Question about Gateway GT5662 Desktop PC
Power light on power supply is on, but won't turn on when you push the power button on the front of the computer. No fans run nothing.
  • Gateway Master
  • 5,660 Answers
Bad Power On switch. (Located inside the plastic Power On button), or Bad Power Supply. Weak voltage power rail.
Bypass the Power On switch to see if the switch is the problem, or the Power Supply.
To perform this procedure you will be using a jumper wire to touch the Soft Power On wire's terminal contact, (PS_ON. Green wire), to ANY Ground wire's terminal contact, (Black), in your 24-pin ATX main power cable's connector. Brief contact, no more than 2 seconds.
Main power cable remains plugged in. The jumper wire can be a paper clip straightened out, then bent into a U-shape. The bend of the U is wrapped with electrical tape.
The legs of the U go down into the socket holes of the Green wire, and ANY Black wire. (ALL Black wires going down in that connector are Ground wires)
You have to make sure the jumper wire touches a metal terminal contact, that is down at the bottom of the wire.
The jumper wire is slid down next to the wire, in the socket hole.
The voltage is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
1) http://support.gateway.com/s/PC/R/1015003R/1015003Rnv.shtml
2) http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Posted on Sep 30, 2010
The power button on my computer won't turn on the computer
if no any power indicator at the front and also the fan at the power supply as will as in the mother board, it was a power supply failure.
Nov 25, 2012 | eMachines EL133105 Desktop Computer with...
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
Voltage not going to cpu
Not sure just what you mean. If your computer is plugged into the wall and the power is turned on, the power supply should be on and the cooling fan turning. Also, the CPU fan should be turning and the hard drive should spin up.
Note that the power supply is the main component that must be supplying the power. If you don't hear or see the fan turning in the power supply and the little power light on the front of the computer does not light, replace the power supply.
If your power supply is running and nothing else is running, I would unhook all devices and leave just the CPU and video and memory in. If you get nothing, then the motherboard is probably bad.
Sep 22, 2011 | Computers & Internet
When the computer on/off button is pressed , the CPU fan and tower exhaust fans start running, the blue light around the power button does not light and the boot up process goes no further. Fans continue...
A) When you hold a Power On button, (Switch actually), in for a count of 10 seconds, it turns the computer off.
(There is a Power On switch, located behind the plastic Power On button. Usually, the Power On switch snaps into the housing of the plastic Power On button.
Example of a typical ATX Power On switch,
http://www.directron.com/atxswitch.html
The Power On switch turns the Power Supply on.
Old computers had a metal rod, that when the Power On button was depressed, the button pushed against the metal rod, which in turn pressed against a power switch located inside the Power Supply.
The design after that, was a power switch located in the Front Panel. (Plastic front of the computer) A large cable, (Wire) ran from the switch to the Power Supply.
Now there is the Soft Power On feature. (PS_ON)
The Power On switch is a small Momentary Contact Switch. Pressing it closes a circuit. The Soft Power On circuit.
When a power supply is plugged into power, there is a constant 5 Volts (DC) present.
This is the 5 Volt Standby.
Closing the Soft Power On circuit, redirects the 5 Volt Standby power to a circuit within the Power Supply.
This in turn 'excites' the Power Supply, and turns the Power Supply on.
Sorry to be windy, but I wanted you to know how the Soft Power On feature works )
eMachines are a budget computer. As such they save the consumer money.
However in order to do this, the manufacturer will install low quality parts, in some areas of the computer.
One such part is the Power Supply.
1) ALL the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Depends on what Processor it is.
(Had you stated the Model Number I could have told you)
Enough power to spin fans, but not enough to spin fans, AND turn the Processor on.
Do you have access to another computer that is unused, but has a Known to be good, Compatible power supply?
It could be used for a test unit.
Tell me the Series, and Model Number of your eMachines, and I'll tell you what Wattage it should have, and what power cables, for the Power Supply.
(Some examples of Series, and Model Numbers, T1090, E4264, W2925, and so on. The T, E, and W are a few examples of the Series letter.
The numbers following the Series letter, is the Model Number)
If you wish I can direct you in removing the Power Supply, and installing the test unit. (And/Or a new Power Supply)
Sep 12, 2010 | E-Machines eMachines Desktop PC
Computer does not power up. The green light on the back of the PS does not come on. I have 120 volts at the plug but when plugged into he power supply and push the power button on front of the computer...
make sure the switch on the back of the power supply is set to 120 volts , does the power-supply fan come on? if not it may be the power supply they are pretty inexpensive and not too dificult to replace
Sep 17, 2009 | Computers & Internet
Yellow Light
Emachines are bad for having failed power supplies and motherboards. Test your power supply, watch this video.
http://www.metacafe.com/watch/729606/how_to_test_your_computers_power_supply_psu/
Aug 03, 2009 | E-Machines eMachines Desktop PC
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Gateway GT5662 Desktop PC Logo
185 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
