Question about Sharp AR-275 Copier
HOW TO FIX H14-00 ERROR CODE - Sharp AR-275 Copier
  • 4,323 Answers
Hi
Error C010 indicates main motor fault. Please check the main motor. If main motor not running under output test, then you'll need to replace it. If motor working, u might need change the LGC board. Take the drum unit out and check inside for any irregularties in drive system belts.
Hope this helps...
Daniel
Posted on Sep 30, 2010
  • Daniel Scott
    Daniel Scott Sep 30, 2010
    The above solution was not for you. Please find below--
    Error H14-0/H4-0 means the fusing unit doesn't heat up. It has happened due to Heat roller, it has detected a low temperature. If the Fuser is not reaching the correct Temp it will give the H4-00 Code. Try cleaning the thermistor and check if error disappears. Hope this helps...
    Daniel
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
I bought $89 office 365 from Dick Smith. How can I install with that? Ellie
Common causes for error code
  1. Antivirus software or firewall might be blocking the Office installation and causing error code
  2. Internet connection or proxy settings are preventing from installing Office results in error code
  3. Pre-existing version of an Office suite is blocking the installation resulting in error code
  4. Incomplete\partial\failed repair\installation\change\removal of a previous Office suite can prevent from installing a newer version can cause the error code
Follow the below steps to troubleshoot the error code
1 - Repair your Office app to fix the error code
error code will be fixed when Office repair tool replaces all the corrupted system files. Follow the steps below to run repair tool to fix the error code
  1. Open Control Panel using Start.
  1. Click on Programs and select Programs and Features.
  2. Click on the Office product that you want to repair.
  3. Click Change.
  4. Select Quick Repair and click on Repair. If Quick Repair didn't fix the error code, select Online Repair and click on Repair.
Note: If Office Repair did not fix the error code, remove and reinstall the Office Suite to fix the error code.
https://answers.microsoft.com/en-us/msoffice
http://microsoftsupport.cc/
Feb 02, 2016 | Microsoft Office 365 Personal 1yr...
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
How can i fix error 0001
Xbox-experts.com - Error code 3 RLOD E01 / 0001
https://xbox-experts.com/errorcode/E01/0001/
General info on Error code : 3 Red Lights E01 0001 and how to fix it!. Short circuit in the console/faulty PSU. E-Code / Secondary Error code‎: ‎E01 (No ...
Binary/Hex‎: ‎00000001 / 0x01 -> 1
Primary Error code‎: ‎3 RLOD
Sep 24, 2015 | Office Equipment & Supplies
Error code 09,038,46:2200
  • What is error code 8500?
  • Common causes of error 8500
  • How to FIX error code 8500...
  • [img border="0" src="http://error-toolkit.com/faro.gif" width="45" height="28" align="left">
    What is error code 8500 ?
    Error 8500 code for Windows can be extremely broad and each number will represent a different problem. To be able to use these 'codes' to be able to fix what is wrong a good deal of investigation must be made.
    This is a full Description of ERROR 8500:
    ERROR 8500: ERROR_DS_INVALID_SEARCH_FLAG.This error is due to The search flags for the attribute are invalid. The ANR bit is valid only on attributes of Unicode or Teletex strings..The default facility code
    ERROR 8500: ERROR_DS_INVALID_SEARCH_FLAG.This error is due to The search flags for the attribute are invalid. The ANR bit is valid only on attributes of Unicode or Teletex strings. .This region is reserved to map undecorated error codes into HRESULTs.
    Common causes of code 8500 ?
    Error 8500should not be ignored though as the eventual outcome can be the slowdown or total crashing of a computer if not fixed.
    How to FIX error code 8500 ?
    Fixing Error 8500 manually is a difficult process and it is not recommend unless you are an expert in this field.
    Therefore, we recommend you to use Regservo. It is reliable PC Repair tool that can do all the hard work for you.
    Please follow the 3 steps below:
    (1) (Download Error 8500 Repair Tool). RECOMMENDED
    (2) Click the "Scan Now" Button. and wait for the scan to finish.
