Question about iiyama Pro Lite 38a Monitor
After a power down of the powersupply (disconnect from the mains), the blacklevel setting, R-G-B gain and offset (in service menu) and the English menu language setting are lost. As long as the powersupply is connected to live mains, the settings remain, also after a set power off-on. My conclusion: the Eprom is defect My question: how to replace the Eprom (typenumber and location inside the monitor). I have an smd solder iron.
    Top Expert:
  • iiyama Master
  • 75,117 Answers
Your conclusion is as good as any guess I would endeavor to give.
Posted on Jul 06, 2017
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: On unpluging the monitor (Iiyama Prolite e435s)all
When you have strange symptom like this, the first place to look will be the power supply section, look for bad caps (leaking/bulging tops) first.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 07, 2010
Geek Squad broke my Television
Try these settings:
Picture Mode: Movie
Contrast: 100
Brightness: 44
Sharpness: 20
Color: 50
Tint: 50
Backlight: 7
Color Tone Warm1
Digital NR Auto
Detailed Settings
Black Adjust Low
Dynamic Contrast Low
Gamma -1
Color Space Auto
Edge Enhancement On
xvYCC Off
White Balance
R-Offset 21
G-Offset 20
B-Offset 21
R-Gain 0
G-Gain 21
B-Gain 26
My Color Control
Pink 20
Green 15
Blue 15
White 15
Auto Motion Plus 120hz: Low
Feb 28, 2014 | Samsung UN55C6500VFXZA 55in Led Hdtv 1080p...
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
I have a apple ipod A1199 my little brother got a hold of it now its in some forien language that i cant read how do i get the menue to read american again?
No problem, you'll just need to do a full reset to restore the language to English.
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
Feb 28, 2011 | Apple iPod Photo MP3 Player
LANGUAGE IS NOT ENGLISH
It was your setting. You can change it to english.
For sansa clip:
1. From main menu, select settings (picture with 4 bars)
2. Use up/down button to find " FM...", the language option is right about FM..., select it and use up / down button to find English.
3. Press home button to come back main menu
Good luck
For sansa clip plus:
1. the same as about.
2. Getting into Settings, you have 4 options (Music, Audiobook, Radio, and System Settings). Languages with letters (a, b, c, ....), you can see "Radio...." option, move the selection bar down 1 - it is System Settings. If Languages without letters a, b, c, ...., you have to get in to each option, at each option you move the selection bar down or up to find letters " USB...." , it means you are inside System Settings, from USB, press down button 6 times, and select it (language option), scroll up/ down to select English.
3. The same
Good luck
Feb 04, 2010 | SanDisk Sansa Clip MP3 Player
Tip
Change iPod Language
Disconnect your iPod from your computer, then press the Menu button until the menu title says "iPod," regardless of the language displayed. This means you are at the main menu.
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
on Feb 10, 2008 | Apple iPod MA446LL/A MP3 Player
Sony cybershot dsc-w270 japanese to english settings??
Press the MENU button to bring up the main menu. Use cursor-down to select Settings (toolbox icon) and press * in the center of the cursor pad. Use cursor-up/down to select Main Settings (wrench and hammer icon), press cursor-right, and then *. Select the second item on this menu.
Dec 14, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
I have a samsung hd crt that I bought in the US. I have it connected to my sky hd box but I will only show a 520 image and the image is offset. Why will not show a 720 image, without it being offset
Dear sir,
Here is the some settings for best view in Samsung HDTV
try this
Picture menu
Mode: Movie
Cell Light: 10
Contrast: 84
Brightness: 54
Sharpness: 0
Color: 54
Tint: G50/R50
Advanced settings submenu
Black tone: Off
Dynamic contrast: Off
Gamma: -1
Color space: Auto
Flesh tone: 0
Edge enhancement: Off
xvYCC: Off
Set the offset as per your requirement
White balance submenu
R-Offset: 24
G-Offset: 25
B-Offset: 25
R-Gain: 29
G-Gain: 20
B-Gain: 19
Picture options submenu
Color tone: Warm2
Digital NR: Off
HDMI black level: Normal [grayed out]
1080 Full HD Motion Demo: Off
Film mode: Auto1*
Blue only mode: Off
--Setup menu
Game Mode: Off
Energy saving: Off
i think it helped.
if you have any problem regarding this issue,leave a feedback we will glad to assist you
Have a nice day
good luck.
Sep 12, 2009 | Samsung Televison & Video
My phone is set in Italian. How do I change the
My phone is set in Italian. How do I change the language to English?
Jul 06, 2009 | Cell Phones
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
iiyama Pro Lite 38a Monitor Logo
76 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Ed Mac
steve morris
steve morris
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
