Question about HP Compaq 6820s Notebook PC - Intel Core 2 Duo T5470 1.6GHz, 802.11a/b/g WLAN, 4GB DDR2, 250GB HDD,
I own a compaq 6820s with win 7 os bios failed to update it still runs but sometimes failes to boot and reboot. and can't find any suitebale drivers either
5 Suggested Answers
  • 338 Answers
SOURCE: i updated the bios of compaq presario v3000 and it
this might get critical, see a notebook pro,
online help won't do here as you messed up it quite bad
Posted on Jun 13, 2009
  • 251 Answers
SOURCE: Hp dv9008 Tried to update the bios but somehow failed,now it
get it repaired under the limited warranty scheme
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Posted on Nov 08, 2009
RescueTechLA
  • 2653 Answers
SOURCE: replace worn touchpad buttons HP compaq 6820s
It's better and easier to just replace the whole touch pad assembly and top cover. It's all one piece...much easier and cost is the same.
This is the part number:
457616-001
Posted on Nov 23, 2009
Testimonial: "Thanks for quick response"
  • 112 Answers
SOURCE: i recently sanitise my hd
I had to fix this problem a couple years ago, it's common on Compaq's. The only way to fix it is to short out the CMOS battery on the motherboard. Doing this voids your warranty, so if you wish to follow that course I cannot tell you exactly where to go, but google's your friend. The other option you have is to call Compaq and open a ticket with tech support. If your laptop is still under warranty, you may even get a new computer.
Posted on Mar 23, 2011
"how to clean & install toshiba satellite l35-s1054 win 7 "
Look in BIOS during reboot, make sure the hard drive is detected. Run hard drive test and memory test. Use BIOS feature to setup boot options and boot order, set all to default. Reboot.
Feb 10, 2013 | Toshiba Satellite L35-S1054 Laptop...
P8z77-v LK SATA Controller Problem ??
The board was working fine until you did what you did. HD is all messed up software wise. Wipe it completely and do a clean reinstall of your OS. And stay away from updates ,etc. The only time you resort to them is when you have an issue. Otherwise, you very often turn a good working piece of gear into a paper weight or junk.
And 8 is the worst OS down the pike - Use 7 and drivers for win 7.
Sep 12, 2017 | ASUS P8Z77-VLK Intel Z77 Motherboard -...
I am attempting to install Windows 7 on an AlienWare M7700 D900T laptop, but Windows Setup will not recognize the hard drives. When first I boot up the laptop the hard drives are clearly detected, IDE...
It is a 2005 machine and was designed for Vista so an upgrade from Vista to Win7 may work as the drivers will need updating as it loads one OS from the other OS.
A bios update would possibly help also.
Jan 16, 2011 | Alienware PC Systems M7700 Notebook
I cant find vga driver for intel d845 epi
HI. Go to there website anddownload with the following steep. Just . CLICKHERE Type model no on the searchoption Choice the product (e.g.chipsets)> Desktop chipsets/laptop board> Choice chip no(e.g.865/945)> Selects your OS from leftside (e.g. sp/vista/win 7)> Click on driver > Now look bottom the page, anddownload one after one. Hope it will help you.
Jan 15, 2011 | Intel Desktop Board D845EPIL Motherboard
My HP ProLiant ML350 G5 failed to boot to Windows. After showing Windows 2003 Server, blank screen comes up
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Jan 05, 2011 | HP Compaq ProLiant ML350 G5 Server
OS will not boot up. unable to start in any mode and also unable to do chkdsk. doing an OS will not boot test, results in sata error uncorrectable data or is read only
My best guess is that your hard drive has failed or is failing. Replace it. Boot to your Windows CD/DVD and install windows. Then add your old drive as a second disk and, if you are lucky, you can copy your data from it before it fails completely.
Good luck. I hope this helps.
Nov 13, 2010 | Computers & Internet
My HP Compaq nx6610 hangs in all stages of booting and when starting up. The problems is when you press power switch to re-boot, the screen remains at "press F10 to enter bios." The same happens...
Well they all do infected, (oldest story there is on PC';endless)
which OS?, oper. system. XP the Virus magnet?
HP only supports VISTA as newest OS for the OLD notebook
Rule1 : it must run on AC power only (wall power) battery out
batteries are shorted lived, and can short. so. get it out of there first.
get the PC working that try battery. LAST OF ALL.
That is first.
Its not hot, 30c is cold.
You re-installed, windows. via, what the HP disks?
DId you boot from the CD? from HP>? to do a fresh install?
or some old Microsoft disk? no disk or OS stated here.
When you use a CD to install after the setup.exe runs
it reboots the PC and the CD MUST be removed.
or keeps repeating the 1st phase of install for ever.
phase2 runs off HDD, to complete, if this fails the HDD dead.
HDD can be 1/2 good, and fail see? like a glass of water with small hole... bad.
if that fails, the HDD is bad, or power to it is weak. (wrong)
Did the install complete.?
DId you make sure BIOS is booting to the HDD?
HDD = hard disk drive.
My wild guess unseen is (near useless) IS, HDD bad.
put in a new SSD drive and win.
your PC is near end of support at HP
get the software seen below and keep it. for later.
here are drivers (pick your OS and use those) just drivers.
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=449878&swLangOid=8&swEnvOid=181
next get the media kit, from HP,
here is the media kit page, the official HP install disks or USB stick way.
http://support.hp.com/us-en/document/bph07143
Mar 27, 2017 | HP Computers & Internet
I have a NEC powermate computer, to remove a possible virus, I disabled system restore, rebooted into safe mode, and tried to install symantec in safe mode (I failed to install), Then I rebooted the...
Win XP is obsolete. Whatever happens it will go through the BIOS stage, if not the hdd may be corrupted. Boot into safe mode and run CHKDSK/f. That may cure your problem otherwise reinstall XP from your CD.
Aug 24, 2017 | NEC PowerMate ML4 PC Desktop
Keyboard keys share functions. Right shift key inserts a z and then shifts. z key does the same thing . Left shift key tabs and then shifts. 9 key and = key both give =9. Other keys also share...
1. try to do system restore first from the time system was working fine. reboot system. if fails.
2. update your anti virus then run a full system scan. reboot system. if fails.
3. update the bios. download the latest bios for your system from the dell support drivers and download section. reboot system. if fails.
4. reseat the keyboard cable. if fails.
5. reinstall the OS. if fails
6. replace keyboard.
Oct 25, 2009 | Dell Inspiron 2200 Notebook
"cant install win-xp on CQ-60"
Hello.
Hope this helps...
These are the normal steps on desktop computers but
should work in your case too with a fresh installation
1. Enter bios settings and set CD Drive as first boot device
2. After reboot if you are asked if you want to start on cd chose yes.
3. start Win Xp installation from cd.
4. delete partiton on C; drive
5. create new partition
6. Start installation and format the c:drive
7. Follow the installation instructions,,,
Feb 10, 2009 | Compaq Presario CQ60-220US PC Laptop
HP Compaq 6820s Notebook PC - Intel Core 2 Duo T5470 1.6GHz, 802.11a/b/g WLAN, 4GB DDR2, 250GB HDD, Logo
137 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
