Question about HP LaserJet P3005D Monochrome Laser 35 ppm Mono Parallel USB PC Mac Card Printer
81.0185 error message in p3005d printer - HP LaserJet P3005D Monochrome Laser 35 ppm Mono Parallel USB PC Mac Card Printer
3 Suggested Answers
  • 136 Answers
SOURCE: jam inside rear bin error in p3005d printer
check the backside out-bin tray for jammed paper, or simply open and close that tray
Posted on Jan 04, 2010
SOURCE: hp laserjet p3005d 52.00 error.
Just had the same issue. I found the Flag on the Toner Cartridge that activates the laser unit to be broken off . Had to tear everything apart to find the flag that was jammed.
Posted on Dec 10, 2010
HP laserjet p3005d frozen on "download file now send rfu upgrade"
Need further information as there are several ways this can go, some of which are fairly complicated. Does the screen state Download firmware over USB? or Resend over parallel port?
Post the exact message and I will see if I can find you the tech document that shows the steps needed, depending on what the screen says.
Jul 01, 2014 | HP LaserJet P3005n Printer
49.ff05 service error hp laserjet p5200
there is nothing wrong with your printer!! it is a connunication issue from the computer to the printer... cancel the document that you tried printing and try reprinting it again.. to clear the error remove the USB cable or Network cable then turn off the printer.. then back ON while the printer is in the ready state re attache the USB or Network cable and reprint the document :-)
Jan 02, 2014 | HP LaserJet P3005d Printer
I m facing problem hp laserjet 3005n 59.50 error
59.50 ERROR
alternates with
To continue turn off then on
A main motor (M1) error has occurred. Motor
operation is verified during device power-up.
1. Turn the device off and then on.
2. Verify that nothing is hindering the main
motor. If necessary, remove all paper
trays and the print cartridge, and then
turn on the device and listen for motor
operation.
3. Verify that the main motor is connected
to connector J407 on the ECU. (See
Figure 6-9 ECU wiring on page 195.)
You might have to remove the main
cooling fan to see this connection.
4. If the message persists, replace the
motor.
Part #
RK2-1488 Main Motor
Dec 31, 2010 | Laser Jet P3005d Printer
I just replaced the Fuser as well as a new Toner cartridge in my HP Laserjet P3005. Getting an error message after initializing that states "13.20.00 Jam Inside Rear Bin". I've taken it all back apart and...
First, make sure that both wire connectors on the right side of the fuser are seated correctly.
Then, see if there is paper sticking a little way out of the fuser. If so, chances are the exit sensor in the fuser is not functioning correctly.
You can put the old fuser back in and verify this if no error codes come up.
Oct 25, 2010 | HP LaserJet P3005d Printer
Where do i find the drum of the laserjet p3005d?
You need to open the front cover ot the printer.Then you are goign to see a black toner catridge wich you can pull out carefuly.After pulling out the toner turn it around and move back the protective cover and you will seee the green drum.
Oct 20, 2010 | HP LaserJet P3005d Printer
Color LaserJet 3800 series - Error message reads
You have a problem with the slot that the yellow cartridge slides into.
Pull out all the cartridges and reseat them. Power cycle the printer. If the 10.92.03 is still there, then something is broken inside. Pull the cartridges and look inside on the right side. Compare that area for the yellow toner to the other colors. Look for a steel wire that is out of place at the yellow position on the inside right frame. The part is a cartridge lock. If it's broken, you will need a tech to replace all the locks at the same time.
Even if it's not a broken yellow cartridge lock, something else is physically broke and you will still need a tech.
Due to the age of the printer, i'm guessing that you don't have a warranty.
Jul 22, 2010 | HP LaserJet P3005D Monochrome Laser 35...
Jam inside rear bin error in p3005d printer
Jan 04, 2010 | HP LaserJet P3005d Printer
P3005d schematic; formatter specifically
this manual has all the specs and steps required
http://www.megaupload.com/?d=9KNO0T3Y
Nov 29, 2009 | HP LaserJet P3005d Printer
I'M GETTING A 59.50 ERROR ON HP LASERJET P3005d. HELP
59.50 indicates a main motor failure either the motor is bad or something is stopping it from turning. can be as simple as a bad toner.
turn the machine on and listen for the motor noise if you don't hear it turn the machine off remove the toner and turn it back on if you can hear the motor running youmay just have a bad cart.
hope this helps
Jan 21, 2009 | Laser Jet P3005d Printer
HP LaserJet P3005D  Monochrome Laser  35 ppm Mono  Parallel USB  PC Mac Card Printer Logo
1,096 people viewed this question
Seeker5211
Seeker5211