    (3) Click the "Fix" button to fix all identified errors.
    Note: Please make sure that you restart your computer after regservo fixes all your identified errors.
    [img border="0" src="http://error-toolkit.com/sk.gif" width="152" height="131">
    follow the steps below to fix your 8500 error: STEP (1): Download >> Error 8500
    Repair Tool
    STEP (2): Click the Scan Button. STEP (3): Click the Fix Button and you're done! Click here to download
    Error 8500 Repair tool
    [img src="http://error-toolkit.com/ic_win.gif" width="19" height="18">Windows 98SE, 2000, XP, Vista and 7 Ready Information: System Requirements:
    Runs on Microsoft Windows 7, Windows Vista, Windows XP and 2000. Including 32-bit versions. Download size: 1.6 MB Software Description:
    software will run a scan of your PC and identify all system errors , missing or corrupt system files. It also identifies errors in ActiveX/COM objects, Windows startups, File associations, File path references, Shared DLLs.
    To fix these errors, you can purchase a one year registration of regservo software for only $29.95 subscription including all new versions, unlimited smart updates and customer support. Testimonials "RegSERVO software is simply the best. My computer went from almost standing still to running as fast as lightning. The software was easy to use and found over 300 issues to deal with. Who knew? Thank you so much for an easy to use and super effective product!"
    - Steve M.Buffalo, NY - USA.
    error 8500 Repair tool
    "My computer was moving so slow that I made an appointment to bring it in to a computer shop. Then my sister told me that she used RegSERVO with a lot of luck. I gave it a chance and found that my computer was being plagued by 237 problems. With a few clicks of the mouse I was able to use RegSERVO to address all the problems and optimize my computer to a level not seen before. Of yeah, I cancelled the appointment with the computer shop - Thank you!"
    - Gerard G.Colorado Springs, CO - USA
    "Before I found RegSERVO my computer would freeze on a daily basis. I was just about to buy a new computer when I stumbled across RegSERVO. I figured for the price it was worth a shot. Now I have five words: Best money I ever spent! My computer no longer freezes and the speed is just unreal. Thanks so much RegSERVO!"
    James D.London, England - UK
    "All I can say is THANK YOU! my computer is error free and so fast now that it is hard for me to believe it is three years old. It literally went from being the tortoise to being the hare. The only difference is this hare actually wins. Thank you so much!"
    - Barry H.Victoria - Australia
    In this article we will explain:
    Nov 26, 2014 | Xerox Phaser 8560/YN Printer
    0176 code error what can i do to fix the problem
    What were you doing to get this error code? When does the error appear?
    Apr 09, 2012 | IBM ThinkPad X30 2672 Notebook
    Cannon ir 3530 all error code and solution
    Code Error name/description
    E000 fixing overheating
    E001 fixing assembly overheating
    E002 fixing assembly low temperature
    E003 post-standby fixing low temperature
    E007 fixing film rotation error
    E010 main motor rotation error
    E014 fixing motor rotation error
    E019 waste toner case full, waste toner case full sensor error
    E020 toner clogging between sub hopper and developing assembly
    E024 developing assembly connector disconnection
    E025 hopper motor, bottle motor error
    E032 NE controller counter error
    E064 power supply voltage error (high-voltage)
    E100 BD interval error
    E110 scanner motor error
    E191 communication error for high voltage power supply
    E202 CIS home position detection error
    E225 CIS light intensity error
    E227 reader unit power supply error
    E248 backup memory error
    E261 zero-cross signal error
    E315 image data error
    E400 feeder communication error
    Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
    CANON IR 3300 HAS ERROR CODE: E000002-0000
    OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
    To clear the error:
    * 2 8 *
    COPIER
    FUNCTION
    CLEAR
    ERR
    OK
    Turn off and on ( main switch )
    If this dont help - replace fixing film assy.
    Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
    Sharp AR-275 Copier Logo
    81 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    CheckitRight
    CheckitRight
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
