Question about Nokia X3 Cell Phone
Opening the back cover - Nokia X3 Cell Phone
Inner screen is crack on a kurio
Kurio 7 Screen Replacement
Written By: Eric Rice (and 6 other contributors)
Comments: 2 Favorites: 5 Completions: 12
Main guide photo
Difficulty
Moderate
Steps
12
Time Required
30 - 45 minutes
Sections
Back Panel
4 steps
Kurio 7 Motherboard Removal Guide
5 steps
Screen
3 steps
Flags
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Introduction
This is an easier part to replace than many others on the Kurio 7. Most require soldering, but this one does not. However, you must exercise extreme care when taking the device apart so that none of the soldered connections are broken. In the event that they are broken, look to our other guides for repair tips.
Tools
Buy these tools
Phillips #00 Screwdriver
$6.99
Buy
iFixit Opening Tools
$1.99
Buy
Parts
Kurio 7 Replacement Screen
Available for sale on Amazon
Buy
Step 1 Back Panel
Begin by removing the rubber cover from the Kurio 7.
Add a comment
Post comment
Step 2
Remove the four 30 mm Phillips #00 screws from the outer case.
Add a comment
Post comment
Step 3
Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
Be careful not to break off the tabs that hold the front cover and the back cover together.
Add a comment
Post comment
Step 4
Once all of the tabs are removed, the back cover should come off easily.
Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
Add a comment
Post comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Buy Now
Step 5 Kurio 7 Motherboard Removal Guide
Use a plastic credit card, or other thin object, to separate the battery from the screen.
Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
Carefully set the battery aside.
Add a comment
Post comment
Step 6
Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
Place the screws aside in a container separate from the other size screws. You will need these later.
Add a comment
Post comment
Step 7
Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount.
Pull the ribbon out of the mount.
Add a comment
Post comment
Step 8
There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
Do not pull the tape completely off the motherboard, as it is used to protect components on the ribbon.
To remove the ribbon from the mount, follow the same steps in Step 3.
Add a comment
Post comment
Step 9
Pull back the ribbons and put the battery near the bottom of the Kurio.
The motherboard is now removed so that other components can be worked on.
Add a comment
Post comment
Step 10 Screen
Flip motherboard down near base of device.
Be careful not to pull out any wires when moving the motherboard.
Add a comment
Post comment
Step 11
This is tricky, and an extra pair of hands may help. Use the opening tool to pry the screen out from underneath the tabs holding it in place.
Once you have created some space between the screen and the cover, slide the opening tool under the screen.
Slide the opening tool around the outside of the screen, releasing the tabs as you go along.
Be careful not to pull too ******* the motherboard while doing this, as there are still many wires attached to the body of the device.
Add a comment
Post comment
Step 12
You have successfully removed the screen!
Pull the screen out from the casing.
Jan 07, 2018 | Tablets & eReaders
Light not working
Replace the light switch at the top of the door opening. Kill the power to the unit, pull down the grille up top, then remove the cover over the switches. the light switch is the one with the white back. The one with a black back is the fan switch. pull the 2 leads off, open the fridge door, squeeze the switch with a pair of pliers to pop it out of the opening, then install the new switch in the opening facing the same direction. put the wires back on , in any order doesn't matter, put the cover back on the switches, then the grille back on and restore power to the unit.
Nov 10, 2013 | Sub-Zero 611 / O Bottom Freezer...
My brother mfc 7420 says that the back cover is open
When this happens it is just telling you to go through the steps of opening and closing the back cover. The back cover may not be completely closed.
Oct 18, 2012 | Brother MFC 7420 All-In-One Laser Printer
Disassemble
This printer having inter locking system, you cannot find any screws for opening.You can observe there is gap adges of covers, inser tool/flat screw driver for opening the covers of left,right & top/back(both combined)you can observe right back side small power supply container, detach power out socket, take out, only one screw fitted at the center point of the power supply & its covered by specification stikker, find the screw, open it... check for component failure.. best of luck
Feb 02, 2012 | HP DeskJet 920c InkJet Printer
Disassemble hp 920c printer
This printer having inter locking system, you cannot find any screws for opening.You can observe there is gap adges of covers, inser tool/flat screw driver for opening the covers of left,right & top/back(both combined)you can observe right back side small power supply container.
How do I get to the ignitor in this model? There is no obvious opening - which I believe should be on the front (the back opening doesn't lead to the ignitor).
you need to remove the top cover by using a putty knife to slip between the top and front cover and release the clips,then there are 2 screws that hold the front cover inside the front cover,then remove the drum belt and the drum and there will be the burner tube and ignitor
Oct 14, 2010 | Frigidaire GLGR341AS Gas Dryer
I just fixed a me super but the frame counter doesn t reset when the 36st is reached or when I attempt to open the camera. HOW DO I RESET IT without openning it?
By opening, do you mean the back cover or the top cover?
after rewinding the film opening the back door will reset the counter. if it does not reset, try firing the shutter with the back door opened a few times. this counter is mostly plastic.
with the back door opened try taping the top cover over the counter to free the counter gear.
if it still wont reset the top cover will have to be removed and the counter repaired.
there are no new parts available for this model Pentax so a good used counter could be expensive.
if you take the top cover off, usually the pointer plate on the right side of the counter is rubbing on the counter preventing it from resetting.
Oct 15, 2009 | Pentax ME Super 35mm SLR Camera
Front cover is open
the door of your printer have a micro switch ,on the door you have a some plastic part that prees that switch,try to find it and then put some plastic on the top .
Feb 01, 2008 | Brother MFC-9420CN All-In-One Laser...
Back cover error on LCD won't go away
This is most likely caused by the back cover switch. It is either broken or the lever on the back cover is broken off.
Sep 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Nokia X3 Cell Phone Logo
79 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
