I have zyxel P600HW router. I used to open the router page by 192.168.1.1:8089 , but now it is not opening by this address and port number. How can I find the port number where it opens ?
  • 101 Answers
SOURCE: i can't access ther router using 192.168.0.1
Hi Wafula,
Unplug the Dlink, wait 2 min, and plug it back in. If that work, on the back is a small hole, marked RESET. Using a pencil, or straightne out a large paperclip, press that the button inside gently. Hold it for 30 sec. Release and unplug the unit. Shut down the whole network. "Starting from the wall", power up the modem, wait 2 min, power up the Dlink, and power up your machine. Your Dlink should be at default now. Remember to reset you security, change the password, etc.
I have had to do this several times, sometimes unplugging the power, and plugging it back while holding the button. (Got 3 hand?)
Posted on Jan 10, 2008
SOURCE: Cannot open port 21 for ftp but port 22 is ALWAYS open
fist it a lot
Posted on Nov 13, 2007
  • 5 Answers
SOURCE: set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
Posted on Jan 30, 2008
sandrew
  • 2961 Answers
SOURCE: Cannot connect the the Zyxel page to configure my Embarq router.
you can check the router ip address by going to network connections in control panel and then, right click on connection icon>status, then support tab, there will be the ip address of your pc and the default gateway address which will be your routers address.
If you still cannot get into the router, there will be a hard reset button on the underside or rear of the unit.
Posted on Aug 18, 2008
marked
  • 6487 Answers
SOURCE: unable to log into router to open ports
To log in to the router in order for you to do a port forwarding you can follow the steps from this link, but if the default username and password didn't work reset the router so it will be back to its default settings http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-T1v2/Age_of_Empires_III.htm
Posted on Oct 24, 2008
How to change Pass word
Hello it depends on your router.
Read more here:
http://www.zyxel.com/support/knowledge_base/kb_detail_1850.shtml
http://www.default-password.info/zyxel/
Here is a video that shows how:
http://www.youtube.com/watch?v=19WI2dl-QU4
You might have to reset router to access the page.
Press the reset button at the back of your router for 30 sec.
and release.Wait for it to boot up again.
Now the router is set to factory settings.
Connect your lan cable to the router to one of the ports 1 to 4
and to your computer
To configure your router's wireless network open Internet Explorer and navigate to the router's configuration page by typing 192.168.1.1 into the address bar. When the page loads you will be prompted for your Router configuration password. By default this is 1234.
(You have to find the username and password first)
Try to download a manual for the router:
http://www.zyxel.com/support/download_library.shtml
Please select your model and number.
Do not use a easy password so others can use your internet connection.
Good luck
Nov 03, 2012 | Zyxel Computers & Internet
How do I use my router so I can open NAT on my xbox for xbox live?
1 Make sure your ZyXEL Device hardware is properly connected (refer to the Quick StartGuide).2 Prepare your computer/computer network to connect to the ZyXEL Device (refer to theQuick Start Guide).3 Launch your web browser.4 Type "192.168.1.1" as the URL.5 A window displays
6 For administrator access enter the default admin password 1234 to configure the wizardsand the advanced features.(or if you already changed your password, enter that password)7 On the right hand side of the screen you will see a drop down menu. click on NETWORK. 8 Then click on NAT.9 Find the area to configure Port Forwarding.10 The ports that Microsoft recommends to be open are:88 UDP3074 UDP3074 TCP
It also looks like you will have to set up a static address (I was looking at the .pdf for your particular router) You can do this by editing your network setting on your XBOX console, and then using this address as your "server" address when opening the above mentioned ports on your router.
ftp://ftp.zyxel.com/P-660HW-D1/user_guide/P-660HW-D1_3.40_Ed1.pdf
Nov 29, 2011 | Zyxel P660HW-D1 Router
I have a P-660HW-D1 v2 zyxel router but on our Xbox the NAT is always strict. I've looked at a few online guides and everyone says to go to UPnP and click all the boxes. Well I did that and still no open...
follow this guide
http://howto.wired.com/wiki/Set_Up_Port_Forwarding_on_Your_Xbox_360
setup your xbox with a static ip address.
setup your router with the following ports forward to the ip address you gave your xbox
Since you've already assigned a specific address to your Xbox, you can now open up the individual ports of this address. According to Microsoft, the ports that require forwarding are UDP 88, UDP 3074, and TCP 3074. If your router requests a range, just be sure that the numbers entered span this range (i.e., 87-89 for the first port, 3073-3075 for the second, and so on).
Mar 10, 2011 | Zyxel P660HW-D1 Router
How do I open ports for xbox360
Is there any computer connected to the router ?
If not then connect the computer to the router.
check the IP address and the default gateway of the router.
open the set up page of the router.
there you will find the place to place to open the ports on the router.
Click here for more information about routers and network
Mar 31, 2010 | Zyxel P660HW-D1 Router
How to configure port forwarding?
Click here for more information about roters and network
Feb 08, 2010 | Zyxel Computers & Internet
Am trying to set up a Windows 2003 server to serve web pages over the Internet. Have got a DSL line from Embarq. They installed a EQ-660R interface which is really build by Zyxel. I can reach the Internet...
In order to access your default web page remotely, port 80 "INBOUND" must be open to the internet.
