Question about Nokia 6230i Cellular Phone
No ringtone no sound in speaker . i can receive call
    Sergeant:
  • 193 Answers
Your ringing speaker may get damaged.You can open the cover of your phone and just press hardly where the ringing speaker is situated.Then check with any ringing tone if the ringing speaker is working or not.If its work you can contact a mobile phone service center and tell him to clean the connection of your ringing speaker and mother board.
Or you need to change the speaker to get rid of it
Posted on Sep 30, 2010
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    My blackberry bolds ringtones dont work all it does is viberate
    Make sure the speaker phone works. play the ringtones in the media folders if they play your phone's speaker is good, if they dont your speaker is bad.
    If the speaker is good then go to the sound profiles and advanced to edit the profile of your choice... make sure it is the one you are using. Make sure it is set with ringtone volume play sound always
    Feb 20, 2010 | RIM BlackBerry Bold 9000 Smartphone
    Make My Sound A Ringtone
    The Solution that I found is send the sound to yourself in a picture message and once you receive it you can select options and there you will find Save as a Ringtone.
    Dec 11, 2008 | LG enV VX9900 Cellular Phone
    Phone Speaker does not seem to be working
    Same here. It doesn't play music and the incoming calls cannot hear when the cover opened.
    Nov 04, 2008 | Sony Ericsson W380i Cellular Phone
    Ringtone
    While the phone is not in use (do not pick up the receiver), touch the FLASH button, each time you touch it, it will sound a different ring tone. Keep touching the flash button until you get the one you want. When you find the ringtone you want, just lift the receiver from the phone, and then replace it. That should change your setting.
    Oct 29, 2008 | Innovage Speaker/Caller ID* LCD Touch...
    W880i not ringing or message alert
    Ok, Might seem like a daft question but is it on silent?
    I'm guessing you chekced this already but it's easy to miss.
    The first thing to check is whether it will make any sound at all - this is a good guide as to whether the speaker is broke or just settings are wrong. Being a Walkman phone you might have some tunes on it so see if they play. Do this through the walkman/media player feature as apposed to the ringtone area.
    If they play then you know it's still working and some settings need changing. If not your speaker might be broken.
    If the speaker works then you need to check the ringer volume. this can be done from MENU/SETTINGS/SOUNDS&ALERTS/RING VOLUME - this then needs to be set using left and right to go up and down.
    After this is set test call the handset to see. If still no luck change the ringtone to another tone - something built into the handset preferably - might be a faulty tune. If still no luck check the the number calling the handset has not got any sound preferences - i.e. no tune when call received. If still no luck it might be broke...
    hope this helps some what...
    Mar 15, 2008 | Sony Ericsson Walkman® W880i Cellular...
    No sound through the ear-piece of my Moto ROKR E6
    hi its to simple. go market and change ur ear speaker
    Feb 25, 2008 | Motorola Mobility ROKR E6 Smartphone
    Voice sound has gone on phone (but ringtones and all other sound working).
    there is problem inside ur phone. the speaker which gives sound to listen in caller's voice that has spoiled. take it to technician it need to be replaced
    Jul 02, 2007 | Panasonic G50 Cellular Phone
    Nokia 6230i Cellular Phone Logo
    425 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
    IT Solution
    IT Solution
