Question about Whirlpool Duet GHW9150P Front Load Washer
Washer the door locked is on and I cant seem to get it off.
    Scholar:
  • 110 Answers
TO OPEN THE DOOR YOU WILL HAVE TO TAKE THE 3 SCREWS AT THE BOTTOM OF THE KICKPLATE OFF USE TORX OR T15 BIT TO REMOVE SCREWS. PULL DOWN ON THE PANEL AND IT SHOULD RELEASE ONCE REMOVE FEEL THE INSIDE OF THE DOOR PANEL AROUND THE DOOR LOCK AREA U SHOULD FEEL A OVAL RING AT THE BOTTOM OF THE DOORLOCK ASSEMBLY PULL DOWN ON THAT RING AND THE DOOR WILL OPEN
Posted on May 30, 2008
Door locked,cant open
just get an old door from any ariston..hotpoint or indersit machine make sure it is the same size
Jan 12, 2014 | Ariston Technologies Ariston AWD12 Front...
Front load duet washer wont start because the door cant lock and we cant open the door.
You need to replace the door lock/switch. It is quite an easy job but is a tight fit behind the front so a bit tricky to get the old one out and the new one in.
Mar 06, 2012 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I couldn't get the washer to start (HE 4T). It
DL stands for Door Lock failure, if your door isnt closing all the way, check to make sure your hinges are lining up and that one of the arms has not broken off on the door, there should be 2 arms going into the door lock. whats common on these is that the door latch has trouble unlocking so it is forced open and now the door latch mechinism is stuck in the locked position and cant re-open. problems with this lock opening and closing- 9 times out of ten, come from a main computer failure to send power to the door lock. this can be temporairily fixed by re-seating the door latch wire harness in the main computer, but its usually recommended to buy a new computer since this problem has been address on the new series of computer. there is no recall on this board at the moment. estimated cost $250-$400
Nov 24, 2009 | Kenmore Elite 45986 Front Load Washer
The door on my washer won't lock!
the door lock has internal relays, if they go bad, the motor control board will not function. Even if you cant physically see anything, and even if the door still locks, the door lock assembly is still the most likely problem and needs replaced. The only way to test it is with a multimeter to know for sure before you buy a new one
Oct 19, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Wahser has quiet working and door is lick need to get close out?
you cant override it but you seem knowledgable..so take bottom panel of and reach up ,,theres a tab at bottom of lock pull it,,,onthejob
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Wd63 door
The main cause with this model is water still in machine. Try a spin and look for water in drum. To empty manually lower drain hose into bowl untill empty. Door should then open.
Nov 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Washer door latch stuck, can't open
ahh..time for "Q" from 007, eh? this interlock feature is a relay controlled issue. Seems that your washer is telling you that it's closed. most likely a relay replacement in control panel area.
Feb 10, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door lock
try crc into lock
if no good replace door lock
Nov 16, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