To access your web server, two things need to happen.
The first is you or someone else must initiate a http request on port 80 using the public IP Address of your DSL connection.
Second, your router must forward that request to your servers internal ip address.
Ex. Lets say your public ip address is 24.39.45.10. In a browser window from a remote location, you enter the URL http ://24.39.45.10 The request will be sent to your router on port 80.
Your web server will not have the ip address 24.39.45.10 because it's on the private network side of your router. So, lets say the private ip address of you server is 192.168.1.100
You need to configure your router to take the http request coming from the internet on port 80 to ip address 24.39.45.10 and forward that request to 192.168.1.100. This is known as port forwarding.
You also need to configure the host header name of your "web page" so it knows it needs to display the web page.
Since we're just using ip addresses in this example and not an actual FQDN (fully qualified domain name), you would make a host header entry for the web page of 24.39.45.10.
To do this open IIS.
Navigate to the web site in question and right click on it then select properties.
On the website tab, ensure the port number is set to 80 and choose the appropriate internal ip address if you have more than one network adapter in the server.
Next click on the advanced tab and look for the heading Multiple identities for this site. This is where you enter the ip address 24.39.45.10.
If you have a fully qualified domain name, you would enter the domain name instead of the ip address as specified in this example.
Host header names are the key to running multiple websites from one physical server as long as it has the necessary horsepower to do so.
Hope this helps and isn't confising. If you're confused in any way, don't hesitate to ask for clarification.
Sep 13, 2009 | Zyxel P-660RU-T1 ADSL Ethernet/USB Router...
How do u change your nat settings to open
you can't just say nat is now OPEN :)
let's say you have a pc with IP of 192.168.1.33
you are running a emule (hehe) on that PC
you want to use port 12345 for your emule
this is what you need to do:
1. go to webinterface of your router (usually http://192.168.1.1)
2. go to menu network/nat/port forwarding
3.go to service->user define
4. in new window click "active", name it emule, start port 12345, end port 12345, server ip 192.168.1.33
5. click ok, apply, whatever and go to menu security/firewall/rules
6. choose packet direction wan to wan/router
7. click on ADD
8. change following fields: destination address - change to single address and change 0.0.0.0 to 192.168.1.33 and click on add, then close to it says ANY, mark it and click on remove
9. on same page under services click on edit customized services
10. choose number 1 or 5 or whatever :)
11. service name: emule rule, service type TCP/UDP, type single, port 12345
12. click on apply
13. go to menu maintenance/tools/restart
14. just in case restart the box and your zyxel is now accepting incoming connections on port 12345 and forwarding them to 192.168.1.33 (your pc) ...
i hope i helped
cheers
-tomba
Jul 28, 2009 | Zyxel P660HW-D1 Router
I have a Zyxel P-660r-d1 modem and I connect to it with my ps3. But I currently have a NAT type 3, and I have some problems connecting with friends online. How do I change it to NAT type 2?
i will repost my guide for opening nat and firewall on a zyxel ...
it will help for sure ...
7. click on ADD
8.change following fields: destination address - change to single addressand change 0.0.0.0 to 192.168.1.33 and click on add, then close to itsays ANY, mark it and click on remove
12. click on apply
14.just in case restart the box and your zyxel is now accepting incomingconnections on port 12345 and forwarding them to 192.168.1.33 (your pc)...
i hope i helped
cheers
-tomba
Jul 01, 2009 | Zyxel Prestige 660R Router (P660R)
Fifa 09 PS3 online lost connection
go to the router page in that port forwarding option is there type your port number and ip address then you get it which port number of the game port number after then save it then reboot it then try you get it
Apr 16, 2009 | Zyxel Prestige 600WH Wireless Router...
Xbox Live connection problem
In this regard, I would recommend you to forward certain port no’s on
the Router.
Port numbers: UDP- 88, TCP/UDP- 3074
It is in this context, I would suggest you to please try with the
following troubleshooting steps:
A) Assign static IP and DNS address to the XBOX.
1. Assign IP address as: 192.168.1.50; Subnet mask as: 255.255.255.0
and Default Gateway as: 192.168.1.1
2. Assign Primary DNS Address as: 192.168.1.1 and Secondary DNS
Address as: 4.2.2.2
# Please Contact X-Box Technical Support to assign the Static IP
Address on Your X-Box.
C) Open the ports on the Router using the following steps:
1. Click on Port Forwarding under Advanced.
2. Click on ‘Port Forwarding’ on the left hand column on the screen.
3. On the bottom of the screen, click on ‘Add Custom Service’.
4. Give a name to the service (for example, XBOX1).
5. Select Service Type as UDP and key in the starting port and ending
port as 88.
6. In the Server IP Address specify 192.168.1.50
7. Hit ‘Apply’.
8. Click on 'Wan Setup' Under 'Advanced'.
9. Check the box 'DMZ Server'. Type in the IP Address 192.168.1.50.
Click On 'Apply'.
10. Log Out of the Router Page.
Please repeat Steps 3 – 7 to configure the ports “UDP/TCP 3074”.
Apr 13, 2009 | Zyxel Prestige 334 Router
Computers & Internet Logo
283 people viewed this question
David Payne
David Payne
