Question about Panasonic SC-HT690 System
Wire for the Panasonic Subwoofer SB-WA340
I need to know what cable I need to hook it up to my computer.
  • 4 more comments
  • Anonymous Jun 03, 2008
    to direct put 210 volt
  • Geovanni Aug 17, 2008
    I can hear the audio but very, very low. I don't know if the prtoblem is the cable or the DVD player.
  • attowallace Jan 03, 2009
    the speakers haut-parleurs only the front L1 R2 working, the L3 R4 sorround & the 5 center putting out no power
  • Anonymous Jan 27, 2009
    I want a assignment of A connector cable of SB-WA340
  • Freycgonza Feb 24, 2009
    Casualmente tengo el subwoofer Panasonic SB-WA340 de un teatro que se le daño la consola y quiero conectarlo a mi PC pero los puertos no son compatibles que cable o que adatacion se puede hacer?
  • idphotograph May 11, 2010
    same question for me what cable and where can i get it??
Here, Amazon com panasonic subwoofer cables. I hope thiswashelpful. Cheers
Posted on Dec 25, 2014
My problem is l have only the sub-woofer and l want to know if l can use it without the dvd player and plz how will l connect it l will be very much happy it u give me the diagram for that u can email it to me at peebrown2@yahoo.com thank you
Posted on Sep 19, 2008
Hi. i have a panasonic sb-wa340 active subwoofer, do you know where i can buy a cable for this?
Posted on Jul 13, 2009
I ONLY HAVE THE SUB..NO CABLE WIRE..IF I CAN FINE ONE CAN I HOOK THE CABLE TO THE RECIVER?THEN THE SPEAKERS?N WERE DO I FINE THIS CABLE ?
Posted on Apr 09, 2010
If you find out i need the same please email me j.j.potter@sbcglobal.net
Posted on Jun 01, 2008
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
I have a Panasonic SB-WA340 Active Subwoofer, and need to know if this is compatible with other Panasonic home theater units?
It should be compatible with other Panasonic equipment that has an output for a powered subwoofer
Dec 25, 2012 | Audio Players & Recorders
Where do I get a cable to connect the SB-WA340 subwoofer to the TV
Radio Shack will have that one. You will need to give them the names of the connector ends you need. This will more than likely be RCA phono plugs on both ends. You also should check the number of connectors on the subwoofer as some require two for left channel and two for right channel.
Oct 31, 2010 | Audio Players & Recorders
Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
May 27, 2009 | Panasonic SC-HT930 System
Need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Feb 28, 2009 | Panasonic SC-HT730 System
Panasonic Sub Woofer
I Have the sub woofer SB wa 340, but I need the remote control if posible bussines send me the information 7862873227
Jun 23, 2008 | Panasonic SC-HT690 System
Subwoofer
is it just the sub you have or do you also have the dvd unit with it?
Feb 20, 2008 | Panasonic SC-HT690 System
Panasonic SC-HT690 System Logo
5,140 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
