about ASUS AMD 761 Chipset A7M266 (A7M266/550/WOL/2DIM) Motherboard
Network interface card was working fine. it just quit working and i have no lights on it now. i have already tryed a brand new card and still have the same problem.
    President:
  • 1,851 Answers
Have you checked the ethernet cable (both sides)? If there is a cut, the lights are not active. Either try this cable at another pc, or try another cable at this pc.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 30, 2010
My HTC wildfire s can not detect sim card I already tried restarting and factory reset
Try the SIM card in a friend's phone.
Try a friend's SIM card in your phone.
Feb 24, 2015 | HTC Wildfire S Smartphone
Most any standard PCI NIC will work for you, as long as you have an available port on your PC. Here is one from newegg.com at a great price. It's a Rosewill and I've bought that brand often.
Rosewill RC 404 Ethernet Card 10 100 1000Mbps PCI 1 RJ45
Jan 28, 2014 | Acer Aspire AM5641-U5520A PC Desktop
Hp network interface not working
the card may be faulty or not installed correctly. go over the connection and make sure everything is installed correctly. if that doesn't work, try a new card.
Apr 06, 2013 | HP LaserJet P4015N Printer
Network card gateway 830gm
Well, you most likely will have to replace the network card, as you already know.
If your network connection is part of the motherboard, disable that one and plug in a new network interface card.
They are fairly plug and play....
Sep 21, 2009 | Gateway 830GM PC Desktop
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
My gateway gt5432 wireless interface is not working
Go into the device manager and uninstall (right click and choose uninstall) the network card, reinstall it by chooseing actions, scan for hardware changes (in the device manager). Its an Ip address conflict probably. or open a command screen by typing cmd in the run dialog and then type ipconfig at the curser. See if you have an Ip address, if not type in ipconfig "space" /renew. This will give your computer a new ip addy. Good Luck!
Mar 21, 2009 | Gateway Computers & Internet
Can two legs of a router be configured to be in the same subnet?
Yes, the route table won't like the same subnet on two interfaces. I'm not sure if this would work if you didn't have "ip routing" configured... you could try turning off "ip cef" too... but i've never been able to do this on a real router.
Other option on a real router is to put both interfaces in "bridge" mode, or configure the second interface to clone the details from the first... although i've only ever done this with Dialer interfaces before.
So I guess the answer is yes... the router wants to put the route to the subnet in its route table (show ip route) and if you have two interfaces both with the same subnet, the route-path costs would be equal and identical... which is a huge issue in a networking environment.
Your PC doesn't care... it's not really routing. It's quite common to do this with a PC for the purposes of doubling bandwidth, load balancing, or having redundant links. (on the switch you would need to configure a "port-channel" to bond two ports together.)
Cheers!
Feb 04, 2009 | 3Com Computers & Internet
Wi Fi fine, ISP fine, no internet via LAN connection though.
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
Jan 21, 2008 | NetGear DG834G Router
Wireless connection
What router brand/model do you have. Is it set up to broadcast it's SSID? Has encryption been enabled on the router?
Have you used Device Manager to make sure the new wireless card is operating properly.
I hope you'll answer these questions and let me try to help before you rate this...
Jan 03, 2008 | Belkin Desktop Card Network Adapter
Locked up
have you tried it with another card? If so then your problem is the zyxel card which I would say stop using. The fact is Zyxel does not make these things they roll off lots of these cards in China and Taiwan and companies put their brands on them, so you are never quite sure of the quality. and yes this is with the majority of these cards. Some companies have better quality control then others and some don't I would say to return this card and exchange it for another one. You might get one that works. That's all I have to say.
Sep 13, 2007 | Zyxel M-302 (M302) 802.11g/b Wireless...
ASUS AMD 761 Chipset A7M266 (A7M266/550/WOL/2DIM) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
