Question about GE Dryer Repair Video Older Models
Model DDE5100M dryer..serial number VF22384GG is it 220volts or 110volts?????/
  • GE Master
  • 3,149 Answers
Your dryer is called 220, but in actuality it is only 110 X 2. If you have a 3 pronged plug to go into the wall, each of the slanted & flat prongs are carrying 110 volts. The roundish center prong is a ground.
One of the flat prongs is for the motor and the controls, the other is for the heating element. If you have a 4 pronged plug, the two side flat parallel lugs are 110 volts each, and the top flat and the roundish lugs are both ground.
Be blessed.
Posted on May 22, 2014
110volts face lifting machine plugged in to 220volts..can it be repaired?
ck to see if it is fused , you may get lucky if not did you smell something burning when you did it , if so you burned it up ,trash it ,
Dec 26, 2014 | Office Equipment & Supplies
Esquema eletrico behringer nu3000
I have a nu3000 that was linked in the wrong strength is 110volts
linked in 220volts burned the two fet source (transistor) T1 and T5 can someone tell me an equivalent for putting in place
Jun 13, 2013 | Music
I will use a transformer that cuts down from 220volts to 110volts. I don't know the wattage of AD40DSR1 dehumidifier. What is it?
whats the brandname of the dehumidifier more importantly the amperage. a number with the letter (a) next to it. lets say it is 0.5A . then your wattage should be the voltage of the dehumidifier multiplied by the amperage of the dehumidifier. "ASSUMING" the voltage is 110v and the amperage 0.5A then 110Vx0.5A= 55watts
Aug 13, 2011 | Whirlpool AD40DSR Dehumidifier
I purchased a GE DRYER here in Greece from someone who left to go back to Canada and sold it to me.... the Model number is DDE5100M and the serial number is VF22384GG ....Question is.....is it 220 volts or...
If you can check on the motor below , if will be marked for the specification ,the voltage will be written .
Now converting a 110 to 220 is a littler expensive and might not be recommended by the economical scale as you will need a step down transformer with a high rating of power. ...will cost.
so decide to check and if 220 ,you will be lucky
Sep 30, 2010 | Dryers
MY DRYER TAKES A LONG TIME TO DRY CLOTHES. HAD IT FOR 5 YEARS. MOVEDTO NEW HOUSE AND HAD TO CHANGE POWER CORD BUT IT WORKED FINE AT FIRST. DO I NEED A NEW HEATING ELEMENT?
It sounds like you may have hooked it up to 110volts while most dryers need to run on 220volts. If your new house has gas then a gas dryer would run on 110volts as it gets it's heat from the gas flame. If this is the case you would need to run a new 220volt line to the unit. this can be costley and you may be better off trading your electric one for a gas one as that will probally be cheaper to run in the long run.
Aug 21, 2009 | Dryers
KENMORE DRYER MODEL #96263800 WON'T HEAT
Need to know brand name and model#..........but it sounds like your only getting 110volts to the dryer instead of 220volts........The moter and controls will run on 110v. but the heaters require 220v. carfully remove small cover on back or if you have a outlet(wall plug) you must check for 220volt...PROBABLE CAUSE 1 fuse blown,,,, or bad circiut breaker. FIRST is there 220v. at plug This will tell us if it's a wiring prob. or dryer prob.
Mar 25, 2009 | Kenmore 62602 Electric Dryer
Dead set of beosound 4000
an expensive repair,at least power pcb and maybe even contol pcb also
Feb 17, 2009 | Bang and Olufsen Beosound 4000 Shelf...
Power plug
I think that the console got fired by now then.
Apr 17, 2008 | Nintendo 64 Console
No power
Probably blew out the thermistat and the compressor, along with the the capacitor. Probably not worth the repair. good Luck
Jun 13, 2007 | Fedders X Chassis A6X05F2B Air Conditioner
GE Dryer Repair Video Older Models Logo
81 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
