Question about HP Pavilion dv8000t Notebook
HP dv8000 crashed last year
Hubby didn't help by formatting the HD's (Dual harddrives).. Turns on but of course has no OS and can't do much... Then turns off after being on for a few mins... When turned on goes past the invent screen then goes into the c prompt and all you see is the following:
Intel UNDI, PXE-2.0 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13 (020326)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM.
Just keeps cycling through that screen over and over...
  • mistress166 May 25, 2008
    What are my options?
  • mistress166 May 27, 2008
    It's back up and running thanks to your advice, now the problem stands that I need a new fan.... It's overheating and shutting the comp down... Had to put it on top of the a/c vent last night to get XP back on it and to get it back up and running to where it's almost complete... But for now it's off and awaiting a fan install....
    Scholar:
  • 110 Answers
It's trying to boot from the LAN. Don't ask me why but it's got it into it's little brain that it needs to boot from the LAN before anything else. When it can't get a valid operating system image over the network, it gives up and reboots with that error message.
Happily the solution is pretty simple. Go into the bios by tapping F10 when you first turn the power on. From there go to the System Configuration, and into the Boot Options. If you still don't have a viable operating system, it's necessary to set the CD Rom as the first boot device, so it will read a Windows disk. Makes sure CD-ROM Boot is set to Enabled and Network Adapter Boot is set to DISABLED. Then set the boot devices in the following order:
ATAPI CD/DVD Rom Drive
Notebook Hard Drive
- all the other options can be in any order, just make sure these two are at the top.
Pop in a Windows disk or your system restore disk and it should go through fine.
Posted on May 26, 2008
You need to tear it apart down to the heat sync and then remove the processor cover and get the crusted thermal glue off of the processor i had the same problem and then put it all back together should be good you can probably run it w/o any thermal glue
Posted on Jun 20, 2009
3 Suggested Answers
  • 81 Answers
SOURCE: windows dont come up.
I had this happen to me before with an IBM laptop. I bought a new hard drive, reinstalled a fresh OS, and had no more problems after that. I also went right to ibm website and did all the updates, as well as all the microsoft updates. So my same problem as your ended up being a bad hard drive. maybe check into that?.
Posted on May 30, 2008
  • 3278 Answers
SOURCE: wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Posted on Nov 26, 2009
HP vp17 screen is turned blue How to get back the colours?
I recommend you check the signal cable plug (from the monitor) is fully inserted into the PC.
Jun 10, 2014 | Computers & Internet
How to reformat a probook 6570b
To format the harddrive turn on the computer and press start find computer and right click the drive you want to reformat and then click Format...
Nov 26, 2013 | HP ProBook 6570b laptop
Mouse was unexpected lost and reboot restart was crashed.
Restart pressing the F8 key then click on "Last known good configuration". If this doesn't work try saving your stuff because you are going to have to try loading your OS on the harddrive (as long as the harddrive is good.)
Mar 06, 2011 | Sony VAIO VPCF13PFX/B Laptop
Having issues with Acer Aspire 5810TZ-4238, Computer saying NTLDR is missing, Press Ctrl + Alt + Del to restart, I did this two or three times it did not work. I took my three restoration Disks out and...
If you are recovering to a new harddrive, because your original HD crashed or is about to crash or can't boot, then find a tool (GPartEd is free and works) to format the entire disk to an NTFS partition. If you want to split the partition to OS and "other", Windows 7 Home premium 64-bit needs at least 100Gb. Basically: PRE-PARTITION before trying to restore to a new HD. To me, these other answers are misleading.
Dec 19, 2010 | Acer Aspire 7110-2069 Notebook
Multiple hard crashes. reformated hd. near end of os load, got "hard error" message. Looking for concurrence of HD being shot or could it be other problem. CD
When this happens it is always the hard drive going.gone faulty. I recommend you replace the hard drive. But first, try a full format, from a Boot CD/DVD, that can be used to format, like Partition Magic, or get UBCD, this too has formatting tools, try that one last thing before giving up and getting a new drive.
www.ultimatebootcd.com/
Feb 26, 2010 | Dell Dimension 4600 PC Desktop
Toshiba external harddrive recovery HELP!
Well, formatting(generally quick format or complete format) won't make the data erased permanently. In your case the MOST effective way is to try some so-called data recovery software.
First of ALL - Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem! Remember - Always make Backups of your precious data!
Nov 30, 2009 | Computers & Internet
How about this Pavilion dv8000 Battery for HP Laptop Battery?
You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
Jun 02, 2009 | HP Computers & Internet
My HP DV8000 will not play DVD's anymore
i guess you need to replace the DVD player now. it may not show any damaged sign on the out side. the laser inside of the dvd player most likely suffered damage.
Dec 03, 2008 | Computers & Internet
HP DV1000
Dear,
Please create new partition through FDISK and relaod fresh OS. This will work perfectly.
takecare
Baliram
India
Feb 23, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv8000t Notebook Logo
460 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
